View Full Version : Welding / Fabrication
- Looking to buy a divided housing T4 flange........
- one pice frount ends
- header secondary size- 48 mm vs 50mm?
- super uber custom t3 5 bolt taper to 3inch!!
- Having trouble contacting ExploitedRacing...
- Snap-On Mig Welder, good deal?
- Tig practicing for my manifold... on mild steel
- Simple Custom Carbon Panel.
- portable oxy-acetylene torches
- can any1 in so.cal do a firewall vin swap (cut,weld,shave smooth)?
- How to put together gaslense and gasket?
- TIG Starting the ARC...manifold building...what method do you prefer?
- C.H.A.S. Unique idea!!!
- Header Fabrication/Design
- SLS 3" Collector Weld Pic
- Anyone here using a Miller Maxstar 150?
- Rate My Tig Welds
- Which mig welder to get?
- Drill Press coolant setup?
- New miller machine news
- need a fabrication shop(so cal)-backhalf needed
- Filler rod dia. for sch. 10
- dc2 carbon fiber dash
- Collector techniques.
- Velocity Stack Comparison: Ross Machine Racing vs Weber Stacks
- Can different metal be welded together?
- christmas present
- HF Tube notcher!
- monster awd honda. is it possible to reach?
- oxy-acetylene lap welds--need advice
- Got $500 gift certificate, Good welder?
- Just to prove I can actually weld...
- chicago electric MIG?
- Small car or large go cart
- q about fixing latch on a CF hood.
- Front Clip for db8
- For the lazy tube notchers!
- Turbo manifold question regarding merging the runners...
- Yea... unfortunately another which welder thread. I did search though.
- My crazy 8pt ER roll cage
- Good Deal?
- new toys for weirRacing
- Electrical Wiring to support your welder???
- tig weld question
- Making a Jig.....
- need help: cut and weld intercooler end tank
- Opinion on my rear Carrera coilover addition... does it look safe?
- How do you measure bent tubing?
- making a turbo manifold... QUESTION
- Poll to help me decide which tig to get. Everyone choose one
- Shaved door handels not allowed for dragracing
- stainless to mild with mig
- Help me choose a welder please!
- Air Compressor storage: Leave bottom vent/nipple open or closed?
- my first welds
- Why no stick welds?
- opening up a skunk2 IM and porting it out then welding it back together?
- can i weld this mount bracket to my frame? where can i get it, part number?
- Which weld to use?
- ok i have searched google so now ill ask here
- anyone have bending program?
- My Tig welds....
- my computer chair
- So I bought a Harbor Freight TIG welder (pics)
- Mold Makers, Question About Paint And Tooling Gel....
- mild steel for turbo mani??
- Any SolidWorks experts in here???
- MIG/TIG welder fabricator looking for job in so cal
- Arc welding stainless
- Post up your custom brake line setups.
- bvkxcjv
- my first parachute setup
- Welding Aluminum with a thermal arc 185
- anyone built a motorcycle frame?--not a chopper or harley custom
- Need a good welder in the Portland Oregon Area.
- What do you guys think of this bandsaw?
- Dumb project of the day...
- BLOCK DAMAGE
- Any welders/fabricators in OKC
- Has anyone built an off road kart?
- Possible to get into welding for not a huge amount of money?
- I searched... ideal welder for turbo exhaust manifold
- HF Manifold Crack fix
- Hardtop Conversion
- Harbor freight Chicago Electric plasma cutter or Smilely Ebay Plasma/Tig?
- how to make two peices from a u-bend anyone?
- thermal arc prowave 185 or synchrowave 180sd?
- EF9 noob...
- a lil pic of my tig welds, any comments?
- EG exhaust?
- intake manifold
- Helicoil kit for transmission case bolts. 12 x 1.25mm...anybody know what size drill bit?
- anyone used this bender?
- problem with a block
- anyone ever mig weld an oil return bung without warpping the oil pan??
- Intake manifold
- Inverter - Why did I use anything else?
- CNC machine anyone?
- Im selling my welder( i know this isnt the classifieds) just tryin to help someone
- ill join the grade my weld contest
- Welding Project for SKOOL is Engine Hoist. Any suggestions?
- Which site did i see a $100, 4-1 header for a Honda Civic Si?? Choppin' it up!!
- Lovefab Audi Manifold
- San Jose Shops
- relocating fuel filter.. what type of fitting will i need?
- Welding aluminum with a Millermatic135????
- Dynasty 200 dx or Synchrowave 180 sd?
- Welding a cracked tranny case ?s
- Quick question about Holes (dont know if this is right thread to post topic)
- engine bay shaving in progress
- Newbie Tig Project
- Need paint in Wisconsin (midwest - tristate area)
- Need Help On Mold Making Using Gelcoat....
- frame jig.
- materials for making downpipe
- double slip fit collector...
- Welding Aluminum ...
- thoriated tungsten
- welding pot metal?
- Any way to get use of shop equipment?
- What would you do?
- lambo door kit
- Composite, Fiberglass and Plastics help forums........
- need header flange 2004 civic
- R/TErnie's Neon "Race car" Project... 56k go away
- What size piping?? turbo mani
- PolyCarbonate or Lexan Honda race windows????
- radiator support
- welding stainless. any tips?
- GT series with a T25 based housing running an external wastegate?
- H22A fabrication work on a alternator/tensioner bracket kit for either H or D series alternators
- where to purchase a TIG from and which one???
- Roll cage mounting box vs. large plate?
- Garage welding table
- Machine shope in LA/Riverside area?
- straight 6 turbo manifold......
- spark plug cover
- Custom 4 lug to 5 lug conversion
- Metal Supply in las vegas?
- Recommend a TIG: Miller Dynasty 200 dx?
- Snap-on Mig welders
- Why i do i need to use impact stockets??
- Is there anyway to weld cast iron?
- CAN ANYONE BUILD ME A MANIFOLD
- Bov flange?
- How would you design a small access door in a side window?
- Help on First Weld Job, Tips, Possible? (Test Pipe & Exhaust)
- Need advice on dremeling a shroud for my HID retro.
- WELDER BROKEN! Need Help On What Happened!
- Homemade DIY Turbo Fitting
- should I buy this tig machine??
- my first downpipe and dump tube
- Fisrt tim with a MIg looks like garbage......help
- Welding stainless with Co2 gas
- Traction Bars I made... pics
- First job with my new Lincoln 3200 HD
- n/a header design formula
- How important is the "pulse" feature to make nice TIG welds...
- Hairline crack in camshaft lobe
- Mild Steel or Stainless Tubing
- Rollcage
- Settings for Stainless Steel? Thermal Arc 185
- Where to get Downpipe mandrel bends In chicago area???
- Attempting mig welding
- Howe?
- Go Kart
- DIY Garage Heater
- save for a tig or get a mig?
- single turbo V6......wastegate placement
- Buying block with broken mount point...
- anyone heard of road race eng aka RRE?
- Catch Can Fabrication.........
- Harness Bar. How Would You Do It? (CRX)
- Shop in SoCal to weld fuel pump into fuel tank??
- what is a good mig welder
- Anyone ever tried???
- FS: BRAND NEW MILLERMATIC 135 MIG WELDER
- Who has made their own 4-1 N/A header?
- Built B18c1 in 00 em1 with custom exhaust build pics.. Take a look
- possible to mod a B series mani to fit D?
- FCAW Q: can you really flux core weld thin sheet metal or not?
- oxy-acetylene keyhole post part 2
- Shave door handels and molding.
- My new exhaust...3"DP, 3" HF Cat....4" back...**PICS**
- To weld or not to weld??? -- need opinions on DP crack repair/replace!!!
- Need help figuring out what turbo out flange I need
- 3.5" exhaust (searched)
- questions on argon purging a manifold...
- What size tubing for extended OEM top hats?
- Manifold criticism
- Which welder: MIllermatic 135, Licoln 135T or Lincoln 135 plus?
- Rate my welds please experienced fabricators. TIG.
- i want to make a h22 turbo manifold i have turbo maniofold but it dont fit
- Manifold Fabercators I know your help
- end mills
- molding and repairing urethane???
- What Tig machine is right for me?...
- Medium duty machinery recommendations.
- NJ welders i need your help welding my Downpipe
- What size fitting for slave cylinder?
- Ideas on how to mount air intake temperature sensor?
- I want a collector
- A new manifold
- Pasenger side motor mount striped need help
- Screwing around with new jig
- i need to make a dumptube but i need some materials
- Welding between the thinnest sections in collectors
- oxy-acetalyne noob here; can't get keyhole to stay in square butt weld
- Weldpak Gas Help please
- Is this K24 salvagable? (broken mounts - welding expertise requested)
- where to get full ss brake lines
- Rollcage welding question
- yay just got the call my new little toy is here
- Grade my new welds please.
- quick exhaust question
- Roll Cages
- How come ppl make turbo manifolds out of stock HF manifolds but not EX manifolds?
- fiberglass gauge pod
- how do you fix bubbles in carbon fiber?
- Question on welding
- Question on how to O-Ring exhaust flange
- Exhaust plans (cad/catia/ug... ect..)
- MIG Welding Aluminum
- How safe would this be???
- would these help stiffen a roll cage?
- what mig wire/shielding gas to use for a seem welding chassis
- whats the proper way to place a egt probe?
- Need a shifter mount/bracket made, needs ideas (h22 to d16 in EK)
- Formula to calculate exhaust flow?
- Mild steel 1018 - exact ingredients ???
- molding part 2
- Back purging MIG welds: is it worth it?
- Where to buy piping... Stainless steel, aluminum, etc.
- THIS WEEKEND"S FAB
- ok, a 'which would you buy'
- Anyone know what type of aluminum our tranny casings are?
- F23 header flange
- So Cal People: Motor Mount Weld
- is an ARC welder tig convertible?
- Reviews on cheap ebay tig welders?
- intake manifold for dual 40 dcoe side draft carb to b18a, any1 have flanges?
- millermatic 185 help please
- ABS retrofit
- Which Resin For CF?
- Aluminum exhaust piping is it ok?
- intake manifold plenum question's
- someone told me the miller dynasty 300dx was junk today!
- Already have 10" miter saw with carbon disk, keep it?
- Thermal Dynamics plasma cutters.. any good?
- High Coefficient of friction? Material? Project
