School me on twin disc. - Honda-Tech - Honda Forum Discussion
Transmission & Drivetrain Gearboxes, Differentials, Clutches
Old 05-16-2018, 01:08 AM
Balor_Gr's Avatar
Default School me on twin disc.
Ok im thinking about installing a upgraded clutch together with the new engine for the breaking in procedure not to take the trans again aout for clutch later...
Hp for now will be like 350 - 400. Later ill go for the best i can on 93(100 EU) + water meth, lets say 600-650hp
Engine is 84x89 sleeved.
In my knowledge 600 on a single disc stage 4 whatever is kinda pushing it.
So im thinking o getting a twin disc to be on the safe side power wise . (If we are sure a particular 6pack can hande 600 safely why not)
The problem is i never had a twin or driver a honda with a twin.
Its supposed to be softer on the foot from the stage 4 6puck... right?
Clutchmasters has 2 options
“Street and Race” (TD7S) – 1 ceramic rigid disc, and 1 fiber tuff rigid disc "
and “Race” (TD7R) – 2 ceramic rigid discs :
On the other hand Competition clutch now only has the high hp rating C option available 4-8026-C (they stopped lower hp rating A and B options)
AND its around 200 euros/$ cheaper if we include the flywheel in both companies.
Whats you experiences with these. What do you know ? What would you buy ?
>Is the street CM version better for daily driving since CC wont offer softer disc combo?
Edit: They last at least like 10k miles right?
Balor_Gr is offline
Old 05-16-2018, 02:00 AM
Default Re: School me on twin disc.
clutches are measured by torque. so at 600-650whp, assuming torque will be in the 400wtq range. I think a single disc will be fine. now 500 wtq and higher yea a twin disc would be smart. I believe az_civic was dd car with a twin disc when it had a **** ton less power though.
ls joker is offline
Old 05-16-2018, 04:40 AM
LightningTeg's Avatar
I have an ACT XXG6 which is Maxx-Extreme pressure plate and 6 puck sprung disc. Rated to ~485ft-lbs. Its a stiff **** but drives pretty well.
My car makes 630whp/450trq no issues with the clutch
LightningTeg is offline
Old 05-16-2018, 05:39 AM
Autoworks's Avatar
My $.02 from personal use with a Spec Twin, CC Twin, ACT extreme single, and CC 5 single w/ heavy plate ...at the power/trq you are wanting to make; I would stick to a single and enjoy. I personally did not like the engagement of the twin in "normal" driving. The twins and ACT were on a D 500+whp motor, the CC Stage 5 on the F series (because I did not want the twin drivability and chatter in that car).
(if going twin, don't forget to add a pedal stop)
Autoworks is offline
Old 05-16-2018, 09:48 AM
Do you feel like the Twins disengage / engage faster?
Old 05-16-2018, 09:53 AM
Autoworks's Avatar
IMO, no. (also had them in a 88 that was fully converted to hydro). No because thee was no slipping in and out of the shift. It was all or nothing and the pedal touched the stop (which was pretty short). With the singles there was "more room to play" w/ engagement on the street.
Old 05-17-2018, 07:29 AM
Balor_Gr's Avatar
So lest say im going single what single should you trust 600-650 on a 2iter with the best drivability?
Balor_Gr is offline
gofastcrx
05-31-2008 10:07 AM
AllMotorRandy
04-26-2006 08:55 PM
Xumarius
General Discussion and Debate
70
09-10-2004 01:38 PM
IMSTOCK
09-07-2004 09:43 AM
Quick Reply: School me on twin disc.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
