PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
  1. recent work (since the last time i was on here)
  2. To all the welders and fabricators. Drive safely this holiday
  3. how do you make these holes
  4. CNC Pie cuts? Who does them?
  5. rwd del sol build
  6. B.R.E. Motorsports, Inc RR s14 fab pics
  7. Why are inverter tig welders so much louder than transformers when welding AC?
  8. Is this enough penetration?
  9. ideas for holding pipe
  10. Advice or help needed for possible exhaust build!!!
  11. any advanage of running a long wastegate pipe
  12. Best belts for metal
  13. Trouble with metal warping.
  14. pics of my first turbo collector
  15. were to buy 38mm 3m thick pipie
  16. tial turbine housing vband clamp alternatives
  17. First time Tig welding (pics)
  18. Moving on up! Bought a new Miller Diversion 180!!!
  19. Exhaust Question Drone and Rattle Can Noise
  20. MIG welding aluminum
  21. Coolant Reservoir wiretuck/holder fabrication
  22. Is this the same as mild steel
  23. some of my fab work
  24. Roll Cage Tubing Jacks/Spreaders
  25. Exhaust design questions
  26. building our new cnc plasma table
  27. welding spoiler holes?
  28. Eastwood tig 200
  29. whats these manifolds paint in or chromed ?
  30. Searching for Welder: Mass/ri
  31. idea on how to make these
  32. can this be fixed? obd1 gsr head with small hole - pics
  33. Where can I buy braided hoses
  34. Roll cage using mandre bends?
  35. Fabricator, and how to become one ?
  36. found this on the net on making up a turbo manifold
  37. Advice on snapped stud
  38. just some info about size for my turbo manifold
  39. Simkusracing.com - My new job ;)
  40. Some Current Work
  41. nice vid on pluse welding
  42. Problems with Miller diversion 165
  43. welding fittings in valve cover and it cracked
  44. Breathing filters
  45. front lip sticker bomb
  46. tig welding stainless to mild steel
  47. what is this called?
  48. Burn-through control...
  49. Manifold runners ? equal vs non-equal length?
  50. Looking for a custom-sized radiator core.
  51. Anyone ever tig welded brass?
  52. Tips for tig welding Stainless please?
  53. collector size
  54. new setup
  55. books for tig welding?
  56. Raising shock towers!
  57. Welding supplies Canada.
  58. stainless MIG tips. Need help.
  59. stright pipe on civic
  60. Pics of your tig torch setup :)
  61. can this HF miter saw be used to cold cust exhaust and manifold pipe?
  62. What gas lens and what size cup is best for me
  63. long tube torque monster, how would you improve this design?
  64. COLLECTOR CITY~D.R.
  65. First MIG Welder
  66. DOC Race BMW 335i Single Turbo Manifold~
  67. Lincoln Electric VRTEX Virtual Reality Welding
  68. can someone give me some advices about tig welding
  69. running your TIG with a generator?
  70. First attempt at welding butt-joints
  71. i am amazed by the technology found in simplicity sometimes.
  72. DOC Race Topmount A/C and P/S
  73. Thinking of making my own Fuel pump hanger?
  74. Lookng for the most flexible gas hose for my tig torch (air cooled)
  75. can i use this piping for turbo manifolds
  76. First time welding
  77. First attempt at TIG
  78. found a crack on my turbo manifold yay!!!
  79. starting my mock up on my turbo manifold
  80. Looking to have a header made
  81. EF9 exhaust into DA9???
  82. RO_SUNNY's Garage!
  83. AdReNaLiN's First Manifold
  84. Whats the best metal/alum cutting chop saw for the $$$?
  85. Good place to buy sanding belts?
  86. Bought a new welder (Dynasty200): Which tungsten....
  87. best shielding gas for stainless tubing
  88. brush finish on stainless?
  89. How to save gas while back purging welds
  90. solar flux
  91. Custom radiator cores?
  92. first atemp at down pipe ive done
  93. some of my welding pics.
  94. Damaged Passenger's Side Rear Wheel Arch
  95. help with 4/1 collector
  96. Welding something with ceramic coating
  97. Best grinding method for aluminum pipe welds?
  98. galvanized or cold rolled?
  99. TurboTrix Racing Forward Facing 6765 Bugeye
  100. how to hold not magnetic pipe to tack.
  101. Loose, rusty scale from cast iron manifold
  102. How do you properly store a welder/cylinder after use?
  103. My welding thread, pictures soon to follow
  104. Some work around our shop lately.
  105. ASC SpeedMetal Photoshoot w/DCSProPhoto
  106. welding newbie ?
  107. Connect the Dots for Adults. Picture and project thread
  108. Just purchased a machine, issues.
  109. welding seat rails
  110. pipe beveling
  111. How you cut 90 degree elbows??? :)
  112. Where to buy bi-metal bandsaw blades for international shipping? What brand?
  113. AE86 Stainless IC Pipes
  114. custom fuel cell
  115. drivers side post mount issue
  116. Looking to buy a TIG
  117. Miller Dynasty 200DX for sale $2500 OBO
  118. log style manifold
  119. Concerns with welding mild steel
  120. Wastegate flange options?
  121. Easiest Method for drilling ss304 for 02 bung?
  122. 70-72 amp?
  123. warping?
  124. hows my stainless welding?
  125. mild steel weld prep.
  126. A few questions.
  127. who can cut and weild full body panels
  128. Please critique my mig welding
  129. F20C Turbo Manifold
  130. 99 - 00 core support on a 96 hatch
  131. taps and dies local
  132. Problems welding a tank shut
  133. quick CFD drawing needed for a velocity stack
  134. Can Stainless Steel Be Welded to Steel?
  135. Questions weld my first 3" custom exhaust
  136. Who makes custom stainless logos / badges for manifolds?
  137. welder not working...
  138. D Series Mini Ram ( First manifold )
  139. My D Series Ramhorn
  140. coolmate 3 water cooler wiring
  141. Evo1's Fab Thread
  142. Cad Software
  143. Finally finished my daily turbo D project
  144. What to look for in buying a welder?
  145. Full V-Band 321 and Inconel Suby Setup
  146. 4g63 custom intake manifold
  147. Anyone have a source of 6061 fuel rail blanks?
  148. Check out my welds (4th day)
  149. Honda-Tech Breather Box/Catch can/breather box thread.
  150. First TIG project
  151. B Series 14:1 Custom Header~
  152. Catch can setup I did.
  153. need some one to make me this..
  154. v-band flanges
  155. At what point in time did you guys start selling your welding services?
  156. Dual Cam KA
  157. What thickness aluminium for catch can?
  158. Twin Turbo M3
  159. Weight Lifting Accessory for fellow Iron Bangers
  160. would you buy this?
  161. Back purging tubes/pipes info help!
  162. First time tig wedling got some questions.
  163. Tial housing inlet flange fixture
  164. Fabrication Career at Boost Logic Opening
  165. turbohelps.com, free cad flanges, t3flange is back
  166. Bolt in roll cage fabrication question?
  167. aac 2jz s2000
  168. Buying my first tig machine tomorrow need some fast info
  169. Gas Lenses and Cups
  170. Fair warning on IR compressor
  171. V band on turbo Cold side 4"
  172. material used in F1 for molds,models,ect
  173. RG Race Fabrication thread ;)
  174. Roll bar install in CRX
  175. Mig welding 2 different types of stainless
  176. Victor X port-match inquiry!!!!!!!!!!!
  177. Ninja 600 Golf-Kart build thread
  178. JB Weld help
  179. Looking for fabricator!!
  180. newb question about stainless so cal help
  181. Honda swap?
  182. fuel line question
  183. Billet Aluminum filler necks
  184. DIY muffler from scratch?
  185. replacement torch help??? sync 200
  186. About to purchase my First tig machine
  187. What belt sander are you using?
  188. Exhaust spring
  189. I'm in big trouble, need some help with stainless steel!
  190. motor mount design help
  191. Miller Elite vs Digital Elite vs Viking 2450?
  192. ideas on how to mount 6x4x4 catch can?
  193. Gas Regulators
  194. Syncrowave 350LX water cooler motor/pump
  195. DOC Race Titanium Mufflers~
  196. Help - External Wastegate Off Manifold Design.
  197. R32 RollCage Build and Pics of the New Shop!
  198. first time tig welding...hints,tips,tricks
  199. Manifold fabrication jig!
  200. fuse welding
  201. engine mount fabrication experience... HELP
  202. A little Fab on a 1jz s14
  203. Valve cover venting/catch can question
  204. DC's custom M5 exhaust
  205. 4g63 custom intake and turbo manifold build thread
  206. What material thickness for which application???
  207. Simple question regaring a Solder
  208. first time welding SCH.10
  209. New shop tool, this thing is awesome!
  210. Ideal exhaust - continuous taper?
  211. 1st time welding - much easier than anticipated
  212. Is this welder enough to weld exhaust and body part?
  213. Who can make me a 3inch exhaust
  214. Custom Radiator
  215. I need Aluminium tubes threaded and coupled. NYC area preferred
  216. Manifold fabrication tools!
  217. Gun Smithing Anyone?
  218. Learning to Mig weld for auto repair?
  219. need good welder in nyc asap
  220. Tig + Stainless Steel Nuts
  221. fast/easy fix for a stripped hole in the frame?
  222. HA! new professional technical question for you welders!
  223. welding role cage
  224. Catch can building idea
  225. First time welding mild steel, What do you think?
  226. Shop next door stole our welders...
  227. Shop Owners: Cost of Improvements
  228. building a motorcycle powered 'gokart'
  229. stripped motor mount holes what to do?
  230. Got quite the zap today from my Precision 185...
  231. Metal Engraving
  232. merge collectors
  233. Roll bar rear mount location, tips
  234. Taking the plunge finally...
  235. Custom radiator for my subaru
  236. HTP INVERTIG 221
  237. Manifold fabrication.
  238. Exhaust off the car
  239. Can These Be Used On Ferrous Metal -- On Slow Speed?
  240. Exhaust Flange
  241. Where to find stamped aluminum intake manifold plenums...
  242. evaluate Miller Maxstar 150 STL TIG
  243. need help finding replaement torch for hf inverter tig
  244. advice?
  245. Cooking the dynasty 200
  246. easy weld
  247. Help
  248. Some tries at stainless tube, help appreciated
  249. 316 L stainless steel for an exhaust manifold!
  250. Anybody ever narrow aluminum wheels?
