need help!! been tryng for 2 months!
Old Sep 25, 2011 | 01:05 PM
gaspari514's Avatar
Default need help!! been tryng for 2 months!
Car keeps throwing crank angle sensor code. Its obd1 gsr motor with p06 ecu... wiring seems fine. Dizzy seems fiine.... just put a bunch of money in the car now running like *** when the code comes on.... need help! Anyone!
Old Sep 25, 2011 | 01:30 PM
gaspari514's Avatar
Default Re: need help!! been tryng for 2 months!
Help ;( before the wether gets bad ;(
Old Sep 25, 2011 | 01:40 PM
mtber's Avatar
What exact code are you throwing? Code 8 or code 9 etc?
Is your p06 ecu chipped/converted to vtec?
Old Sep 25, 2011 | 01:51 PM
gaspari514's Avatar
It is chipped. Its code 4... don't know if its converted to vtech or not. Assuming my tuner did
Old Sep 25, 2011 | 01:52 PM
gaspari514's Avatar
I think tuner uses a form of ectune as well
Old Sep 25, 2011 | 02:03 PM
GhostAccord's Avatar
DTC 4 is the crank shaft position (CKP) sensor. What distributor are you using? Also is it OEM honda or a reman unit?
You say the wiring looks good, have you tried testing the sensor and it's wiring with a multimeter?
Old Sep 25, 2011 | 02:18 PM
gaspari514's Avatar
I have not.. how can I tell the obd 1 from obd 2 dizz?
Old Sep 25, 2011 | 02:27 PM
gaspari514's Avatar
its oem too
Old Sep 25, 2011 | 02:49 PM
gaspari514's Avatar
Also, a ittle info on build....
B18c1
Benson sleeved
Cp pistons 9.8;1
Eagles.
Ls crank
Portflow head.
Sk2 tuner1
Crower valvetrain
Skunk2 valves and gears
Edle vic x
Bdl 68mm throttlebody
Walb 255 fed into bosch 044
1000cc inj
-8 lines
Bdl fuel rail
Gt3040 turbo
Love fab manifold.
Other turbo crap...
425whp 280wtq 16 psi.
That's the basics... so this code keeps ****ing me up... don't know what to do
Old Sep 25, 2011 | 07:04 PM
gaspari514's Avatar
No hellp?? ;( its confusing me!
Old Sep 26, 2011 | 12:59 PM
TurboChurch's Avatar
its either the wiring or the sensor. Refer to Helm Manual to test both the correct way with multimeter. If either is out of range, fix the problem. If you recently did a wire tuck, assume wiring 95% of the time.
Old Sep 26, 2011 | 01:32 PM
gaspari514's Avatar
So... replace the harness??? I forgot to mention wiring is obd2... but I have conversion harness
Old Sep 26, 2011 | 03:13 PM
No. Test the sensor and it's wiring to the ECU. That way you can see exactly what needs to be replaced.
Do you have a shop manual and a multimeter? IMO those are the most important tools when doing a swap of any kind.
Old Sep 26, 2011 | 04:45 PM
gaspari514's Avatar
Ok I see
Old Sep 27, 2011 | 04:11 AM
Its also likely that you have a bad connection at your jumper harness, especially if you had the car tuned without these issues and then suddenly they appeared say when the tuner pulled his equipment off your car or say when you tried to put your ecu back where it belongs behind the kick panel. I would make sure all wire connections are tight and that the wires are not falling out the back of the connectors.
418whpturboD
Mar 7, 2009 07:01 PM
mraudio13
Sep 19, 2002 05:34 PM
