PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
  1. Replacing front end on 94 Civic
  2. injector bungs
  3. D16Z9 Sand rail build
  4. Making my own roll cage??????
  5. TI bolts anodized?
  6. Help! M6x8mm flange head bolt.
  7. my bro's 95 talon TSI build
  8. machine shop
  9. + + Anyone want to build this for me? + +
  10. Thermodynamics dynamics 38 questions
  11. Some more titanium!!!
  12. roll cage installation question
  13. Sheet metal brake and big fuel cell
  14. eBay CRX with nice mods
  15. Looking for small 3" mufflers
  16. 321 vs 6061 Cat back
  17. 5" aluminum bends
  18. Fitting a Test Pipe/Cat
  19. Pics/Tips Wanted: Door Panel rollcage fitting/trimming
  20. Any ideas on how to "crush" or "oval" 4" downpipe for clearance?
  21. Building a 12V generator
  22. Eisenmann Exhaust with pictures,
  23. Bought a Lincoln 140 Mig, I have a few questions...
  24. redrill stock dsm turbo manifold for b18 motor?
  25. just wondering about conversion..crx
  26. 1.5mm wall thickness tubing. good for headers?
  27. Anyone ever herd of/used one of these welders?
  28. exhaust fab prices
  29. Need your help (Bandsaw)
  30. Remote oil scavenge pumps, where to buy
  31. twin charged civic
  32. reducer.
  33. need some feedback
  34. best Electric Die grinder for Port/Polish
  35. Where to buy a 2" collector flange?
  36. Welcome Home!!! Oh yeah, about your Prelude...
  37. Civic twin engine
  38. Just got our first peek at a watercooled MVS
  39. I need some brackets CNC'd...
  40. welding t3 flange to merge collector
  41. Question about choosing the correct type of TAP
  42. Fixing dented header
  43. Fabworx is in Speedhunters!
  44. Anyone use vibrant bungs latley?
  45. just fab-ed up my turbo mani.....now what?
  46. Where to get 1:1 mandrel bends.
  47. best place to get 3" exhaust donut?
  48. harbor freight welder...dont shoot me
  49. oil drain plug stripped..... what to do?
  50. ? for the IM fabers and engineers
  51. What size tubing for turbo manifold??
  52. Rear bumper support questioin
  53. belt sander question,
  54. Simple software for designing brackets?
  55. catch tank for a DA
  56. tig welding 1mm aluminum with HTP tig machine
  57. Turbo Cobalt
  58. anti slosh sumped tank help.
  59. My first welder!!!
  60. Turbo Manifold
  61. simple curiosity question
  62. transmission housing material
  63. Need A Some One To Weld My Radiator Support
  64. Header Building, Need a Builder/Fabricator
  65. subaru twinscroll
  66. I made a tall shifter...
  67. What are the best mig welder brands?
  68. Where Sch. 10 1018 steel bends straight where?
  69. Parts cleaner solvent
  70. Newb Question - Lightweight Pulleys
  71. Who can make me a 1/4" Divided T4 Inlet Flange?
  72. MIG HEAT WRAP... Have a beer call it a day
  73. New Header Build
  74. need to fix cracked cast iron machine housing
  75. I finally did it.
  76. What pipe size for a t3 flange?
  77. Noobtastic Welder question please help
  78. EG One piece fiberglass front end
  79. Strut bar material
  80. Harbor Frieght 90 amp MIG welder
  81. roll cage fabrication in oregon?
  82. my newtop mount i built
  83. need help, new welder issues
  84. I love this EG
  85. Best settings for harbor frieght mig welder?!!!!
  86. Roll cage welding
  87. some recent SBC turbo work i did........
  88. SS to Alum Connections
  89. Solar Flux
  90. Welding Turbo Manifold Techniques (Your input here)
  91. d16 valve cover vent and catch can?? help
  92. Polishing before Welding
  93. Building a catch can
  94. H2B Low Profile Valve Cover
  95. Steel thickness for turbo manifold
  96. Can engine block weld be done w/ motor in car?
  97. 240sx Frame Rail
  98. its cheap i know, but it wont get used for fancy stuff
  99. tight space grinding???
  100. JRSC touch-up
  101. possible gas issue, need insight.
  102. Ls1-6 intake flange
  103. Wheel polisher
  104. 38mm Dump Tube pipe
  105. Some handrail pics
  106. miller diversion 165, is it good enough??
  107. first aluminum welding in 7 years or so...
  108. Jeff Jones FD3S Formula-D car build
  109. Evo/Sti brakes on honda/acura
  110. Where to buy/make?
  111. Anodizing my radiator
  112. Subaru EL header (not mine)
  113. Downpipe fab question
  114. CRX turbo build
  115. Recomendations for a bead blaster??
  116. Anyone make a good DSM 1st Gen talon Eclipse manifold?
  117. Rotors
  118. welding 'booth'?
  119. V band flange w/ taper vs flat.
  120. Oval intake runner tube
  121. where to buy 3 in. SS piping for downpipes?
  122. wp-20 torch body
  123. sheet metal roller
  124. AFI Turbo coming back from the off season...
  125. Looking for an srt4 exhaust flange
  126. What welder are you using to weld valve cover fittings?
  127. want to replace my welder to a ac dc one,
  128. autobahn88 bead roller, anyone tryed it?
  129. Mig welders ** Which one should I buy
  130. HOW TO WELD A CORE SUPPORT
  131. Exhaust turbine housing alloy, ok to weld?
  132. Can anyone with a CNC provide me a quote (part pics inside)
  133. anyone recomend a good tig machine for the average joe
  134. anybody here make this mani??
  135. jb weld v.cover
  136. Need some CAD/Engineering work done.
  137. Holes where seats should bolt in
  138. Welding sump on ribbed fuel tank
  139. welding tools
  140. Sumping A tank and not kiling your self?
  141. catch can built in mild steel, how thick ?
  142. buying used oxy/actylene torch setup
  143. Quality measuring devices.
  144. Why do my welds turn out like this?
  145. (Header Fabricators chime in) Need some help TIG welding 18ga tube
  146. Advice on building a header
  147. hobart EZ Tig 165
  148. weldingaluminum and SS with a MIG welder. advice needed
  149. Back Purging, How do you do it?
  150. Side Exit Heat shields?
  151. crack in the back of rim
  152. mig welding vertical, best direction of travel?
  153. Advice on what welder to buy.
  154. SU Baja: Welding 304SS
  155. Bad tungsten? having a weird issue...help?
  156. Full-Race R14... getting updates
  157. water to air aluminum ice reservoir, what do to for lid/cap?
  158. b16a2 flange
  159. airbox top i finally made
  160. when to back purge?
  161. what is the right way to weld a header?
  162. B-series tranny cable shifter conversion?
  163. TIG alum bead has rough texture
  164. Oh Noez, It's That Time Of Year Again
  165. Help me identify my mystery filler rod.
  166. what to use to polish stainless steel manifold?
  167. rack and pinion fab?
  168. spool guns?
  169. 2jzgte dragster project
  170. RMS t6 single turbo diesel mani done!
  171. Some stuff i've been working on [CAD]
  172. looking for 60mm elbow
  173. making closed deck b16 block?
  174. what tool(s) should i use to cut this? [4130]
  175. What do you use to cut holes in piping ? ( Exhaust fab - dumptube routing - o2 bung )
  176. sheet metal intake manofild?
  177. Vise "restoration" pics
  178. electricians i need some advice on my diversion 165
  179. Squarewave vs. Non-Squarewave??
  180. Wire tuck questions please help!!
  181. advice on this ramhorn manifold!!!
  182. Adapter Plate Midwest
  183. Fab/Mechanic Shop in or near Miami,FL
  184. Woodworking fab - desk project.
  185. Newbie Tig question?
  186. what would you do?
  187. skid plate for header
  188. Welding table project pics
  189. Eye/Face Protection, What do you use?
  190. Dual Purpose Bender
  191. "Channel" steel for suspension pieces
  192. Quite the baffling problem.
  193. in search for a CNC machine shop
  194. Taking a tig 6g test, tips?
  195. Meet the Avalanche. Aluminum+TIG+Skate meets Snow
  196. help! ideas on what to fab. with sheet metal
  197. question for dynasty 350/700 users
  198. Help with gas lens
  199. need cad drawing please, will pay if needed
  200. custom diffusors?
  201. canadian fabricators
  202. RMS fab turbo diesel v8 manifold
  203. radiator mods
  204. HF welder to weld quarter panels?
  205. Building a work table(FIRST TIME)
  206. NoN HONDA BUILD :) PEUGEOT 106 GTI
  207. TT LSx Camaro build(TONS of pics)
  208. Shop Phone Systems - What are you using?
  209. Advice working with polyurethane liquid
  210. Mandrel Bend?
  211. The coolest tube bender ever!
  212. hayabusa itb's can some1 fabricate these 2 fit a h22?
  213. Drag car project I've been working on.
  214. B16 EF shift linkage
  215. Hello from down under (non-honda warning ) lol
  216. Has anyone used S2metalwerks?
  217. Blog I made for Welding & Fabrication Projects
  218. Always feels good when this happens...
  219. ef coupe, like 2 doors and a trunk
  220. conductive or non conductive footwear for welding?
  221. sidecar race bike swingarm and my homemade bead roller
  222. bending aluminum round bar, best way?
  223. '89 Ford pickup to 24v Cummins we are finishing up, lots of pics
  224. ariel atom wanna be
  225. EG Dash swap
  226. Nissan CA18 exhaust head flange
  227. >*MIG WELDING Noob PUSH OR PULL?????
  228. 91civic front frame cut
  229. Anyone willing to CNC an intake flange?
  230. the shop...from the ground up.
  231. Stainless machine speed?? help
  232. requesting pics/info on custom diy motor mounts
  233. Need a 6 to 1 T3 merge collector
  234. Strut Tower CAD Drawings
  235. Need Help Picking out CNC Machine
  236. Long mornings ... Longer days .. short nights
  237. 89EFhatch- How I pay bills
  238. Home made spot welder?? can it be done?
  239. rear diffuser
  240. 110 welder question
  241. is it ok to use chop saw for cutting alu and mild pipe?
  242. Sparkplug cover
  243. Post You Painless or re-engineered wiring
  244. 1.75" aluminum pipe donut
  245. A very non Honda header/build up
  246. Help modifying valve cover
  247. defective blades latley?
  248. welding help needed! look here
  249. What is "schedule" metal?
  250. Tips on welding a cracked block
