PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
  1. WELDING IN CAGE?
  2. DGR Fabrication in NorCal - Any advice?
  3. Who wants to help me make a CAD model?
  4. VW Golf 2000cc 4-cylinder header.
  5. Exhaust Welding Cost ?
  6. Machining my own piston
  7. Cutting out roof
  8. Bracket fab - weldon pump
  9. t3 to t4 adapter ?
  10. Silver soldering....anyone hear of this?? Not plumbers solder!!!
  11. Aluminum Slot Clevis?
  12. Lincoln Precision Tig 225 VS. Syncrowave 200
  13. Time for a new welding hood....Miller Elite vs. Speedglas....also who uses magnification??
  14. Can a dremel cut through... strut "feet", and a coil spring?
  15. 90-93 integra spare tire area fuel cell? What fuel cell have you used?
  16. Finished Custom Int. Endtanks
  17. time for a new tig welder
  18. How important is it to level an engine off when retrofitting it ?
  19. Floor Board Replacement
  20. Using a Lincoln Electric Power Mig 255 next week, could use some quick pointers please.
  21. MMW 6 Link set up
  22. Question about this manifold
  23. what is a good air cooled tig torch?
  24. made an exhaust
  25. welding lower control arms
  26. where to buy baffles for a catch can
  27. What kind of material you guys using to make collectors?
  28. Anyone know a Aluminum Radiator Core Supplier in the NW? If not where?
  29. where to buy V-band clamps for 1.5" and 1.75" tubes?
  30. Welding aluminum?
  31. type r braket
  32. Samarium Cobalt Magnet Distributors?
  33. Fabricator needed.
  34. Prelude 4094R custom manifold
  35. How long do tungstens usually last?
  36. Heres a pic of the wire form of our coach built car
  37. Fabricator needed
  38. Hydrodynamic SS Buggy Build
  39. are these elbow's good for a manifold?
  40. 1st ramhorn build...
  41. my first manifold, criticism welcome
  42. tubing vs piping
  43. proper bung size for radiator fan switch?
  44. Steel version of the threaded part?
  45. Fabbed up a CRX topmount with a 4" DP for a HT member...
  46. Need some helpful tips or suggestion on welding in this Chrome moly strut bar.
  47. Best place for speedglas lenses
  48. vented valve cover in bay area?
  49. Flywheel adapter for a K24a2?
  50. Trying to gain some oil drain height at mini-ram price...implement a Neukin collector in a diff way
  51. welding mild steel to aluminuized steel tubing??
  52. Just some Kevlar stuff
  53. Another Tial v band manifold we made
  54. Worst Fabrication Pictures
  55. 309 rod for welding mild steel?
  56. Some people should retire as a fabricator...
  57. Learning to weld
  58. EK rollbar into EG?
  59. Cad files exhaust flanges, wastegate flanges, turbo flanges.......
  60. Who Converts Stock Manifolds to fit ITBS (4AGE 20V)
  61. Catch Can Fab.
  62. 2dr cages
  63. Roll bar and swing out side bars
  64. building a cage in Portland...
  65. ITB's, wtf???
  66. my next manifold..in progress
  67. turbo placement while trying to make a manifold jig
  68. What are you using to bevel IC & exhaust tubing???
  69. What size tungstens are you guys using?
  70. What size torque wrench for engines?
  71. cheap ebay aluminum bends?
  72. What are your methods of shaping schedule 10?
  73. jdm front conversion..
  74. 90-93 integra
  75. kinds of welding mahine ?
  76. Structural aluminum tubing...anyone know of a good place to get it?
  77. angle guage for collector cutting
  78. Who manufactures this tool? I want one.
  79. Shop related accidents!?! PSA thread
  80. What do you use to grind your tungsten?
  81. aluminum or SS for i/c piping?
  82. harbor freight bandsaw is going to give me an ulcer, please help.
  83. Civic Tow Bar
  84. what i did w/ my blown engine
  85. Anyone welded 1/2" aluminum before?
  86. Need help picking out the right TIG for me
  87. Muffler Silencers universal?
  88. Welding tips for turbo housing
  89. Header I finished for a buddy.
  90. Question regarding Rollcage Welds
  91. Well, I figured I'd sharpen up my aluminum TIG skills...I got a few questions...
  92. h22 intake mani flange
  93. A few parts I made for Toyota 2000 GTs
  94. Need Info...Building a Turbo Mani...ASAP..
  95. Thermal Arc 185TSW
  96. a non honda header I built over the last 2 days
  97. i've been thinking bout this build for awhile...
  98. endtank design/efficiency
  99. Custom cage needed...
  100. suggestions on a good solder/desolder unit for chipping ecus
  101. pics of one of the headers I'm making for the prototype were building
  102. metal question?
  103. Can someone please help me figure out how to make a 2 to1 base collector
  104. Just another day @ spoolin
  105. Stainless steel welding
  106. Eastwood Electric bead roller? Anyone have experience?
  107. Stainless mig wire used as TIG filler?
  108. Has anyone ever used a voltage reducer for your welder outlet?
  109. Wiring up my 230v Mig.
  110. to all with a bead roller, wanna roll some?
  111. Metal Etching
  112. 115 or 230 mig?
  113. trailers and car haulers
  114. Fab'd up some Int. Endtanks today
  115. o-ringing parts.
  116. mmmmm mig. *56k nfg*
  117. subframe reinforcement plates
  118. HF Adapter to 14b?
  119. Converting 6pt roll bar to 8pt cage
  120. Cages that go THROUGH the dash...how the hell?
  121. Book Needed:Design Techniques for Engine Manifolds
  122. Miller Syncrowave 180 SD Tig worth $1100????????
  123. lets see twin turbo honda setup
  124. New Welder: Need some advice
  125. need help carbon fiber related
  126. Cant Find this F*$*&* Bolt!!!
  127. Cage -- Rear Sturt Bar Question
  128. How do you make Sway bars?
  129. GT4094R Manifold for a 1st Gen Neon I just finished 4"DP/44mm gate
  130. anyone using ebay flex grinders?
  131. Good Muffler shops in N.east OHIO
  132. in the market for "good" tig welder for the house
  133. just bought a beginner welder but need 2 question answered cant find in *search*
  134. Help Building a Divided T4 Collector
  135. Anyone up for fabbing me an axleback? 2.25 stainless
  136. give me some feedback on my valve cover
  137. VW bus IRS tranny to h22?
  138. setting up garage for syncrowave 200 and 220v air compressor (shopping list)
  139. New to welding, need help.
  140. to backpurge or not???
  141. Can someone make me custom -3 brake lines??
  142. Pre-Fabbed Brackets, Tabs, Mounts, etc. Where to buy???
  143. Where can I get a 7.5" x 4.5" carbon fiber pc??
  144. Normal for new laser cut flanges to be warped?
  145. some pics from my new workplace,
  146. What does your local shop charge for dyno time?
  147. my first manifold...t3 twinscroll built for a holset
  148. gas lens setup?
  149. lincoln tig 225 supplies
  150. where can i BUY my own large argon cylender from
  151. New to tig
  152. Popcorn welds
  153. xs650 build
  154. where do you buy your roll cage tubing?
  155. Who else makes this flange ?
  156. some non honda fab
  157. Anybody ever cut off the endtank on an Intercooler?
  158. Carbon fiber manufacturing - good sources?
  159. shiny welds.... how?
  160. Mitsu turbo flange
  161. Best place online to buy .030-.040 SS TIG filler rod?
  162. Pics from the garage(aka shop) today...Figured I'd share
  163. Need help Picking first welder...Im a Noob Welder Help!
  164. Fully Custom Exhaust's
  165. building b series swap mounts for 86-89 accord (possable to buy the pri patent?)
  166. Cut out of twin loop muffler
  167. Fuel Cell Fabrication
  168. turbo manifold piping ?
  169. Anyone have, or make this type of collector?
  170. Did some work on designing my 4G63 manifolds...
  171. SPfab traction bar production
  172. 304SS pipe - where to buy?
  173. stock mounts are enough!! and i'm broke. i have a plan need advice!!!
  174. welder outlet
  175. What is a Good welding helmet to buy?
  176. What do you guys use to drill SS
  177. Pipe Bender Question?
  178. Fiberglass Gurus: A few questions for you : Underbody Diffuser.
  179. Not Honda Related, But Just A Little Something I Put Together
  180. Tore chunk outta subframe, need advise on how to repair.
  181. d 16y turbo
  182. my first turbo manifold what do you think
  183. JDM ITR Front end conversion: Will the car still keep its ridgitness?
  184. Welding a -6AN fitting to a Steel fuel rail???
  185. intake tubing madeof fiberglass
  186. Tube Chassis Parts For Civic?
  187. aluminum advice
  188. Mig'ing a testpipe out of scrap
  189. "ski bike" my 14 year old brother and his friend built *pics*
  190. how do i replace a 1.625" bore x 2" stroke clutch master cylinder?
  191. help
  192. My homemade DP 3"
  193. Need a second set of injectors added to a full race intake manifold.
  194. Aluminum 02 bungs?
  195. Help with valve cover lettering
  196. any one use'n 2% ceriated or 1.5% Lanthanated tungsten for DC t?
  197. some fab work today
  198. 6 to 1 header for a s/c is300.
  199. Where to buy Adjustable Ends for Strut Bar??
  200. I'm buying a welder. I narrowed it down to two. would like others opinions!
  201. Post: DIY ITB set up!
  202. can someone verify this for me its about extension cords
  203. Suggestions on turbo adapter
  204. need help with ubend
  205. missing wire spool holder...alternatives?
  206. A different kind of fab work
  207. Need Opinion on Harbor Frieght Gas Mig Welder
  208. anybody ever try makingtheir own bike?
  209. where can i get a sharp/tight radius 2.5" 90deg bend?
  210. AE_2000 Headers i made
  211. Help me with these welds Tig welding .065 SS pipping
  212. Turbo flange placement - early steps in manifold fab
  213. Custom headers, Ford F150
  214. QUESTIONs FOR WELDERS
  215. NEED: SMall Aluminum Tig Repair Welding in SOCAL OC
  216. Ok we saw the one guy that made the bad weld, but someone torqured something wrong
  217. Problem with my syncrowave 200.
  218. Need to find a 1.5" SS flex pipe or equivalent...
  219. Cutting SS pipes what you guys find better for blade 18 tpi or 24tpi. Other recomendations?
  220. What is going on in this video?
  221. Headers for my SUV Non-Honda
  222. Cad Database???
  223. some work pics...
  224. What are the Must Have tools to start up a tuning shop?
  225. What welding rod to order for new TIG user?
  226. SAFETY EQUIPMENT THREAD
  227. Post up: your Intercooler endtank construction pictures.
  228. Using Google SketchUp to model turbo manifolds
  229. Thermal Arc Dragster 85 TIG welder
  230. Right way to weld V-Band to a cast exhaust housing?
  231. can you weld 304 ss and 306 ss together
  232. Small explosion while welding a radiator??
  233. Teach me CAM
  234. aluminum v-bands?
  235. best so cal exhaust shops!!!!!! help
  236. Nhra Cage Base Plates
  237. Aluminum hangers
  238. Frame rail damage drivers side. And home remedy tool i can use to bend it up to straighen it?
  239. Welding onto turbo compressor housing
  240. Anyone have pics of inside of properly welded manifolds/exhaust
  241. pic request: backhalf civic
  242. Best way/tool to remove cracked lugnut?
  243. HKS bypass valve flange the same as greddy?
  244. 4g63 into an EF/EG...
  245. playing out the rose even more
  246. What size pipe for Tial 44mm wastegate?
  247. 1uz turbo manifolds
  248. home made ramhorn.... PICS INSIDE
  249. which tig welder should i buy?
  250. some 1.8t work ive been finalizing
