Having trouble with a basemap
Old Feb 17, 2016 | 08:14 AM
z6sedan's Avatar
Default Having trouble with a basemap
Okay I ordered a basemap, going to say from EITHER xenocron or phearable because I do not want this thread to turn into the bashing of either one of these companies. I have had positive experiences with both in the past and do not wish to hurt any ones reputation.
SO my setup is a 95 civic, d16z6 i/h/e skunk2 stage 2 cam, crower springs, skunk2 IM, 66mm skunk2 TB, stock map, injectors etc
I am using flash and burn with an older moates burn1.
I have used a few chips with crome's p28 map and they all run fine, as soon as I load the bin provided the CEL stays lit when I start the car and as son as I even blip the gas the engine bogs down, almost like something isnt scaled correctly. I wrote the bin provider and he/she verified it and said the bin is fine!
Also he/she sent a second bin and the only difference waqs debug mode and disable o2 sensor... Not sure how no o2 would run but I would assume rich and shitty...
I am attatching the bin, can someone please look it over and see if theres any obvious mistakes, the car is absolutely stock with sensors and everything besides the bolt ons stated above! Thanks!!!Order29025-Z6-Stage2Cam-IHE-240cc-StockMap-basep72.bin
Old Feb 17, 2016 | 08:21 AM
oldschoolmaster's Avatar
Default Re: Having trouble with a basemap
I would help but can't open it up
With that kind of mod you have need a wide band and start with base map then tune to your car in your current sea level
Old Feb 17, 2016 | 08:27 AM
z6sedan's Avatar
Why cant you open it? Do you want me to send it directly? I know how to tune fuel maps to wideband pretty well, I just dont mess with timing maps, I have used basemaps in the past for a starting point and tailored to fuel maps until I am happy with the wideband reading
Old Feb 17, 2016 | 10:07 AM
Masterl1nk's Avatar
Maps looks smooth.
Have you checked the CEL code? Try disabling injector check, ELD.
Old Feb 17, 2016 | 10:18 AM
z6sedan's Avatar
Appreciate the response, it ended up being something with that tune, corrupt file maybe I am not sure. But Got sent a third and completely different tune and it runs perfect!
Old Feb 18, 2016 | 05:43 AM
Masterl1nk's Avatar
Great!
Before burning the bin file, first erase the EEPROM!
GooseS2000
Engine Management and Tuning
Aug 13, 2013 10:09 AM
Serg562
28
Jun 14, 2011 02:21 AM
vtecbasher
Aug 9, 2006 11:45 PM
THMotorsports
Apr 5, 2005 09:06 PM
hondaeg8
Jan 17, 2004 05:42 PM
