Will a bad PCV be detectable at the sniffer?
Old Sep 25, 2011 | 05:01 PM
erikiksaz1's Avatar
Default Will a bad PCV be detectable at the sniffer?
Just curious, if you have a PCV that is stuck closed, will there be any affect on the AFRs? What about if the valve cover ventilation is not hooked up to the intake? Will that affect the AFRs?
I know a car should be in tip top shape for a tune, but would these things greatly degrade a tune?
Old Sep 25, 2011 | 07:56 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: Will a bad PCV be detectable at the sniffer?
The valve cover vent hooked up as stock is for providing fresh air TO the crankcase. I can't see where either one should affect AF ratio a measurable amount, but if the valve is stuck closed you'll just be pushing it all out through the valve cover vent. The question remains, why not replace the pcv valve?
Old Sep 25, 2011 | 09:37 PM
erikiksaz1's Avatar
Oh, I was just curious. Cleaned out my PCV a while ago.
civic-steve-94
10
Jun 12, 2011 05:05 PM
Black R
Jan 25, 2010 07:18 PM
Bioinfomatic
Feb 23, 2007 04:15 PM
Ri5e
Aug 11, 2002 03:28 PM
