PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47
  1. how do you guys clean the inside of your charge pipes?
  2. Mig welding review ( pics inside)
  3. Another creation ( catback system )
  4. Anyone have results/feedback from their custom header? (na only)
  5. My ITB setup, in progress
  6. good welders?
  7. 8" radius bends
  8. in need of multiple sizes of velocity stacks
  9. GReddy PE downpipe bolting to a Spoon N1 (or other) Axleback
  10. CARBON FIBER SUPPLIER IN SAN DIEGO?
  11. Wastegate Drop down tube
  12. Does anyone have a Design made up for Traction Bars?
  13. Blueprints
  14. lighten my coupe
  15. welding on frame?
  16. Thermal arc welders any good?
  17. lug nut manufacturing.
  18. Where can I find more of these
  19. Source for Small Damper Shocks?
  20. Downpipe flange for Ihi/Borg warner Gm8???
  21. can u use the dryer outlet for a 220volt welder?
  22. Who has the best online prices for welders ?
  23. rewired engine bay...FINALLY!!!
  24. wire feed welder-
  25. Give me your opinion on a lowered roof cause I like it.
  26. My first downpipe *pics*
  27. Need some help setting up a lincon mig welder
  28. Power Brake Bleeding - Pump Type
  29. Whats a good pipe bender?
  30. Middle console gauge pod...(with pics)
  31. ebay tig welder any good? what do you guys think?
  32. Welding Rollcage to Chasis questions
  33. PLASMA CUTTER FOR SALE
  34. Is MIG supposed to be easier than welding with oxy-acetylene torches?
  35. civic clutch ss line
  36. new to welding
  37. My first manifold (progress)
  38. THE SETUP OF ALL SETUPS
  39. Why Lincoln sucks ass....
  40. where to get this awesome item
  41. anyone ever trimmed all the metal from a civic door???
  42. h22a turbo project finished as of tonight...
  43. Rally light pod
  44. door hinges
  45. "Shortening" Header Question.
  46. my hm bov *pics*
  47. Inverter welder that is a/c and dc an will run on 115v and 220v
  48. DIY Fan Shroud
  49. first collector imput wanted
  50. who here can build custom flanges?
  51. Turbo manifold project
  52. So close to getting my turbo kit finsihed but ran into a welding snag
  53. Need advice on this type of TIG welder.
  54. Anyone make their own muffler before?
  55. How much to fill in Side Molding on a civic?????
  56. I need a couple of parts machined...
  57. will aircraft paint remover dissolve fiberglass?
  58. place in so cal for broken bolt and exhaust fab
  59. POR 51?
  60. I went Tig welder shopping this morning, looked at PT 185 & 180SD
  61. Integ Door Panels In EG Hatch
  62. tig torches, which to get.....
  63. H22 Exhaust Flange to make Custom Header
  64. Wheel well rust repair
  65. Anyone got a cnc machine?
  66. New to welding want some buying help?
  67. Sanding body for paint
  68. miller 180sd?
  69. Locked threads??
  70. new dash layout
  71. Subframe Reinforcement Bar--in need of CNC--Nor Cal
  72. wrapping up downpipe...wrap cat or not?
  73. h22a turbo
  74. seam welding?
  75. Wiring a Miller syncrowave 180 SD
  76. Need some help looking for a Gassless MIG
  77. plasma cutter opinions
  78. IC Piping...2000 Civic Si w fogs......
  79. Installing SIR sunroof in a DX
  80. Hybrid A/C in to Civic....
  81. Fibreglass question - may not be what you expect - non car related
  82. Can anyone cut me a aluminum intake flange?
  83. Gauging Intrest.. B & D & H series Turbo manifolds
  84. Has anyone in here ever tried to stitch weld their frame?
  85. personal experience with machine shops in north va
  86. Mani for a CT-26
  87. What tool for exhaust pipe flaring?
  88. intake manifold
  89. Where to get turbo xs bov flange?
  90. What welder to buy for a good price?
  91. expanding pipes so that it will slip over other pipes
  92. Cage mount plates: stitch welded?
  93. KNOW ANYWHERE TO GET CONVOLUTED 1" TUBING?
  94. moonroof question (not sure if it belongs here)
  95. Looking for a small drill press
  96. 15g downpipe flange?
  97. Aluminum motorcycle mufflers..
  98. Collapsing Craters?
  99. Repaired Block
  100. looking for someone in the northeast to do fiberglass bumper molds
  101. MIG welding help questions
  102. Look at what contaminated my weld >:(
  103. tig question...
  104. custom carbon work?
  105. where to find...
  106. Worldwide carbon fiber shortage is here...
  107. can a 12ton press handle most automotive jobs?
  108. BEST DRILL BITS??
  109. A little end tank welding
  110. Hole saw bits for steel?
  111. 4" aluminum mandrel bends
  112. reviews on miller maxstar 150 tig
  113. GSR Endlinks
  114. converting stick to tig welder
  115. where to get diagram for obd2-obd1 harness
  116. Where to buy Exhaust Flanges....
  117. Tack welding aluminum
  118. When your MIG welding on a car, do you unplug the battery?
  119. jig making?
  120. Tap and Drill chart
  121. SolidWorks?! Anybody with experience
  122. Custom trunk traction bar
  123. Welder for JDM Conversion
  124. Carbon Fiber and Cheap in the same sentence
  125. Other Metalworking / Machining Boards & Resources...
  126. header modification /general stainless steel welding question
  127. Fuel cell + cover pics
  128. What aluminum sheet u use in Custom Race wings?
  129. where to buy the reast of my cage from???
  130. Rent MIG welder? or...
  131. Rent Mig Welder?
  132. newbie to welding. plz help
  133. Going to use sawzall to cut piping, what kind of blade should I get?
  134. Daydream Welding
  135. Dayton Imports - Now Hiring
  136. CRX dash swap?
  137. Custom exhaust
  138. noob, help with AC arc welding please
  139. 2500 lbs mustang
  140. liquid nail on aluminum
  141. fabricating Integra Door Panels into EG Civic
  142. tap and die Questions...a little help for the inexperienced please..
  143. roll cage pics
  144. question about welding the engine block
  145. looking for a product for tube notching
  146. Flanges
  147. San Diego CNC guys... help me out...
  148. Oil cooler
  149. Can anyone confirm these dimensions?
  150. 92 civic integrs front end
  151. Welding thin .035 aluminum tubing to intake manifold flange???
  152. can we mold lexan..
  153. Anyone ever fab'b mounts to fit b18a1 into 94 civic??
  154. I need someone to weld for me!!!
  155. Any welder in the DFW here?
  156. SeArched and FaiLed, Part # or where to find 90degree bends SCHED 40
  157. Valve spring install tool
  158. lower - the smart way?
  159. h22a turbo project progress....pics inside
  160. Aluminum Exhaust- Hangers?
  161. Mcmaster carr part# for wasgate dumptube piping???
  162. rusted chromoly?
  163. home made remote oil cooler
  164. ITR Quarter Panel
  165. S&W roll bar kit finally installed
  166. Need help finding header building school....
  167. tig welding shops in northern VA
  168. exhuast modification
  169. building knockoff strut bar. help!
  170. welding on car???
  171. MIG vs TIG welds
  172. extending exhaust
  173. Would you call this a jig?
  174. Welding cylinder head
  175. Help! Making obd2=>obd1 wiring harness?
  176. Best way to make a JIG for full exhausts...
  177. collector jig
  178. Help!!! Fabricating a Wheelie Bar?
  179. Need help looking for Thermal Arc 185TSW parts.
  180. 3" cat didn't come with bung I requested, need to weld it on myself
  181. hf/evo8 16g plate
  182. Welding up various body/frame locations, suggestions needed.
  183. H22a turbo project almost complete....pics inside
  184. radiator core support
  185. results of my weekend.
  186. whats the deal with this welder?
  187. project finished.
  188. Where to Buy V band clamps and Flanges
  189. please sell me a h23 head flange....have it in stock?
  190. Ashy Weld
  191. Aluminum or Stainless barbed nipple source?
  192. Custom manifold with warped flange
  193. Mini-me style for Mitsu 4G93
  194. WILL PAY CA$H for a welder to fix my seat bracket. SOCAL
  195. Welders
  196. Looking for someone in the Northeast to tig weld a stainless closed loop dumptube
  197. Body repair - Rear Qtr Panels on EF
  198. DC 4-1 header modification
  199. Floor pan repair. how thick?
  200. Positioning exhaust parts for tacking
  201. Arc welder shocking??
  202. What bandsaw blade to use?????
  203. Damn, problems with new Lincoln Handy Mig - gas valve sticks
  204. having feed problems with miller mig welder
  205. Rollcage builders in SoCal?
  206. Cutting Carbon Fiber Question
  207. JB Weld on Tranny?
  208. weld from stock header?
  209. Relocate Gas Tank Filler Neck Relocation Civic CRX
  210. Cool PLX install
  211. other fabrication forums
  212. 10 t-bolts for $9.00...
  213. Our Latest Project!!!
  214. Where to get a WG adapter
  215. Carbon Fiber Help
  216. anyone know how to Moon Cut a valve cover?
  217. welding techniques?
  218. any NJ fabbers?
  219. civic jdm front clip swap help please
  220. racecar builds
  221. Can you Mig weld Stainless steel?
  222. cowl hood
  223. Can you tig mild steel exhaust tubing with C25 gas?
  224. what is the best...
  225. About to start my first manifold, got a couple of questions...
  226. just bought an arc welder...never welded before....a few questions
  227. Just curious, does this stuff work ?
  228. thin wall stainless (.049, 18ga) source
  229. weight of tubing
  230. ls motor swap
  231. Anyone do cages near GA?
  232. What material (304/308/310) for fullrace-style manifolds ?
  233. Bandsaw broken in less than first hour
  234. Rate my weld...
  235. Who makes a collector like this?
  236. What Downpipe Materials Did YOU Use???
  237. Any one want to fab a resevoir.... Simple design.
  238. welding in Michigan, need help ASAP
  239. Where can i find a brake tube bender likes this??
  240. McMaster-Carr, page numbers
  241. What Tool am i looking here?? grinder or cutter?
  242. New to welding, I dont know shit. Help me out.
  243. tips on makeing my hatch less noisy inside???????????
  244. Half-Radiator dimensions
  245. K series bellhousing specs
  246. In INDIANAPOLIS
  247. Buying a welder
  248. What kind of metal...?
  249. Does anyone sell aluminum radiator cores?
  250. How to fix crack on the bottom of a CF hood?
