b16b ecu help needed !!!!!
Old Sep 25, 2011 | 09:58 AM
eire_eg's Avatar
Default b16b ecu help needed !!!!!
i have searched but when it comes to wiring im just not the greatest
i will be getting a b16b and i will be going either 1 or 2 routes,
i will be putting a b18c crank and connecting rods on it therfore stroking it too 1.8L and a new header, exhaust and a good tune
or else,
i will get cams, intake, header and exhaust and a good tune
either way i want 200 hp and hopefully 30mpg+
whats my best choice?
Thanks for reading
Old Sep 26, 2011 | 03:37 AM
7rrivera7's Avatar
Default Re: b16b ecu help needed !!!!!
P28 chipped ECU. PM me for pricing...
Old Sep 26, 2011 | 05:44 AM
spAdam's Avatar
Loved
Community Favorite
or else,
Thanks for reading
Why not get a b18c-R? That's all you'll be building by swapping out the b16b crank and rods for the b18c crank and rods.
Old Sep 26, 2011 | 06:24 AM
GhostAccord's Avatar
Best bet would be to search your local area for a tuner. Find out what hardware and software they are comfortable with and go from there. No sense in buying a chipped P28 if no one around you knows what to do with it. However, I'm sure there are tuners in your area that can, best to talk to them first though.
Old Sep 26, 2011 | 07:34 AM
eire_eg's Avatar
pm'd........
i can get a b16b much cheaper and will not need axles or linkages...Thanks for the reply though
agreed....will do
Another question is... the civic i will be gettin is an eg3 so if i got a loom of an eg6 b16a engine, will it plug into the b16b and into the eg3 ?
any help much appreciated
Old Sep 26, 2011 | 02:45 PM
spAdam's Avatar
Loved
Community Favorite
Mostly. The b16b and b18c blocks are externally identical and share the same head with the b16a (except for the b18c1, but externally very similar). The b16a block is just slightly shorter. There will be some things that are slightly different due to different generations but the harness will reach fine. No need for different axles, linkages, or anything else.
Deminmatthew
36
Nov 10, 2013 02:23 PM
92KillerBee
Feb 1, 2005 03:56 PM
redline23
Nov 28, 2004 07:05 AM
BLK99VTECR
Sep 4, 2003 11:47 AM
SD99GSR
Jun 19, 2003 10:16 AM
