quick ecu question/suggestions
Old Oct 4, 2011 | 05:37 PM
vtexas936's Avatar
Default quick ecu question/suggestions
I recently picked up a 98 hatch with a b20z2 block and ls head
Guy i got it from said it was running a chipped p28 and he said the chip is messed up and that's why it runs rough
It idles between 800 and 1500 and constantly fluctuates
And when i drive it feels unless i give it some gas it's cutting out like im barely pushing the gas pedal
Is it possible its not the ecu?
Should i get a different ecu if that's the problem?
Any help greatly appreciated!
Old Oct 4, 2011 | 05:45 PM
mouab18c1's Avatar
Default Re: quick ecu question/suggestions
It could be so many things. What map is on the chip? Are there any CEL's?
Old Oct 4, 2011 | 06:03 PM
vtexas936's Avatar
Nah no cel. Only light on is the srs but that's it. And I have no clue on the map it's currently on. Is there any way I can tell? Sorry if im asking stupid questions
Old Oct 4, 2011 | 07:38 PM
mouab18c1's Avatar
Then that is where you need to start. Get a ls map burned onto your chip. At this point it will be hard to determine what map is on there since you don't know which program was used.
Old Oct 5, 2011 | 04:29 AM
vtexas936's Avatar
What about just running a stock ls p75?
Old Oct 5, 2011 | 06:14 PM
mouab18c1's Avatar
That could would be the other option. I have seen few b20's that will run good on a Stock ls ecu.
Old Oct 7, 2011 | 12:33 PM
vtexas936's Avatar
Thanks for the help. I'll get a p75 then go from there. I'll keep you updated
Old Oct 7, 2011 | 12:45 PM
Mike Lowwryyy's Avatar
As mentioned before, could be anything... ECU, bad chip, improper tune, wiring issue, bad iacv...
Is the motor stock?
Old Oct 7, 2011 | 10:39 PM
mouab18c1's Avatar
Yes it was a bone stock ls.
Old Oct 12, 2011 | 04:10 PM
egvera89's Avatar
get a p75 and see if you still have the same problem and lets go from there.
Old Oct 12, 2011 | 05:13 PM
GagnarTheUnruly's Avatar
Does it have a stock O2 sensor?
Old Oct 14, 2011 | 04:48 PM
josephcmiller2's Avatar
Check tune-up parts. Pull dizzy cap and check. Maybe plugs, wires, filters, etc. Should do all that anyways before tuning.
Old Oct 24, 2011 | 08:08 PM
nicks00si's Avatar
The idle going from 800 to 1500 back and forth could definately be the IACV. My buddy's running an lsvtec in his integra and it was having the same problem, he changed it out a couple days ago and the problem is fixed.
zachhthe1
Engine Management and Tuning
22
Oct 25, 2013 07:17 PM
msinsky14
Jan 31, 2009 11:59 AM
aggressivecivic
Jan 22, 2008 05:52 PM
F20_EG6
Jan 3, 2008 04:36 PM
AZNracerx1989
Jan 16, 2006 07:41 PM
