Ecu help
Old Mar 5, 2016 | 05:58 AM
Hays419's Avatar
Default Ecu help
Have a 99 integra that I did a b20 swap, need to know the difference between obd2a and obd2b. Have the stock b18 ecu and looking to get correct one for engine. Non vtec
Old Mar 5, 2016 | 07:33 AM
motoxxxman's Avatar
Default Re: Ecu help
what is the full engine code of the b20? theres a LOT of different versions of b20's out there. and is the b20 completely stock top to bottom?
Old Mar 5, 2016 | 08:53 AM
Hays419's Avatar
It is a b20b out of 99 crv, I put the stock b18b cams in it and we put the crank sensor and oil pump to convert it to obd2. It also has the b18 intake and a 65mm throttle body.
Old Mar 6, 2016 | 10:16 AM
motoxxxman's Avatar
99 is obd2a for both the integra and the crv.
using the stock crv ecu may or may not work all that well because you changed the cams and intake manifold, and using a much larger TB. your best bet would actually to convert to obd1 and have it tuned.
Old Mar 6, 2016 | 09:07 PM
Hays419's Avatar
Thanks, I was just looking into doing that.
Old Mar 10, 2016 | 02:58 AM
forbiddenera's Avatar
+1 on tuned obd1
Hays419
Mar 7, 2016 12:43 AM
allmotorCRX.
13
Jun 12, 2011 06:46 PM
91CRX-T
Apr 28, 2011 06:45 AM
93redeghatch
Mar 24, 2010 11:43 AM
