H22 Compression problems?
Old Oct 17, 2011 | 01:09 PM
01slowlude's Avatar
Default H22 Compression problems?
I have a 2001 Prelude, h22a4. My car isnt running right. I was running and meant to grab 4th and put it in 2nd .. what could that damage??
I did a compression test and the numbers were, 175 170 150 165. What could this be from and how can i fix this problem.. thanx
Old Oct 17, 2011 | 02:00 PM
SteelcityLude's Avatar
Default Re: H22 Compression problems?
bent valves and/or your oil pump took a crap, i did the same thing to my h22 twice, more than likely bent valves thats what happened the first time.
Old Oct 17, 2011 | 03:08 PM
01slowlude's Avatar
That's what I was thinking, I bought another cylinder head. Thanks
Old Oct 18, 2011 | 05:31 PM
01slowlude's Avatar
Would bent valves cause a loud squealing noise, usually at high rpms?
Old Oct 18, 2011 | 09:44 PM
no, but you might as well convert to a manual timing belt tensioner, ditch the balance shaft belt, and change the timing belt and water pump while your in there.
i actually had a loud squeal on my h22 in the higher rpms finally i took the timing belt cover off and found out the tensioner spring for the balance shaft pulley was gone
94vtecmn
May 17, 2009 07:31 AM
ludekid4323
Feb 28, 2009 02:29 PM
hondatuningboi96
May 27, 2007 03:38 PM
jjbonseye
Mar 24, 2006 07:19 AM
pgillean
Oct 2, 2004 09:09 AM
