p72 ecu help
Old Oct 27, 2011 | 12:11 PM
landon2992's Avatar
Default p72 ecu help
I have a JDM ITR swap in my 96 hatch so it has the p73 ecu in it. And I have emissions coming up soon. I live in MD. I figured the p73 ecu wouldnt work since its JDM. I went there and hid the obd port under the dash so I could get them to do a sniff test but they wouldnt do it and gave me an extension. Ive waited long enough and I have emissions coming up again in January. So..my question is, will a GSR p72 ecu work to pass emissions? Any input is helpful. Thanks
Old Oct 27, 2011 | 11:45 PM
mouab18c1's Avatar
Default Re: p72 ecu help
Go test it and post your results. The p72 will feed less fuel so you might have a shot.
Old Oct 28, 2011 | 03:53 AM
landon2992's Avatar
I'll have to try it then. And will post the results of what happens. I figured it would work as long as it passes emissions. Can't believe it's been viewed 105 times and only one reply...
turbojdmsol
Sep 19, 2009 07:17 AM
Mikes2000civicsi
Nov 24, 2008 09:33 AM
brownman72000
Jul 11, 2003 08:01 AM
Petah
Jun 10, 2003 02:11 PM
