PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
  1. help me pick my first (TIG) welder!
  2. is this a good welder for my frist one?
  3. Dye & Penetrant
  4. Home Renovations/Add-On's How To:?
  5. No more warped flanges... thanks Tony.
  6. cutting collectors
  7. Motor swap fab question
  8. Sand Rail Shift Linkage? Rear engine D series fabrication ideas
  9. swain tech coating?
  10. Those who use heim joints on manifolds....
  11. Welding counterweights to a half counterweighted crankshaft
  12. What tungsten are you using for AL IC piping?
  13. Valve cover vents - What's the best way to measure exactly?
  14. Does anyone kno where i can get a front clip put on at
  15. Tin Work,
  16. Help i bought a eg6 with a custom sunroof
  17. "hole" type mounts
  18. Can anyone make a AC/PS comp. turbo manifold w/new tial housing. Reciculated dump too.
  19. my out mount header
  20. are you guys using respirators when you weld?
  21. who can CNC a custom shop press die?
  22. my semi custom slash cheep catch can
  23. Show me your custom made Intercoolers :)
  24. First attempts - collector, pipe to pipe, pipe to plate
  25. running belt driven accessories off of the rear diff (alternator, power steering, etc.
  26. who sells exhaust reducers 2.25" to 3"
  27. Nice piece of fabricating (McBearen/Mclaren)
  28. Where to buy ball and socket type exhaust flange?
  29. Fuel system question, priming possible?e
  30. Where to buy - 1/8" NPTF aluminum weld bung?
  31. welding Cast Iron.
  32. Hytech Exhaust Customer Service
  33. WANTED asap: Someone who does fiberglass interior work in Los Angeles
  34. Fabrication This Week @ SLS
  35. Metal Cutting Saw Blade Help!
  36. Buy an old ENCO mill?
  37. question about copying my custom manifold dimensions.
  38. ok so i finally finished the itb's all the way
  39. Where to get rolled edge flat aluminum bars?
  40. Intercooler ducting+my top mount
  41. E36 M3 head flange needed
  42. rather high flow cool looking 40 buck manifold setup
  43. Recent fab
  44. Somethin a lil different....Ultimate beach radio
  45. anyone know where i can get this dvi plug?
  46. anyone use acetone in a spray bottle?
  47. What are license plates made of?
  48. Need a 3" mild steel donut yesterday
  49. Trunk Lid Fabricating
  50. Fabbing Manual cutout for 3" downpipe
  51. Need help putting a sump on the tank
  52. Exhaust tip (help!)
  53. vTec Engine
  54. Forming round runners to oval port?
  55. Soco bender?
  56. SOHC TRI-Y? WTF help me identify?
  57. Need lot's of help with MIG welding.
  58. Whats the best method to really make stainless el's look good?
  59. SLS Rotary Action
  60. Welding to compressor housing?
  61. Who sells 1.5'' flex couplers commonly used in wastegate re-routing?
  62. Aluminum sheet metal for intake plenum. What kind?
  63. Looking to buy a decent Mig that will do 1/4"+ steel..
  64. DIY Z6 manifold
  65. im new and trying to learn
  66. how often do you change your gas lense?
  67. cutting aluminum piping, cheapest way?
  68. How long is tig welding wire/filler
  69. True Skillz
  70. mac mig welder
  71. Is this a decent welder??
  72. can you weld this???
  73. How thick of Steel should I use for the top of my welding table
  74. Some roll cage work...
  75. cambell hausfeld welders any good for doing body work/sheet metal?
  76. 220 Wiring Question
  77. 2JZ Powerglide Trans Adaptor
  78. V-banded Collector
  79. Body work??
  80. Header question (Custom angle)
  81. Calling Welders/Benders in/near Jax, FL
  82. Aluminum Head welding in Northern Virginia Needed!
  83. polyurethane
  84. Cracked ITR head. Can it be welded?
  85. Is this welder good enough?
  86. Precision Tig 185 alum. trouble
  87. Aluminum downpipe?
  88. Who can rework the LED lights in a instrument cluster
  89. Problem with CRX
  90. Roll cage bolt in ends...where to find????
  91. 1950 Chrysler with a Duramax swap
  92. I got a new job.
  93. Pedal assembly fab
  94. Bending thin wall chromoly
  95. t4 twin scroll flange???
  96. 1.6 for B16A Swap in 97 civic si
  97. for all u guys that did ur diy itbs help me out
  98. top mount with a/c
  99. Problems fitting precision 440cc injectors ?
  100. What do you use to cut pipe?
  101. Collectors for the new Tial stainless turbine housings?
  102. Tony1 comes clean about supporting OBX? Chinese fabrication FTW?
  103. Intake flange request/quote
  104. Integra trans question
  105. Carbon Fiber Hatch
  106. New composite pieces I built for a customer
  107. Aluminum tig welding.....
  108. looking for some rsx side mount turbo manifold pictures, and undercut or not
  109. Honda's with Targa tops? T-Tops?
  110. omfg i broke an allen head screw...
  111. 95 civic disc brake conversion
  112. where can i have something like this made?
  113. Can anyone help me out? OC, Irvine, CA area... Chassis welding...
  114. Turbo collectors 4-2-1 need info
  115. Who got the New Honda Tuning Mag. in the mail?
  116. rust repair
  117. Is This Easy To Cut/Weld?
  118. Offset Aluminum Pipe
  119. FJ custom headers
  120. Whats the standard size Argon bottle for tig
  121. Would this downpipe brace be a bad idea?
  122. Some pics of my fab table I just made at work...
  123. DOES ANYBODY KNOW SOME THAT DOES RIGHT HAND COVERSION'S FOR CHEAP?
  124. welded water pump on back of ls motor
  125. i need a megaphone welded to my header
  126. SLS 2JZGE Fun
  127. for people using chop saws to make collectors please help
  128. welding certificate and education. lets talk about it.
  129. E71T-11 on stainless steel?
  130. where to can I buy these
  131. Straight Line Specialties CNC spark plug cover
  132. A little tig help please
  133. Which to get? Harbor freight tig welder or Smiley welder..
  134. Making extension cord out of 3 prong dryer cord & plug
  135. CNC motor plates for tubed S2K
  136. go kart
  137. go kart
  138. RMS final b series t3 design
  139. Composites Forum??
  140. How is this guy's welds?
  141. 91 Civic HB (ED6). I would like to see some pics of some underhood fuel cells to see how they are mo
  142. Dynasty 200 be used with dryer plug/outlet? ETC
  143. advice on drilling / machining downpipe for dumptube
  144. New to wleding, welder for making downpipe/exhaust?
  145. WaterJet Cutting pics
  146. EG with Cantilever suspension
  147. CNC Mills
  148. ramhorn pipe size?
  149. Quarter panel replacement
  150. Opinion on Drill Press
  151. Rollcage
  152. mitsu evo 9 steering wheel into EK?
  153. Lift Installation ??'s
  154. 1989 RB20 skyline, auto
  155. 10# spool vs 1# spool, weld wire?
  156. 1.75" mandrel bends...schedule 40 stainless
  157. Where to buy T3 Collector Ram Horn
  158. rear METAL bumper diffuser ?
  159. welding thin aluminum
  160. pic request for 99-00 civics with rollcages
  161. Quarter panel skin
  162. Interview for welding position: How to dress?
  163. Speedglas 9000F hood issues
  164. miller syncrowave 200 for home use
  165. Is this flange too complicated for CNC?
  166. how do you get the weld color consistant?
  167. what is a decent, affordable welder for doing headers, manifolds, exhausts?
  168. How to setup the wire feeder?
  169. welding a radiator support anyone?
  170. seat rails
  171. Metal Nibbler
  172. Rhode Island area fabricator
  173. Military Dog Tags
  174. new catch pan
  175. flanges
  176. Traction bar questions
  177. Anyone have any Vibrant alum mandrel bends?
  178. i made a drill press stand now
  179. Mig welder not welding right
  180. Aluminum Tubes?
  181. Could I make with parts from home depot (picture) My steering rack line is bent.
  182. ITR muff delete
  183. T3 manifold to T4?
  184. Guys with The lincoln PT 185 or PT225 What torche heads you get and were
  185. Wierd request. Looking for an exhaust part
  186. anyone know where GeeGee is?
  187. how could i make intecooler piping 4 my crx (D series)
  188. Where are QA1 heim joints manufactured?
  189. Grey Welds with SS and only 40 amps on the tig
  190. Help me choose between two dynasty welders 200 dx
  191. What setting do you guys use on your tig for alum piping ?
  192. before welding on a car
  193. 220 power supply
  194. Need help with tig welding
  195. Question for those who know about Heim joints used for turbo bracing....
  196. what equipment is needed to get started?
  197. Welding in tight spots ie collectors
  198. Need to know where to buy radiator/reservoir neck and cap
  199. Will anyone send a vw 16v header flange to England
  200. help please i only have until 4:30 or 5:00!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  201. please help i only have until 4:30/5:00!!!!!!!!!!!!!!!!!!!!!!!!!!
  202. MIGin the body
  203. Header flange thickness
  204. Making a 3" downpipe, what kind of piping?
  205. Aluminum radiator piping?
  206. muffler shops in ct?
  207. CNC/Fabrication Photoshoot
  208. Exhaust welding
  209. welding powdercoated or painted pipes....?
  210. Looking for supplier of specific exhaust flange
  211. Air Intake
  212. Vband flange
  213. need turbine inlet flange for k03
  214. del sol roll cage
  215. B18a intake manifold flanges?
  216. Welding and shaving engine bay
  217. turbo manifold kits???
  218. got my first welder
  219. added a few bars to my cage
  220. Looking for an old thread where a car from the ground up.
  221. Anyone want something drawn in Solidworks for free?
  222. leveling out a warped flange???
  223. Replacement Pump(s) For Miller Tig Coolers
  224. Advanced welding courses
  225. Some stuff ive made. intakemanifolds, turbomanifolds and some wiering
  226. Porsche 993; something a little differant... 56k-no no
  227. tac weld..trying to remove stripped plug on motor ?'s
  228. new turbo sandrail video compilation
  229. what floor jack do you guys use/recommend?
  230. can you weld different metals together?
  231. *urgent* do i need feeding wire?
  232. using flux core to weld 16ga mild steel piping?
  233. Welding mask is UV 16(DIN) ok ?
  234. Tig Stainless to CS body panel?
  235. sandrail fabrication & shop tour **56k warning 76 pictures**
  236. Turbo manifold question.
  237. side molding
  238. Pic request! NSX Intercoolers
  239. Sheet metal source??
  240. Carbon Fiber Hoods for 1995 Honda Civic
  241. tubing vs. piping
  242. should i use these parts for mani???
  243. made a bench grinder stand
  244. Sch. 40 stainless weld 90's
  245. Toyota AE111 20V Individual throttle bodies
  246. Little project of mine
  247. welding magnesium to aluminum
  248. Hot tank or press wash?
  249. Upper Radiator Pipes (Good / Bad) Stainless or Aluminum?
  250. What a common size for thread tapper & vacuum logs?
