voltage dropping effecting afr's
Old Sep 6, 2015 | 04:00 AM
blackeg's Avatar
Default voltage dropping effecting afr's
well im back in the boosted world for the first time in a year or so. while datalogging/tuning i noticed my voltage is a few tenths lower than i remember and than it used to be. currently getting 14.3v idle no load, 14.0v with fan and lights on. i did a pull last night up to about 7k rpm and voltage was down to 13.5v. i dont ever remember it lower than 13.8. well anyway it was getting rich into the mid 10's from the low/mid 11s when its seeing closer to 14v.
im currently adjusting the injector battery offsets to compensate but i feel theres another issue here. using neptune, precision 880s, walbro 255 stock wiring, oe resistor box (all of which ive used for years together without this issue)
how low is too low on volts?
the battery is a bit old now, but has 12.5v when tested car off which i think is ballpark...
Old Sep 6, 2015 | 06:33 AM
boosted94gsr's Avatar
Default Re: voltage dropping effecting afr's
Resting voltage on a battery doesn't tell you if it good or bad. You need to test the voltage under a load. Any battery shop can do it for you typically free of charge.
I see my voltage drop into the high 13s sometimes when reviewing logs, but it doesn't affect my afrs. I'd say your batter injector offsets need a little love. Warm the car up then disconnect the alternator at the fuse box, then see what happens to your afrs and adjust the battery offsets for that voltage to bring them back to normal if they changed.
Old Sep 6, 2015 | 09:44 AM
theYBLEGAL's Avatar
Loved
Sounds normal to me. I see the same voltage behavior in most cars, non-hondas too.
Just adjust the battery offsets. I don't recommend disconnecting your alternator, just turn accessories on at idle. I can get voltage to drop into 12's if I have brights on, rear defrost, cabin fan maxed, dome lights on, and try to roll up already rolled up windows (Large load there).
Old Sep 6, 2015 | 06:07 PM
Muckman's Avatar
Moderator in Chief
Agree on the Injector battery offset tuning. Regardless of what the manufacturer supplies for values I always find this table needs tuning. However its really easy once you get a solid AFR at your baseline voltage.
Old Sep 7, 2015 | 06:11 PM
turbonetics3597's Avatar
In your ems setting injector battery offset may not be clibrated correctly
Old Sep 8, 2015 | 02:21 PM
blackeg's Avatar
so I believe I found the issue it was the tps sensor. I was using a sk2 alpha 66mm and for whatever reason I had to clock the **** out of it to get somewhat reasonable wot voltage. well looking over data logs I noticed it kept changing its output from what I calibrated it at causing it to only see like 70-80% when I had it pinned. ill recalibrate max min volts and take it for a spin again once it cools down it was damn near 100 today
Old Sep 8, 2015 | 04:34 PM
Muckman's Avatar
Moderator in Chief
That's not related to your original post what so ever. Sounds like a bad TPS sensor.
Old Sep 9, 2015 | 03:07 AM
blackeg's Avatar
I know. I noticed the voltage change and the afr change and thought they were correlated since the afr issue happened under higher load with the fuel pump working harder. this is also where the wot but lower tps voltage came into play. idk im loosing my mechanical touch the less and less car stuff I do I guess...
slammed98sedan
Dec 25, 2014 07:12 AM
vtecnique69
Nov 7, 2014 08:20 AM
vtecnique69
Honda Civic (2006 - 2015)
Nov 7, 2014 08:18 AM
motegicivic
May 6, 2012 12:02 AM
bozoka45
Dec 27, 2004 05:21 PM
