View Full Version : Welding / Fabrication
- welding cast steel
- surge tank??????
- note to self: alays grind metal wearing a face sheild
- chop saw blades???
- moving tubes on when fabbing turbo manifold
- Buying a metal lathe....
- Looking for different coolant reservoir *Search is down for me*
- where is a good place to get something anodized
- fuel cell for c-16
- Jb weld radiator question!!!
- Unimog Fuel Tank
- Post your best welds!!!!!!!
- harness bar?
- exhaust
- warped flange
- best way to weld a intercooler pipe .065
- Make EP3 seats lower
- Getting the most from PT225 on 1/4" AL
- where to buy a blank t4 flange?
- Need to weld 304 to mild steel... but no 309l filler?
- Using Solar Flux on a turbo manifold
- custom manifold
- Stolen: Red JDM Front Integra
- lincoln welder sp-135
- n00b Tig welder.....
- what happened to the worst fab thread?
- new welding table
- Made a new turbo kit, for my OWN car finally (S372R) (Pic intensive)
- Welding 304 with 316l filler?
- Will this main hoop pass nhra/ihra inspection?
- hows this weld?
- what u guys think about this welder
- gas for purging
- problem on 1992 accord tranny shifting
- Welding over a weld??
- welding the new tial mvs v band
- Tips/Advice...
- advice on hobart tigmate
- Making Hole Saws Last??
- sir-g fogs in a 98 front DC
- SS plate
- engine cradle
- SAE Baja 2010: Mig or Tig welder
- 3d printer. Check this thing out.
- Clear Nail Polish to Prevent Rust?
- FIRST TURBO EVER ! can i use this ?
- My Fab Project: 6g72 Powered Audi (Many Pics)
- intake manifold material
- some of my fab work
- my new catch can
- 4G63 In A Teggy
- WTB: welded rose
- Choices of fabrication welder
- F-body LS1 ac compatible turbo headers
- DA Turbo Piping
- What do you guys think of this mig?
- question about harbor freight
- Building Collectors w/ Chop Saw
- Fabricators! How long for a tubular manifold?
- Honda TRX450R +2.5" A-Arms
- custom flange?
- A brief timeline of my Camry TT build.. Lots and lots of pics
- fabbing some manifolds for my audi
- exhaust hangers..
- Mobile Tubing Bender!
- Left hand die or thread chaser?
- Plasma cutting gas
- b series intake runners
- ek rear diffuser
- Thought id share my latest.....
- Pirate 4x4 roll cage measuring guide ?
- bead form tool needed
- Damn Chinese Materials
- Cad files for header/turbo flanges.. get em here
- '67 Mini Cooper Header
- Questions on motorcycle engine swaps into cars
- jegster 8 pt roll bar request
- Crappy Fab Thread
- working on some turbo ls1 stuff
- what, welding maching would be best?
- RSX Seats, How Do I Get Them To Sit Lower
- Pipe size for stock H22 ports
- Looking for DYI exhaust fab kit('s)
- Intercooler End Tanks
- Gas Welded Aluminum Tubing
- Cheap 45* elbows, anyone?
- random
- Need help picking a smaller tig torch.
- harbor frieght 20% off single item cupon jan 30-feb2
- How to give metal tubing a burned look? (cool idea)
- Omni Adjustable Cat converter
- band saw
- Realtime 4wd Coupè
- new prostreet turbosystem
- Roll cage gusseting
- Welding Titanium
- Tipps for tapping stainless steel ??? anyone
- Is a hot side of turbine weldable?
- built another eclipse turbo manifold
- back purging
- Is college for welding worth it?
- Shielding Gas Always On
- fabbing up new ss mani for my drag car
- welder
- custom exhaust
- Relocating stock Integra Seats
- Welding road block
- Lincoln Invertec v155-s Anyone Actually Tried It?
- ef shift linkage
- My new welding table!
- Which do you prefer, AutoCAD or SolidWorks?
- I need a good So CAL FABRICATOR
- Welding 304SS exhaust piping what size tips and tung you use?
- hytech replica springs
- Suspesion Anyone??
- Finally picked up a tig for the shop...
- Filling Manifold Flange With Layers of Weld
- First Fab work...Manifold for my S2k
- ? for the pro fabers non honda
- chemical tungston sharpener
- Aluminum and Stainless
- Took a stab at the coke can thing ....
- Easy way to calculate equal length?
- Welding V-band to exhaust housing
- sumping gas tank, gotta ?
- Welding Education....
- post pics of your storage solutions
- ITR header
- Tube bender
- Can a Lincoln mig, weld alum?
- Help me decide which welder to get.
- Post pictures of your collector jigs.
- first time doing stainless tube
- quick ? roll cage ?
- Update around the UCF Racing shop.
- SS Alfa exhaust i did. Pic heavy
- ? for those with experience with titanium
- S2000 Test pipe 3 hole flange
- anyone made B-series tranny cable shifter conversion?
- header making?
- first TIG project
- filling a tube with sand, heating part to bend, then bending??
- Mandrel Bending: Who?
- RMS b series vband manifold
- Sch 10 vs. Sch 40 for manifold
- Should i pull the trigger on a Miller Syncrowave 250DX
- teaching someone to tig how much to charge
- Tips for cleaning aluminum welds?!?!
- spot welded extra metal on strut towers help please!
- Question about filler wire and strength
- Buying a tig welder???
- Tips for welding thick AL
- what filler rod for chromoly cage
- shaving engine bay need help!!!
- What to do with newer civic drivetrain?
- 2008 Projects In Review
- Where to purchase maf flanges
- 4" header pipe extension?
- crx trike???
- Removing sunroof, need advice on metals/welding
- Home made plasma cutter
- Request: Pictures of your work done by a syncrowave200 machine?
- Upright shop vacuums... what do you reccomend?
- diff. between air to air and air to water cores
- ls vtec catch can and 3 inch downpipe
- b series top mount mani
- Building a Tire purger/filler
- mr. rpmwelding : anyone ever used their service?
- Re Surfacing steel?
- Cage builders, in here please!
- Had anyone ever shipped a welder, if so what company?
- Looking for someone to make me 3-1 Merge Collectors for turbo car
- Engine Bay Shave - How long did it take you?
- got a gas tank for cheap. needs repair how can i repair it?
- Mig Weld SS ??
- Decent Price For Used Miller Sidekick
- dc2 4 into 1 header
- no high frequency on my dinosaur
- Anybody know the name of this part?
- My Fab Table
- my little welding table for my tig. what do you think?
- First time at TIG -- Need Help
- Striped LCA bolt
- Which is a stronger material for a manifold....
- Anyone have a thermal arc 185?
- Arc welding Aluminum?
- Just took up welding... looking for critiques/insight W/PICS
- Need advice concerning welds
- what welder to buy?
- what type of welder?
- H series EG turbo manifold
- Best Fabrication Pictures
- Shop Upgrade - Non-Honda
- (non honda fab) Subaru EWG
- post pics of your aluminum welds...
- what size tube for building a header?
- serious noob with ?'s
- pic request. syncro 200 runner
- shortening a shifter
- 4g63 swap in a del sol
- some pics project turbo kit ... ...
- some new welds.. critique me.
- cost to convert to v-band?
- Anyone make a 3" tial bov flange?
- Weldign certification
- hand built toyota 2000gt
- Noob TIG welder. day 3 what do you think?
- J Mandrel Bend Help
- Looking for the site...
- 60mm vband kit
- Horizontal bandsaw blades.
- Roll cage floor plates...Mig or Tig???
- pickling paste
- Cast weld question
- Opinions on which stainless for turbo mainifold?
- RMS vband manifold
- how to mount 4point harness on roll cage?
- Cusom fabricated exhaust
- Someone with skill to replace roof skin - needed -
- good/cheap tig welder
- Post up your Mig'd Roll cages... Tips welcomed as well
- Adjusting post flow on Sync200?
- My first catch can.
- J32A2 swap into 95 Civic Si
- roll cage in a eg !!!!!
- sch. 10 filler of choice?
- Some more Tig welds.... this time sch10
- Engineering school truss update( 1st place)
- need custom catch can made
- 1950 Chrysler with Duramax swap *Now with burnout vid*
- first tig welds... and theyre on aluminum
- welder questions...
- Billet Intake Manifold Flanges
- inside pipe weld..
- Is this a decent welder?
- What are your favorite chassis fabrication tools and equipment?
- trying to decide on welder
- Having Traction Bar Problems
- sumping gas tank, few Q's
- Needs some help with a Manifold that creeps......
- horisontal band saw---how helpful?
- Hobart Handeler?
- what type of welding
- thread repair?
- Need help with weld on frame/body
- Found a useful resource for new people
- help me choose a bandsaw
- Source for 64.5" Morse bandsaw blades?
- powdercoatiing oven = batch oven?
- Arc Welder?
