b16 tuning
Old Mar 28, 2016 | 11:46 AM
Jamzi's Avatar
Default b16 tuning
Hello.
I have seen lots of topic's about tunning the B engines but didint get the info i was looking for.
So im posting my b16a engine mod list and dyno's
70-68mm TB
Hondata intake gasket
Aftermarket exhaust system ~2,3 inch
NGK wires
NKG Iridium sparks
T-Pros 4-1 exhaust manifold
AEBS intake manifold
Skunk2 valve train
Skunk2 pro stage2 cam
The probl. im looking for is my engine idles bad (some times it even dies )
and it makes poor performance .
my tunner says I definitely need to get cam gears and degree it .
but I m also thinking its tunned bad.
any suggestions?
Old Mar 28, 2016 | 09:16 PM
raverx3m's Avatar
Default Re: b16 tuning
you need adjustable cam gears. with those cams.
tuner can only do so much if the cams are not degreed
Old Mar 28, 2016 | 10:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Is your dyno sheet showing "Wheel" HP/Torque or is it calculating and displaying "Flywheel" or "Crankshaft" HP/Torque ???
Old Mar 29, 2016 | 04:49 AM
Masterl1nk's Avatar
Is your IACV running fine?
As I can see below on the graph, there is a loss 'curve' (used to determine crank HP).
Are you running Hondata s300?
Old Mar 29, 2016 | 11:31 AM
Jamzi's Avatar
nop.
BTW ,i got AEM cams, i will try to degreee it. and post news here
Old Apr 1, 2016 | 11:25 AM
Jamzi's Avatar
quick question :
+2 is advancing?
so -2 ar retarding?
like skunk base settings : -1° Intake, +3° Exhaust
Old Apr 1, 2016 | 12:49 PM
1HGEJ2's Avatar
stock block?
Old Apr 1, 2016 | 10:01 PM
Jamzi's Avatar
Originally Posted by 1HGEJ2
stock block?
yeap, not milled head and stock block
Old Apr 2, 2016 | 01:19 PM
1HGEJ2's Avatar
u need high comp pistons for this cams
Jamzi
Mar 28, 2016 11:51 AM
FMN716
17
Mar 24, 2014 08:02 AM
SonicB
Jul 21, 2010 01:12 PM
biassj
34
Oct 10, 2006 08:14 PM
msbhvn_DC2
Feb 9, 2006 02:08 PM
