Simple Stand Alone Ecu
Old Dec 30, 2015 | 02:56 PM
TurboEG6262's Avatar
Default Simple Stand Alone Ecu
Building a tube chassis rear engine car for autcrossing. What's the simplest stand alone setup for what I'm doing. Also do they make a simple harness to wire the factory ecu??? Thanks
Old Dec 30, 2015 | 04:25 PM
Eight09's Avatar
Default Re: B18b
Easiest way to wire in a stock ecu would be to get a complete harness and strip as necessary. Hondata is realtievely cheap for the ease of use/abilities
Old Dec 30, 2015 | 04:42 PM
Default Re: B18b
Thanks
Old Dec 31, 2015 | 04:36 PM
v4lu3s's Avatar
RTFM
Default Re: Simple Stand Alone Ecu
Megasquirt is probably cheaper but requires pretty good electrical knowledge.
Old Dec 31, 2015 | 04:39 PM
DieMaster's Avatar
Needs to be About 20% Cooler
this was my first thought:
Phearable.net - MIL Spec Harnesses - MIL SPEC TUCKED ENGINE HARNESSES
Old Jan 1, 2016 | 09:25 AM
DVDr's Avatar
I would go full stand alone route,
either AEM ( series one are super cheap) and build a custom harness or use a harness out of a car or a megasquirt
Old Jan 1, 2016 | 09:42 AM
spAdam's Avatar
Loved
Community Favorite
x2, but I would suggest an AEM EMS-4. It doesn't have any extra features that you don't need (since this is strictly a race car), it's still supported, and it will interface with their AQ-1 logger. They also sell a flying lead harness for it that should get you up and running pretty easily. I don't think you're going to be able to work with a pre-made harness since you're building your own chassis.
Old Jan 1, 2016 | 03:38 PM
Masterl1nk's Avatar
My vote to Megasquirt.
For 280 USD you can get a full MS2 kit that you need to build. It works pretty well with stock Honda sensors, reluctor, injectors and coil.
Also you can convert it to fully secuential fuel n spark.
Old Jan 22, 2016 | 01:34 PM
GhostAccord's Avatar
x2 on the MegaSquirt. love it! I have two of them now!
Both have the MS3X board as well. You can never have enough control!
If you have a good working knowledge of soldering and a proper iron. You should be able to put one of these together in an evening. Everything is very well packaged and labeled. Step by step directions are also available on their website. There is a very helpful forum/PDF files for setting up al of the sensor parameters as well.
As far as wiring harnesses go. they sell them for the unit as well. All you need to do is save your connectors and solder the wires to the MS harness wires. It will allow you to eliminate a lot of wiring BS.
Mikey3000
Jun 24, 2008 04:59 PM
jdmb16acivic
Dec 13, 2007 04:27 PM
tepid1
Oct 2, 2007 01:18 PM
USDM 4G VTEC
Apr 9, 2003 07:34 PM
