Ecu question
Old Nov 24, 2011 | 08:00 AM
flat out 99's Avatar
Default Ecu question
looking for an ecu that you can have two maps on that you only need to flick a switch to change between maps
Are Ectune or neptune capable of this have googled it but can't find anything helpsful thanks
Old Nov 24, 2011 | 09:05 AM
TheShodan's Avatar
Moderator
Default Re: Ecu question
It depends upon what you're trying to do. AEM does that with their Nitrous maps, but can be used for meth-water, or other means. If this is just a fuel map from 93 to E85, you would use your boost controller to the high setting and make sure you have E85. Your brain is the best switch.
Old Nov 24, 2011 | 09:44 AM
HRTuning's Avatar
NepTune RTP has the ability to switch to a secondary set of maps via a switch. Everyone else has copied this feature from us, so eCtune and Hondata have it as well. NepTune RTP also allows 3 completely separate tunes to be stored and switched between on the RTP in the event you need to fine tune parameters for different fuel types, which nobody else has currently.
a1320honda
Engine Management and Tuning
Oct 13, 2012 08:40 AM
no1knows908
Apr 21, 2008 10:35 PM
jadugartir
17
Dec 18, 2006 05:38 AM
Mugen Hamster
Audio / Security / Video
28
Mar 1, 2004 05:28 PM
