View Full Version : Welding / Fabrication
- Inner Wheel Well 91 Hatch
- Advice on tig weldeing
- Need chassis welding help! Seam welding unibody w/ TIG
- f20c s2000 exhaust manifold flange cad\dxf\dwg file
- Welder Recommendations - "Cheap" Tig Aluminum Welder
- Hey Kiddos I'm Back 😎
- Fab and Wiring shop in SoCal
- Vband for Exhaust
- Welder Rated for 60% Duty Cycle 1/4 in Steel
- reverse opened hood????
- Anyone familiar?
- Rear subframe swap ?
- 3D Printed Parts Repository
- Best place for premade body parts?
- spline conversion 26 to 28 on output shaft
- Source for Stainless Exhaust Flanges
- Best TIG Welding Helmet?
- First time welding [question]
- Anyone thats built their own header/manifold, can u recommend someone to make flanges
- best welding setup for beginner?
- Exhaust weld
- My first turbo manifold
- Tig
- Exhaust Question
- Header repair
- what whell bearing use for the awd brackets
- Looking for the 3 bolt flange downstream of cat
- random titanium parts we weld... starting with FK8 CTR J pipe...
- 3" SS Downpipe Fab
- Hydraflow, Vangen, fancy clamps..
- AN ORB Fittings for Valve Cover Ventilation
- Welded valve cover??
- exgr's B18/B20 large tube header titanium header.. Sexy, ain't it?
- PUSHER position fan shroud for "EG" Civic
- How stupid would it be to redrill a 6 bolt flywheel to 8?
- Crack fixable? Hairline crack between coolant passages
- 304 sch10 1.5 to mild steel flange what wire to use? (manifold)
- Modifying 4dr mugen side skirts to fit 2dr
- Floor Panel Rot - Spot welding?
- Cheap & ghetto bulletproof exhaust leak fix
- Anywhere to Buy 321 Sch40/Thick Gauge Turbo Piping?
- Fixing broken LSD in U2Q7 tranny
- DIY Plain/Spherical Bearings for Suspension?
- H22A1 - Weld rear motor mount boss onto block
- D15B Vtec custom welding RWD
- Noob question about exhaust welding
- Mugen header sounds like a tractor with test pipe.
- B16a header blocked by b18C1 bottom end
- 75/25 for stainless steel
- Wet and dry lay ups
- Eg coupe awd big hp build
- filler rod for 6061 0.118 sheet intake manifold 5356 or 4043.
- honda hrv (2003) 5 door sills
- Aluminum weld or patch?
- Welder question for guys that have done their own exhaust
- dirty aluminum welding
- egycasper's custom-fabbed intake manifold for K24
- SRI Intake tube fabrication design ideas
- Intake manifold FABRICATION
- SS welds
- I'm modifying a Power Wheels, how can I get a custom part?
- Kraftswerk Supercharger custom air intake kit
- Skeleton front end, Round bar?
- 3D printed
- Grille
- Using a Flux core welder for bodywork?
- noobieturbo manifold build
- I basically need all the panel of the trunk
- EG civic front fender molding delete
- 09 Si seats in 94 hatch
- Delete
- Fabricating a larger collector on to a header?
- Unequal Lengh Header measurements for K24
- New exhaust down pipe too close to steering rack
- Stainless steel water meth tank
- (S.Jersey)Where to find J32 turbo manifold
- Honda K20a2 gearbox flange drawings
- can i convert a manual vertial bandsaw to be semi auto?
- Full-Race manifold Crack 😔
- -8AN inside diameter
- Updated fab shop directory?
- Gassy Pancakes - Caps for backpurging
- Weld el prep
- b16 head welding ???? plz help
- best intake tube material
- Exhaust sleeve clamp
- Welder in the Dallas area?
- Is this weld-able as a temp fix?
- B16 valve cover baffle
- Wastegate positioning T4 divided
- Wastegate port placement
- any JRSC CAD/CNC templates for brackets? D-series
- Random thought on exhaust silencers
- Portable band saw stand.
- New Bumper Support/Bash bar
- Our, RMS Fabrications, new BILLET collector 4G63
- T4 twin scroll 4 into 1 merge collector design help
- Mid Engine RWD Project: Transmission Question
- Modification of single scroll turbo manifolds?
- Question on how to repair seals/joints in body frame
- Can I Weld an additional pulley onto the crankshaft pulley?
- New exhaust, custom valve for back pressure adjustable and sound level
- Anybody in central NJ or Lehigh Valley PA
- EF CRX Tubular Front end
- miller elite helmet repair
- Smokers/BBQ pits. Lets see them.
- Turbo aluminum compressor flange
- welding in new core support
- Diameter measurements OD/ID to make a turbo manifold
- Prelute vs Integramino
- Powder Coating
- Cut my coupe in half, re-shaping the body
- JDM door siding conversion to local
- Re-doing the spare tire bay. What gauge should I use?
- Work I've been up to lately
- Is this weldable?( thin material)
- What kind of 110v welder??
- Sunburn from welding.
- industrial ghetto dolphin tip
- What am I doing wrong with this aluminum tube?
- 30amp 240v 3 wire weld plug
- custom roll cage fabricator/shop in LOS ANGELES
- Dimple Die with Honda bearing races
- Valve cover and oil pan AN weld fittings
- exhaust manifold paints
- Where can I get custom flanges made?
- Rover 400 - Civic 5.5 gen MB3 body
- civic dx 98 Swap k20
- HELP: Yonaka Ronin Seats... Seat belt
- Anyone have a k24z3 exhaust flange cad file?
- Beginners blogg, tig progression, Ancu
- Cheapest source for 3" stainless exhaust flanges?
- Welding flex pipe
- Tungsten question
- Custom unequal length headers?
- Warpage of vband flanges.
- Best way to bend 0.125" alum
- turbo manifold bracing 75mm turbo
- Is this the leading edge of rallycar doors?
- 97 Integra Gsr need help with driver pan
- Any idea to fabricate this "turbo flange"?
- Hytech Side exit
- Equal length headers vs non equal length
- Tacking Non-Magnetic Piecuts?
- console modification
- Venting a non-Vtec valve cover
- What alloy for welding a honda head?
- oval SS tubing 2.5" nominal
- 1000HP BSERIES 3D build of civic hatch solidworks cad highly detailed models
- Beveling tool
- diversion 180 issues
- J's Racing muffler - Dimension???
- Advice on Forming Aluminum Sheet
- CNC manifold collector(metal porn)
- CNC Plasma work
- Anyone done this before?
- Aluminum Welds Pitted
- Raising your motor? For ground clearance...
- Make universal cat direct fit?
- AWS Advanced Motorsports Seminar 4130 Chrome Moly
- Who is making/selling 3in stainless exhaust flanges? (2 bolt)
- Exhaust tool
- ***WELDING RANDOM CHAT THREAD***
- Noob welder/fab from Italy
- chrome plater or dipper? recommendations?
- Fabricating with a GSR block vs LS
- I need your help with this piece =(
- TubeNotcher Paper Templates
- Reinforcing the chassis
- Band saws for light production
- Decent mig welder for starting out?
- Air compressors?
- Metal art
- Budget GTAW machines
- Tight radius bends
- Independent rear suspension in 1st Gen insight
- My beginner's progression into welding/fabrication
- Who sells Ls intake flanges, spacers, adaptor flange?
- short ram -> custom forced ram intake
- Tig Rod Size for Aluminum Sheet
- Roll Cage Bending Tips
- angle grinder safety
- rucked radiator bracket
- Best media to use in abrasive cabinet
- Coldsaw vs bandsaw
- Welding 1/2" channel to 3/16" 2x4 square tube
- How do you bevel your exhaust runner tubes?
- Making round tube square?
- Bung size for oil catch can (VALVE COVER SIDE)
- 2000 Civic Si HX35 downpipe build
- Fixing warped quarter panels
- Turbo D series Street Rail
- Who sells pre cut stainless pie cuts?
- Aluminum Flanges
- alty relocater bracket
- SCH10s exhaust manifold welding
- 100micron filter in aluminum?
- Another Carbon catch can.
- Made exhaust for my car, getting a slight putter at low RPM
- Welder extension cord
- Broke this at work, which bolt "material" is strongest against bending
- Welding Helmets
- Silencer End Caps - what are people using?
- aluminum exhaust fab recommendations
- picking a soldering iron
- welding v band to turbine housing
- turbo oil return sump fitting
- dxf files
- RYWIRE Tuck Radiator Question
- Dry film lube supplier
- Technique for forming collector to fit a T3 flange
- cleaning a PYREX gas lens screen?
- My First Attempt At Fabricating An Exhaust System
- Machine Shop
- Just bought Everlast PowerTIG 210 EXT - Need some Help Choosing Consumables
- 3d printed parts
- shaving/cutting calipers to fit wheels
- Another welder cart build...
- Turbo build questions. help
- First weld impressions
- Wheelhouse upper member
- 1990-93 integra exhaust stock sounding muffler with 2.5 in exhaust
- Bought a milling machine. Can you recommend some bits, etc.?
- Welding on turbo hotside?
- Must have tools for exhaust/header fab?
- Anyone make Custom Ring and Pinion Gears
- Wandering Arc welding Titanium?
- Welding aluminum oil pan. Need help please!
- What would you guys like to see in fabricaion shop/store?
- Ek trans mount frame bolts stripped. Need advice
- Sidewinder manifold for AWD Nissan GtiR.
- Wiring tools
- Welding fabrication table
- Looking for some advice
- b series mid plate transmission mount
- Most effective catch can baffleing design
- Best Fabrication Pictures
- TIG Question: Keeping everything squared up
- Radiator Neck and Cap
- Roll cage labor quote
- S2k carbon headlight deletes.
- Turbo Manifold builders question
- B-Series VTEC Billet Valve Cover Project..
- SOHC D-Series VTEC Timing Cover mold construction
- looking for a fitting
- Titan Motorsports Hiring Welder/Fabricator - Orlando, FL
- How to make a Carbon fiber fog delete
- warped v-band...
- Bad bottle of Argon?
- Custom Cage by All Speed Innovations
