- Flattening warped flanges? (when torquing the bolts wont cut it)
- Anybody interested in helping me do a wire tuck?
- Inexpensive, reliable, compact band saw...
- Rust on my Full-Race Ceramic coated manifold. Curious?
- Cost and service of: Welding a flange onto a B pipe..
- good vs bad
- What type of fiberglass to use?
- where to buy turbo manifold supplies
- anyone ever make lexan "roll up" windows in a civic?
- Mandrel Benders in CT HELPPPP
- Colored carbon fiber?
- Opinions on Lincoln Weldpak 100
- Learning To weld Pictures
- carbon fiber parts??
- Anyone have experience with OLD Hobart or Miller Tig Welders?
- What to get with $3k welding budget for beginner?
- would this be an ok tool?
- Shaving Door Handles
- Intake Manifold? Design considertations + math
- Couple of fiberglass quetions...
- Welding in a 8 point cage in a Ek Hatch
- What's the best looking beads fluxcore can do?
- Flange thickness
- h22 engine mount options? (in a prelude)
- Is there any tig's that can run off 120 and do aluminum?
- Need a roll cage made.
- Another which one...Lincoln pro mig 140 or hobart handler 140?
- Mig Welder... Clarke or Hobart?
- Cutting Stainless Steel schedule 40 Weld Els? Chop saw or band saw?
- progress so far (scion tc intake)
- Ever built a engine stand? can you share the blueprints ?
- Need help setting on this welder
- Affordable way to covert 2" compressor outlet to 2.5" 90? Ideas.
- Question On Plug Preparation (Mold making)...
- Custom Electric Power Steering onto EK chassis Electric Motor fab??
- help me make a header!
- i could use some help from you guys
- carbon fiber exhaust system???
- SOUTHERN CALIFORNIA: Looking for someone CNC
- intercooler project
- NEW JERSEY: can't find scrap metal to practice welding
- Solid Works Model -> Machined parts
- spot welding and subframe repair
- A good place that can cut flanges?
- Made a new plenum for my ITB's
- My 6 point rollcage.....
- Does anyone have the Bend Tech software ?
- Angle Grinders
- Any good TIG welders in Orlando?
- New Aluminum Pics
- H22A Valve Cover - Anyone ever grind off the rivits for the breather system?
- plate for the climate control on ek dashboard...
- Kicker panel fabrication...
- S2000 4" Downpipe pics :)
- Northern Virginia Welding classes? Where to go for hobbyist?
- external oil sump- rear mounted turbo
- Is there a simple way to assess if you need more argon flow or not?
- So, I TIG welded some mild steel to some stainless
- what kind of resin to put onto cf
- Divided housing turbo manifold design
- how to measure kW out of welder
- Problems with vibration/resonance on custom exhausts i've built.....
- JB weld didnt work...tranny
- weirRacing homemade VELOCITY STACKS
- Where to get wire covering?
- looking for a little help
- Spec II
- custom air to air intercooler
- Something that frustrates me.. HOW.
- Free bandsaw - Must pick up in Phoenix, AZ
- list of materials for custom exhaust
- Has anybody ever heard of or tried Lab-Metal?
- Question about welding. Please help.
- Rate my welds. Give pointers. Please.
- new manifold finished, what do you think.
- Which bender
- What gloves are you using to weld ?
- Math Skills
- Broken Manifold - what can cause this?
- Whoever uses a Miller Econotig or has info on it Enter here....
- Stolen Items - Please Look Out For Them
- Is it possible to buy a good quality new mig under $300 ?
- About to Buy a TIG need suggesttions on where to buy for the $MONEY$
- Fab work in New york
- Stitch Welding a DC2
- Lasik eye surgery and welding?
- Burns Stainless Inco Welding Deal thing AKA as stealing Casey's practice INCO scraps
- Feeler: Hobart Tigmate Welder for sale
- Optimal way transition from 2.5"-3"
- My modified valve covers for RB25
- How does your welding setup look? (Table/clamps/etc.)
- tranny mount bracket broke off....
- Need to disconnect battery for Welding on car?
- Recent welding pics from work
- stick welder on car alternator
- If you had access to a laser cutter...what would you make to sell?
- premade sheet metal
- ? v-band clamps for turbo entry?
- Porsche calipers finally!
- First time w/ Stainless Steel.... TIG.
- which goes on first? etch primer or filler?
- What AC Frequency and balance do you typically run?
- How do you clean up a weld in a tight area where you cannot fit a grinder?
- Synchrowave 180sd for sale 500 bucks
- How to make a braided line?
- someone had requested FCAW pics for a welding thread.
- Iam on market for Air Compressor.
- velocity stack??????
- how would you make a downpipe for this flange
- Pipe gauge chart
- how much should this cost??
- welding prices??
- Question About Tapping
- Wire comes out very curved on my Mig and makes it hard to stay consistent!
- Welding Inconel tubing
- welding class in CT. help
- got bored and made this........thing.
- What tubing benders do you use? what was the cost?
- Which Mig welder for aluminum tubing?
- More Flux Core Fun
- UPS cracked my JDM ITR 4-1 header... can it be fixed?
- How to? Custom fiberglass interior panels and sub boxes
- Cutting Exhaust Tip
- Home made cold air box/shield
- Pricing to get bolts extracted and perhaps rethreaded
- where to buy green volk wheels
- Miller people- Does this sound like a good deal?
- Wanna fab me a bracket?
- Pic request: 7 bolt turbo downpipe flange.
- Chrome plating temps
- Opinions - Suggestions Tranny mounts? K series related...
- my tig weld pipes
- where can i find a 3" v-band
- Precision TIG 185 or Syncrowave 180 SD? Help me decide
- welding a t25 flange onto a t3 downpipe
- constructive criticism on a couple of my latest manis..... ramhorn and a/c compatible design of my
- WTB: CNC intake manifold plate for h22
- New to welding?
- How To: Wiring for your 240v welder
- Mini-Dirtbike rear axle stand
- Can someone cut me something out of billet or similar, (non car related) could be fun.
- Decent welder to buy for a beginner???
- what kind of welding is used for titanium welding???
- tips for drillning squarely
- molding a rare part
- Electric problems after having exhaust welded
- custom oil cooler
- welding a 3 piece strut bar
- Welding Schools in around NYC?
- Anyone made or feel like making a manifold for 4g63
- cool looking safety glasses...
- Sch 40 Weld Fittings Fitup Problems
- yet another ;) my first down pipe and exhaust.....
- Where to buy exhaust gasket material by the sheet?
- another "My first downpipe" DIY thread.... :) For an H22A in a CRX.
- Can someoen help with buying Gas Lens parts for my TIG?
- battery location
- steel intake manifold, sheet..... anybody made one?
- need mandrel bends for header
- sandblasters!
- new trq mount design
- Quater panel help
- question for the DIY manifolders.....
- welding exhaust?
- WTB/Where to buy: RHD EG Conversion
- some F1 fab stuff
- JB weld...fix hairline crack...?
- dumb ? do you wear an apron in the shop?
- Which or the 2 welders are better?
- Where do you guys get your wiring supplies from online?
- Preparing to unweld my radiator. What do I need?
- cracked fiberglass bumber
- Can someone TIG up an aluminum battery box??
- need a steel intake manifold flange....for d-series
- Header help.
- Who can make me two....
- Where is L-CON?
- where should i go to get my DC header customized for a 2.5 collector.
- Safe to weld traction bar on?
- 2.5" collector to 3" exhaust addapter?
- Has anyone ever turbo'd a pocket rocket?
- muffler
- anyone have detailed pics of itb's
- carbon fiber
- radiator support needed?
- Searched... i need some help.
- bender for role cage
- Comments on Mig welds wanted :)
- omni power test pipe
- Anyone ever Unweld or weld an Integra Radiator Support? JDM or USDM.
- Econotig or Syncrowave180Sd on a budget?
- Who can make a custom distributor cap?
- North Cali Mandrel Bender
- Fu*k me....
- Someone make this for me...Surge tank
- automotive engineering schools
- Testing for leaks on practice exhaust welds
- A thread on turbobricks.com about making a mani from scratch.
- i need pics of custom made turbo manifold for a h22
- Question about a Chicago Mig welder (gasless)... im in the market for a welder
- Short runner intake manifold supplies.....
- Autobody pro's: Need help measuring bwm frame
- First welds ever. any pointers?
- major problems with cracking studs w/nuts on welded stainless manifolds
- Best TIG welder?
- My First Gasless Mig Welds. What Am I Doing Wrong?
- Good digital micrometer or caliper (search is down).
- Inconel 625 and turbo manifolds (as well as general toughts)
- NEED ALL THE PROFESSIONAL AND WELDERS OPINON.........
- Learning To Weld. What Are Some Good Reads? Links?
- Pipe Bender
- I have transformed a Chevy S-10 into a beast!
- Need a 8 station welder.
- Welding Questions
- 16ga. for turbo mani?
- help .... with relocation of brake lines ....
- SOHC turbo pic
- post up your roll cage
- just some stuff i been working on ...
- silly project
- Please Help Suggest Welding Project for School
- can you weld a turbo manifold with a mig/ wire feed welder?
- Should I buy this TIG machine? any advice would be greatly appreciated
- can anyone in SOCAL weld a flange on to a pipe for me
- 300ZX Front mount ic pics
- WELDER: Need Help On Purchasing. Tell me if these will do or not, and which is best. *LIST*
- Underbody sealer removal
- oil drain
- Newbie TIG welds!
- Who can bend and weld?????
- possible to mig on a dsm side mount intercooler
- where to get a used TIG machine?
- Tooo damn funny!
- exhaust header repair
- Individual Throttle Body Intake Manifold
- where to get tial 44mm wastegate and dumptube flanges
- Flux core welds suck
- Thinking of welding over this this part due to coolant leakage...
- Sparco Steering Wheel Hub
- Roll Cage Fabrication in California?
- stripped thread on squirters!! (block)
- Backpurging...how important?
- what size are you running for runners on a turbo maifold?
- exhaust question
- Fabbing an exhaust cutout w/ a throttle body
- Air Compressor for automotive work
- TIG torch water cooler?
- ITBs - braking problem
- Transmission Clutch Lever Modification?
- FS: ESAB MIGMASTER250 Wire feed/spoolgun/mig welder/gas
