built b16 low power help!
Old Oct 6, 2011 | 12:39 AM
bradabu's Avatar
Default built b16 low power help!
i have a b16 with skunk2 stage 2 cams, skunk 2 valve springs and titanium retainers, skunk2 cam gears, aebs IM, type R throttle body, higher comp pistons, ARP rod bolts and head studs, password jdm (whale *****), hytech headers tri-y, with full 2 1/2 piping...
problem is that my motor is being dyno tuned but for some reason my motors not making any power! its only at 94whp at 6000rpm! i have good compression, spark, and fuel maps and timing is all set. what may be the reason why im not making power? and also when i rev past 4500 rpm on acceleration my tack seems to fluctuate...can this lead to a problem? please any help will be nice and no negative comments
thanks
Old Oct 6, 2011 | 02:08 PM
TurboChurch's Avatar
Default Re: built b16 low power help!
whats the graph look like from dyno? Ignitor going bad? engine popping? what is your compression numbers for all cyl? did you degree the cams in when you installed them or just drop them in and put stock gears on it? whats your timing like? Did you sync the ecu timing with the the distributor?
-NEED MORE INFO!
zhan28
Apr 17, 2006 09:35 AM
boosted k20
Aug 29, 2005 01:28 PM
slow91crx
Jun 1, 2005 04:47 AM
rough_draft
15
Jan 19, 2005 12:27 AM
stevel
Jan 8, 2003 06:30 AM
