Need some info!
Old Oct 15, 2015 | 05:22 PM
Jnantz00's Avatar
Default Need some info!
I bought a 99 boosted EM1 tuned on EcTune and I'm new to the game. It was blown up, completely rebuilt everything. Question is that I started it for the first time today and the MIL is on as soon as you key the ign on. Wasn't on when I bought it but is now and all sensors are connected correctly. Can this be an expired license issue or and actual problem? 2nd question is how the hell do you read codes? Might be a dumb question but my scanner doesn't even power up through the the DLC. Do I need the software just to read DTCs?
Old Oct 15, 2015 | 05:54 PM
F22Master's Avatar
Default Re: Need some info!
OBD1 ecu?
If so, find the "service check connector" wire (google obd1 ecu pinouts). Ground that wire and your MIL should flash the stored codes. 1 long flash = 10, 1 short flash = 1.
Old Oct 15, 2015 | 06:03 PM
Jnantz00's Avatar
Yea it is a P28. Guess I should of included that and thanks I'll give is a shot in the morning
suburban_ninja
Oct 31, 2013 11:21 AM
dohcmotors
Aug 25, 2008 09:38 AM
prettylew
Apr 19, 2008 08:27 AM
labtec2
Mar 24, 2008 10:17 AM
KevronsEG
Jan 21, 2003 02:22 PM
