chipped ecu help
Old Oct 16, 2011 | 09:02 AM
boostkid345's Avatar
Icon3 chipped ecu help
hey guys im a bit new and looking some help amm i have an obd1 ecu think its a p28 not 100% sure will double check but anyway it came with a skunk2 chip in it and i was juss wondering if there was a way for me to reprogram it and set my own set up on it like launch control and stuff like that if any one has any idea or any info that can help me i would rlly appreciate it thanks in advance
Old Oct 16, 2011 | 10:07 AM
SpeedwayCoating's Avatar
Default Re: chipped ecu help
pgmfi.org
Old Oct 16, 2011 | 10:33 AM
thanks bro wil do a lil research on the site as like i sated im very new to all of this
Old Oct 16, 2011 | 10:40 AM
7rrivera7's Avatar
You can if the Skunk chip is re-programmable. If the chip has a sticker, remove it and see if there is a glass circle in the middle of it or if it is smooth. If it has a circle, you'll need special equipment to erase (UV light) and reprogram it (no Moates). If it's smooth, see if says SST or Amtel.
Old Oct 16, 2011 | 11:49 AM
hey bro am im not by the skunk 2 ecu atm but i have another one its a toyomoto chipp and it does have the c true in the chip what will i need to do
Old Oct 16, 2011 | 12:04 PM
7rrivera7's Avatar
You can't reprogram that chip without special equipment. You need to buy an SST chip which you can get at www.moates.net, www.xenocron.com or even eBay!
http://www.xenocron.com/eprom-chip-s...gle-p-149.html
The chip is blank so you need Crome and a chip burner like the Moates Burn2:
http://www.xenocron.com/burn2-usb-chip-burner-p-88.html
You can also buy a preprogrammed chip from Xeno or Phearable and not have to deal with burning a chip:
http://www.phearable.net/shoppingcar...emap-p-60.html
http://www.xenocron.com/basemap-chip...tom-p-279.html
Good luck!
Old Oct 16, 2011 | 01:10 PM
thanks alot bro rlly helps
98_ssbp
May 29, 2012 12:44 AM
peaksi
Aug 5, 2008 01:12 PM
swiftjdmzc
21
Jan 12, 2008 01:48 PM
mortificationrock
Aug 12, 2007 07:52 PM
kNOwLedGeDA9
Oct 5, 2005 07:03 PM
