P30 Chip
Old Sep 1, 2011 | 02:59 PM
Etzim's Avatar
Default P30 Chip
Ok im really lost, there are so many options to tuning.
Im doing a jdm b16a 2nd gen swap in my 93 integra. Im going to be running on a p30 ecu. But its highly recommended to get it chipped. Im not sure what exactly i want to do or what i should do so any recommendations please tell me.
Chip Options:
*Set rev-limiter. Im thinking 9200rpm
*Set the v-tec point. im thinking 5000rpm
*Add 2-Step. im thinking. 4000rpm
*Disable knock sensor. not sure if i should?
*Disable o2 sensor. not sure if i should?
*Disable IACV. not sure if i should?
*Disable speed check. YES
*No Govenor. No idea if i should.
Old Sep 1, 2011 | 04:57 PM
mtber's Avatar
Default Re: P30 Chip
Chip Options:
You can run the stock p30 without an issue on a stock b16 engine...
Why don't you consult with who ever you are having chip your ecu? :-)
The stock revlimit is at 8300 rpms. You will not make positive power with a stock b16 above 8500 rpms. Set the revlimit at 8500 rpms.
Vtec: Stock is 5875, I wouldn't set it any earlier then 5600 rpms as you will simply create a dip in your powerband.
Knock sensor, it's not needed.
IACV, leave it enabled
Speed gov, remove
O2 sensor, disable if your o2 is bad
Old Sep 1, 2011 | 06:07 PM
Etzim's Avatar
just what i was looking for.
But one thing, you said i wont see any power gain past 8500 rpm. But the higher the rpm the more fuel and air, and that all goes to the gearing, so technically wont i be seeing a power gain? and eventually im going to build this motor, it will be put in with bolt ons btw, cai and a header.
Old Sep 1, 2011 | 06:18 PM
Etzim's Avatar
i was told they ran better chipped and did better with aftermarket parts, even internally.
Old Sep 1, 2011 | 07:03 PM
mtber's Avatar
The engine doesn't make positive power past 8500 rpms on stock cams, there is no point in reving the motor up there...
A chipped ecu would yield more power over a stock ecu if you had bolt ons such as intake/header/exhaust.
Old Sep 1, 2011 | 07:11 PM
turbodcxbro's Avatar
^^ Listen to this guy, that kinda free advice from an expert is hard to come by!
Old Sep 1, 2011 | 07:59 PM
Etzim's Avatar
Alright thanks for the advice, ordering my ecu soon
Old Sep 1, 2011 | 08:19 PM
GhostAccord's Avatar
A base map created by someone sitting behind a computer won't always give you the max gains. If you want to get the most out of your engine and chipped ECU. You need to go to a tuner and have it tuned properly.
Old Sep 1, 2011 | 10:53 PM
Etzim's Avatar
Yeah i understand that^ unfortunently i dont have the funds for that right now. I only have enough to get the swap in with a low budget chip.
Btw i messaged the guy, he said they are out of p30 ecu's but a p28 would work just as well because im getting it chipped. Should i wait to get a p30 or is a p28 good?
Old Sep 1, 2011 | 11:41 PM
Etzim's Avatar
btw if i disable the knock sensor will i have problems with vtec?
Old Sep 2, 2011 | 04:38 AM
mtber's Avatar
No
HondaVTEC93
22
Mar 9, 2005 10:57 PM
jdmb16a hatch
13
Sep 30, 2004 09:16 AM
tc
10
Apr 23, 2003 06:06 AM
