Same VSS issue for almost a year!
Old Feb 29, 2016 | 04:49 AM
Mjalaly's Avatar
Default Same VSS issue for almost a year!
I have not clue what is going on but VSS CEL keeps coming on and I cannot figure out how to get it work. I have directly wired 12v, GND, B10 and installed a whole new sensor. Is it getting an error because I am not using the stock dash (or one at all)? Thoughts?
Any way around this or can i install another sensor somewhere else? I have no clue how my tuner was able to tune with it on. He was boosting over 10psi on the dyno but once i get around 4psi it cuts out.
Old Mar 1, 2016 | 06:14 AM
Flr Power's Avatar
Default Re: Same VSS issue for almost a year!
VSS normally uses 5vdc...
Old Mar 1, 2016 | 06:53 AM
Mjalaly's Avatar
it is 12v since it pules 0-12v based on engine speed.
Old Mar 1, 2016 | 07:24 AM
Flr Power's Avatar
It's a vss so it would not be based off engine speed...
Old Mar 1, 2016 | 07:33 AM
Mjalaly's Avatar
yeah sorry ... not engine speed.
anywhoo... any solutions?
Old Mar 1, 2016 | 08:45 AM
Mjalaly's Avatar
the service manual shows the VSS sensor with two grounds (G101 & A23) inputs and one input to b10. that doesn't sound right.
this other one shows it going to power
Old Mar 1, 2016 | 10:01 AM
Flr Power's Avatar
There are just common ground. Do you have the speedometer working at all?
Old Mar 1, 2016 | 10:28 AM
Mjalaly's Avatar
ok but is it power, gnd, signal or just signal and gnd chassis/ computer? Those two different schematics show both.
I use a completely different dash with its own speed sensor off of the front wheels.
Old Mar 1, 2016 | 01:56 PM
PyroProblem's Avatar
What ECU and tuning software? Is there not a setting to disable VSS error codes?
Old Mar 1, 2016 | 02:01 PM
Most sensors have ground, 5 volt reference from the ECU, and a signal back to the ECU. I thought the vss sensor is a magnetic pickup type sensor so it operates like the ones in your distributor. ECU sees sine wave and converts it to digital for processing.. Someone correct me if I'm wrong.
Does the code come on right away or after you start rolling? If it comes on right away, I would think it's a problem with the circuit. If it comes on after a certain MPH, I would think it's a signal issue.
I wonder if you could some how spin it with a drill with it uninstalled but still plugged in, then watch the signal.
Old Mar 1, 2016 | 02:08 PM
I've seen corrosion at the VSS connector terminals also cause issues. Those look OK?
Old Mar 1, 2016 | 04:25 PM
Mjalaly's Avatar
I think I got it to work. I moved the ground location and now my s dash is reading a speed when I turn the wheel by hand. I will post if it comes back once I get it out for a drive.
Old Mar 2, 2016 | 08:47 AM
Tufflexveritiv's Avatar
You most likely have the pins wrong on the sensor itself
Ground 12v and then signal to ecu
Old Mar 2, 2016 | 09:24 AM
VSS gets a 12 volt reference signal and not 5 volts like most engine sensors?
Old Mar 2, 2016 | 09:25 AM
Yep
12v
Shares same voltage as injectors and iacv
Old Mar 2, 2016 | 12:14 PM
Good to know!
fcm
Nov 4, 2014 05:32 PM
Rat Rod
Nov 18, 2010 04:02 PM
blaze.1
Sep 10, 2009 06:24 AM
aziaticvang
Jan 13, 2008 06:35 PM
turismo128
Sep 27, 2005 03:22 PM
