need help with obd0 ecu chip
Old Nov 28, 2011 | 01:07 PM
dc2_dustin!'s Avatar
Default need help with obd0 ecu chip
my buddy has a chipped obdo pr3..just got it chipped/tuned and now it gets a solid red light..have done a few obd1's and know that if you clip the j1 jumper it will run back on the stock rom..was wondering if there was a similar procces for obd0? thanks in advance
Old Nov 28, 2011 | 01:17 PM
raene's Avatar
Default Re: need help with obd0 ecu chip
There is no equivalent process on OBD0, sorry. With OBD0 you have to cut the OEM chip out and put in a socket.
I'd check the chip is making a good connection with the socket and isn't at all loose, and make sure no legs are bent, before freaking out too much. Standard chip sockets typically suck.
Old Nov 28, 2011 | 02:01 PM
thought so..thanks man
Old Nov 28, 2011 | 05:47 PM
josephcmiller2's Avatar
x2
90R3x
Engine Management and Tuning
Mar 8, 2015 05:02 AM
spens 91 Ef
10
Jul 12, 2012 10:32 PM
Radim
Dec 23, 2009 07:29 AM
border919
May 16, 2009 07:44 AM
shortshift89
Aug 29, 2007 06:31 AM
