View Full Version : Welding / Fabrication
- Where can i get one of these??
- Homemade Press Brake: advice needed
- easy question, possible stupid question
- Newb Mig Content & Miata mani/dp build
- Welders! I need advice!
- port spacing(F,H,D,B)
- My first pic thread
- Horizontal band saw blade ?'s
- CTD-Fab's Metal Art/Sculpture Megathread
- where can i find engineering info?
- ls rods in d16
- Expensive header surface rusting issue's
- mig welding with 100% argon
- Quick question about mufflers
- any electritians or 20" disc sander owners here?
- who can build this...
- Anyone using or have used the HTP inverting 201
- Rusting problem with steel stock
- post your best woodwork
- Cutting Reliefs on Head Flange
- What causes welds to crack like this?
- What Gas for welding stainless wit a Mig
- fab me a turbo manifold/DP/DT for ........ Not a honda!
- 4wd civic evolution
- Best type of steel to support rear mounted subframe
- Oxygen/Acetylene Tanks EXPLOSION!
- Anyone up for some steel work? (CNC Plasma or similar)
- Need help on how to approach my situation
- j series adapter plates
- Q45 TB Question
- Intercooler end tank design
- Remving gobs of JB Weld from clutch case and correctly fixing it
- Table saw and cutting aluminum
- OPEN slate fabrication. Crx body. FWD V8? Rear engine V6? Throw ideas at me
- modified crv AWD trans?
- Got this baby back from powder coat today and had to show her off!
- widened wheels
- VW hot rod fiberglass one piece front end
- New toy for my welder.
- Fab tools you can't live without/love/wish you had
- Aluminum TIG Issues
- Redzone Performance- TSX custom cooling shroud setup
- F-body LS1 turbo headers
- inhaling metal dust daily.....
- noob to REAL welding
- Suggestions on cutting 1/8-1/4" sheet at home on a budget
- DIY OEM light weight H22 Flywheel (CNC)
- Quality tube transitions
- welding shortshifter
- Vertical Band Saw
- welding muffler hangers
- Bare Essentials
- Titanium manifold mounted on car
- stripped tenshioner bolt
- D16 "Quick spool" manifold ....
- Source for 1.5" Mild steel weld els?
- Machine work (and a little non vtec love)
- LS1 Rx7 Long tubes
- Is it dangerous to let your compressed gas tank get below freezing?
- has anyone made a dual diaphragm pressure plate using stock parts (B series)
- Custom oil cooler cores
- 2 motors one civic
- what do you do when you build something in good faith, but no payment?
- J swapped..... Sandrail project!
- anyone using this welder
- Turbo diesel project I NEED HT.COM HELP
- something different, bike swingarm brace
- OEM Location Fuel Cell
- Where to buy mandrel bent manifold piping?
- quite exhaust in a diffrent way.
- Flange PDF
- 308>316 or 308<316??? opinions?
- how fast do you guys go through argon?
- Sandblast guns???
- keep the butchering to a minimum... my flux-cored welds.
- What "welding" stuff do you use ?
- oil pan baffle
- Bobcad V23 Anybody?
- S2000 Pink Exhaust
- clear coat saned carbon fiber?
- Post your MIG Stainless Steel SS welds.
- 96-00 civic truck...?
- ITB Manifold
- 70mm exhaust...modify help
- Some Recent Work @ MaseEngineering
- which safty shoes do you guys know of?
- roll cage
- Half Dozen Miniature Copper Roses (Non-Honda Related)
- Looking for input on if this would be strong enough
- Education?
- Custom length shift cable source ??
- Oil Pan gasket question???
- Flux core/Mig/TIG for Turbo manifold/downpipe
- Roll Cage help
- wanting see what you guys think
- I wish I could take credit for this one....
- what is Carburizing?
- Need Custom Exhaust
- manifold cracked..
- 12V VR6 Intake Manifold Project
- fabricating a steering pin. EN24T?
- another pie cut question
- Any opinion's or compariable's against the Miller Dynasty 200 or 350?
- Welding and Art/furniture
- Been Busy...
- my first fabrication (dsm)
- Material Selection for Intake
- Custom radiator
- GSX-R Intake manifold....your thoughts please
- has anyone taken a co-op student?
- Custom b-series headlight mount turbo manifold
- Exhaust help
- Protection after welding question
- FINALLY!!! Titanium turbo manifold pics
- Help.. Need advice on a band saw purchase!
- Hey everyone.
- Any experiences with stainlessheaders.com?
- Dual stage intake manifold...butterflies, rotary valves, etc.
- looking for a catch can
- primary larger than flange
- Need help finding old door bar picture
- Built LS/Vtec Turbo Kia Sephia
- RHD conversion help needed
- Where to get M14 -> M12 Step Stud
- Welding spoiler holes?
- Fab'n EF front end mounts.
- Deist parachute release handle fab help... :)
- How should I make this? CNC Endmill? (Nonhonda)
- any aluminium welder, need 1 weld done... needed in socal local only
- Oxy/Acetylene Welded a Couple of Aluminum Exhausts
- Acuretly indexing bends
- ASK : Twin Scroll Exhaust Manifold Pairing??? Papadakis exhaust strange..
- Where to get radiator cores?
- Need info on older mig welder.
- Low Profile V bands
- Hydraulic Question
- Free racecar chassis design book
- any one here uses a parts tumbler ?
- solidworks 08 .dwg not to scale in autocad 2010, program to convert it?
- What material are most ATV axles made of?
- accord intake manifold
- Milling/CNC a v-band flange out of a T3 flange?
- 16g turbo flange manifold for b16
- Welding on something that used to hold gasoline???
- HKS Blow off valve Flanges *Everyone Read*
- Where to buy 15 degree prebent tubing
- where to buy Bead Roller Mandrels?
- who make cast\cnc collectors besides z10?
- Zirconia Sanding Belts
- Really weird topic, but please help, i'm miserable.
- Aluminum Tube Pressure Rating
- newb here. some of my work....
- Why do my ss welds not have color?
- Not Honda related but....
- dynasty 350 or sync 350?
- welding runners to eachother
- Any good exhaust shops in the east bay?
- Place to find 3.5'' or 4'' intake piping?
- short turn radius butt weld fittings
- ATP or Vibrant for piping and flanges?
- is this right for getting a DP made?
- Oil cooler manifold for K24
- converting a HF machine to use a switch?
- tips and tricks
- welder/torch woes...
- Finally getting some room to work!
- Where can i get a piece of pipe in a T like this?
- Who can sell me B18 and T3/T4 flanges?
- What size sch 10 for a B series Turbo Manifold?
- Opinions on this Milling Machine?
- titanium turbo manifold
- fittings in the valve cover?
- metal rings for side exit/hood exit downpipes ?
- Hood latched ripped off (2002 Civic)
- make me a DP and DT??
- Something very useful?
- ASP K series scatter shield
- FD3S- LSX 454- 106mm Turbo- Spoolin Tubulars
- Welder needed
- Built an exhaust for an E60 M5 today
- Is this a good welder.
- S2000 Intake manifold
- Would some one make me some legitimate collectors PLEASE!!!
- where to find titanium bends?
- miter turn templates
- My new garage
- i need 5inch od or id stainless 90 degree
- hood dampeners
- molding dashboard?
- H22 Alternator Relocation (Please Help)
- 6061 vs 5052 aluminium
- My Intake.
- ATTN: Welders read this or you could DIE (for real)
- Milling machine for plastics (polyurethane)
- GSR/B16 Intake Manifold Fab.
- Lastest Fab Work
- Flaring piping question
- engine hoist plans
- Intake manifold and throttle body flanges ?
- Best Fabrication Pictures
- Need a builder...paypal ready
- MIG wire
- Does somebody here think this is possible
- Turbo mani material. Where to get it?
- since everyone is posting up their intake manifolds, here's one i did
- intake manifold project
- Some pics of our work at Full Blown Motorsports ***56k beware***
- Exhaust pipe kit
- My first manifold (2jz, no shit!)
- turbo heat shield
- Custom Cages
- Someone sell me 2 or 3.. 4to1 collectors
- decent welder
- Invertiweld machines?
- Manifold Turning Colors??? pic
- Some cool tube fabbing
- how can i make a skid plate for my header?
- SS Weld el suppliers
- pair of 4AGE toyota headers
- Electrolysis. Rust removal. Tips?
- Making custom exhaust......tell me what you think
- pie cut formula
- Some of my SS welding
- 2007 Turbo Mustang
- need fabrication quote in socal
- Project 80cc Rascal
- Rubber Protection.
- anyone looking for a TIG in new england?
- where to buy 5" bends for downpipes et?
- ANYONE KNOW WHERE JESSE IS FROM AFI, OR IM IN SEARCH OF COMPANY WHO CAN FIX RAMHORN
- quick question about IC piping
- RamHorn Mani Need Input.
- civic core support
- So I just got a TIG: any suggestions for a beginner?
- Spec Miata Roll Cage
- Help regarding welding on a restoration project...
- DA+EF fuel pump covers? Looking for ideas/pics
- DIY blow off valve on the cheap
- da footrest?
- Rollcage for 24 hours of Lemons
- building some misc stuff outta " junk" around the shop
- EP3 exhaust fitment on other hondas...
- found some old project pics.
- Heat Exchanger Cores
- blocks needs to be helicoiled?
- V-Bands warping slightly after welding
- Clutch fork Renforcement
- valve cover painting?
- HELP!!! with custom single turbo exhaust setup
- These door bar kits legal?
