Obd2 to obd1?
Old Jan 31, 2016 | 03:25 AM
barraea's Avatar
Default Obd2 to obd1?
This sounds very silly but going from obd2 to 1is a down grade right? ?
I swear i seen people on here posting about obd1 conversions is this correct?
Old Jan 31, 2016 | 03:35 AM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: Obd2 to obd1?
not necessarily. depends on what you want to do with the car. for example, if you want to tune your swap with neptune or hondata you need to go obd1. unless you go K series witch uses it's own hondata module or re-flashing the computer. .
Old Jan 31, 2016 | 03:45 AM
barraea's Avatar
That's what i want to hear
I'm being called an idiot for not going obd2 in a old obd1 car as the motor I'm putting in runs a obd2 ecu
But now knowing if its good enough for honda boys its good enough for me
Reason i want to retain obd1 is due to its easier to tune much cheaper to
Old Jan 31, 2016 | 05:03 AM
barraea's Avatar
My q is now
Doesn't the obd2 ecu have more adjustment points n parameters etc?
Old Jan 31, 2016 | 02:23 PM
motoxxxman's Avatar
what engine?
Old Jan 31, 2016 | 09:35 PM
barraea's Avatar
It's for a ford eww i know
But ya i always thought i was seeing things about peoplegoing back to obd1 but now i know it's happening
Old Feb 1, 2016 | 11:42 AM
motoxxxman's Avatar
well that changes everything, and cant even really be discussed here.
the only reason honda guys with obd2 cars go back to obd1 is for tuning purposes. 96-2000 hondas are not tuneable unless you convert them to obd1 (92-95). it's really just that simple.
Old Feb 1, 2016 | 09:33 PM
barraea's Avatar
Cheers for that all understood now but dam i thought with the amount of hot hatch eks etc there would be a way to tune. ..but as you said its obd1 or after market ecu only
mobeast808
Jan 26, 2025 09:18 PM
92civic_si
16
May 6, 2004 02:50 PM
2muchGT
Oct 17, 2003 01:06 PM
Phat_GSR
Dec 15, 2002 05:31 PM
