turbo or supercharger an what kind of EMS for a fully built H22 click for specs on mo
I have 2.2l H22a4 head w/super tech valve train an the works... Bisimoto 2.4 cams an cam gears and its port an polished w/a H22a block w/JE pistons 9:1 compression. eagle rods polished an balanced crank. an yes the block is sleeved. an the transmission has a new blox LSD my goal is to run high 9s ( like 9.75's to 10.4's ) an all this would go in a 2000 BB6. (i don't have to be in the 9's but it would be very sweet) what kind of turbo or supercharger would i need to look into also what type of ECU, axles/clutch kit, injectors an how heavy of a flywheel...???? (would i need 680hp or 850hp) any tip would help (any but a smart a$$ answer)
Thank you...
Thank you...
Re: turbo or supercharger an what kind of EMS for a fully built H22 click for specs o
A lot of information concerning builds is on this website. Please search/read the forum to see what others have found....
Running 9's is very expensive.
On top of a good power plant, it will generally require an expensive transmission, axles, suspension etc.
I.E.:
1. PPG/Liberty/Other aftermarket tranny (if you want it to hold up)
2. Drive shaft shop axles/hubs
3. Coil over system / traction bars etc
Concerning engine management, use a management that your dyno tuner prefers such as: Hondata s300, AEM ems, Haltech, Neptune etc.
I would suggest dual bosch 044 fuel pumps with injector dynamics 2000cc injectors for your fuel setup. You will also want to setup aftermarket feed & return lines etc.
Hope this helps...
I.E.:
Hope this helps...
Drifter6508
11-18-2011 05:07 AM
Drifter6508
11-16-2011 01:30 PM
Drifter6508
11-09-2011 03:58 PM
