PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47
  1. Welding cylinder heads...
  2. anyone on here want to make a little side cash?
  3. My First Topmount
  4. custom ef 88-91 civic/crx traction bars
  5. ALUMALOY ? to repair a TINY, hairline crack near the oil pressure sensor hole ?
  6. My Latest Project K Series Turbo Manifold
  7. My first downpipe 3" a/c compatable blox manifold
  8. Piston Removal HELP
  9. how much effect on flow and hp with bad exhaust plumping?
  10. can this be patched?
  11. Looking for a mid size bridgeport mill....
  12. Carbon Fiber tube
  13. Cage
  14. has anyone made a xmember like this? and will it be effective?
  15. SS welds "grey"
  16. Custom Air Box/Duct
  17. arc welding help
  18. RED valve cover paint code.
  19. Roll cage fabricator in Illinois or surrounding area?
  20. Plasma Cutter that can cut 1/4 steel
  21. just bought h/f welder and i need help with wires.
  22. are there any 110v tig welders worth getting?
  23. Exhaust pipe broken... weld it?
  24. syncrowave 180 for sale
  25. SPINDLE MOUNT SHOCKS...
  26. CF Molding Question
  27. Header/intake runner combo calculations
  28. plastic welding...
  29. stainless to aluminized/mild?
  30. who machines delrin? in socal?
  31. Custom EF 88-91 Civic/Crx Strut Bars
  32. welding aluminum?
  33. Fiberglass Resin and Mat question
  34. shaving the door handles
  35. Looking for custom radiator...
  36. Another 20% off Coupon!! Harbor Frieght!! Expire DEC 30!
  37. question about making my own spark plug cover
  38. SR20 240 Turbo Manifold (56k no way)
  39. Collector Diagram
  40. thinning primer?
  41. turbo manifold for ej8
  42. shift linkage (EF)
  43. Plenum/Pressure Vessel Design, Dissecting something that works...
  44. welding question
  45. Cheapest J and U bends in Mildsteel?
  46. few more shots of the chinese smiley tig madness.
  47. ramhorn questions? new guy
  48. How to rethread?
  49. Turbo Manifold Build Up Prices....
  50. Happy Holidays
  51. Bumper Cutout on 91 Si.
  52. noob: questions about my welding machine
  53. Another new toy
  54. Custom Fuel Rail
  55. Dodge ram piping..
  56. Race car cutting
  57. Great post to people that are new to tig
  58. Fabbing strut bars.
  59. Made a solid motor mount and now HID does not work.
  60. Which welder should I rent to use on my firewall?
  61. Getting a flange CNC'd
  62. Sheet metal intake...How thick of alum? and grade?
  63. Merge Collector Angle Discussion
  64. Purchased a new welding machine today
  65. intercooler bov
  66. where to get 4" mild steel tubing?
  67. ATTN: Exploited racing...
  68. WHO'S THE NEW GO-TO FLANGES PERSON
  69. What is the best way to clean stainless steel headers?
  70. Harbor freight deal
  71. looking to contract carbon fiber fabrication...
  72. mild steele not easy to weld ???
  73. Riland Tig 200 ?
  74. using a plasma cutter
  75. How to get colors in stainless/tig'ing?
  76. My school mini fender project + PICS
  77. what type of metal should i use to make an engine mount
  78. Best place to get a 304 stainless b-series exhaust manifold flange
  79. cool video of how vacuum infusion works in manufacturing infused carbon fiber stuff
  80. turbo manifold construction help
  81. Can you weld.......
  82. maxstar 150 s arc welding?
  83. FS: Lincoln Idealarc SP-200 MIG welder with tons of extras OREGON
  84. Can you mig stainless?
  85. At home fabricators...
  86. Started making a cabon fiber valve cover
  87. How do YOU cut the hole in the manifold for the wastegate?
  88. finding flanges
  89. Looking for a 60mm to 63mm (2.5") expander section
  90. Tig welding in magnetic fields
  91. couple of cutting tools
  92. Turbo manifold????
  93. This material good for headflanges?
  94. Custom NA Header. Tig.
  95. is it possiable you can fabricate your own proarms ?
  96. weight difference between aluminum and aluminized steel?
  97. any experience w/ these welder?...
  98. Custom down pipe
  99. Tig question, its been making me go crazy.
  100. 1 1/2 vs 1 3/4 runners
  101. Anyone know where to get a 4.5" turndown?
  102. need help removing a broken bolt...
  103. Picking up welder tomorrow, what kind of wire?
  104. automotive primer? which one should i use?
  105. Any turbo inlet filters....like super low profile foam sock?
  106. toyota intake sensor flanges??? any one make them here???
  107. Labor cost for pie-cut/sectioned bends
  108. what striaght pipe to use with my mcmaster bends?
  109. coeficient of heat expansion of mild steel?
  110. Stainless ball/socket flanges?
  111. GT42R RSX manifold
  112. my little tig project...
  113. metal suppliers
  114. rate my collector.
  115. Other possibilities than mildsteel AISI 1018 for flanges
  116. roll cage fab for road course car in OREGON
  117. Millermatic 150 any good?
  118. My Tig Steel and Aluminum pics
  119. In need of some gas cup info...
  120. how thick should the piping be for a turbo manifold??
  121. New here, non honda but still unique
  122. Anyone have CAD drawings of exhaust mani flanges?
  123. Where to buy DOM tubing for roll bars
  124. Buyin a tig today need help asap sync 200 or TA185
  125. Want to pay someone in SoCal to do fabrication and welding
  126. my aluminum welds with tig
  127. Manifold almost done.....
  128. what do you guys pay for argon ?
  129. a good mig for 500
  130. what size breakers for syncrowave 250dx??
  131. How much do you guys pay for your steel locally?
  132. intake manifold parts add in magazine?
  133. Miller Syncrowave 180SD With Tig Runner FS
  134. exhaust runner length
  135. for those who asked, closeups of smiley tools work. and welds
  136. DIY C-pillar Bar
  137. roll bars
  138. tig welder for sale. and need advice on which welder
  139. The first 15 minutes of welding with my Miller Maxstar...
  140. Header Fabrication 101 (56k wait a while)
  141. Intake Manifold Question...
  142. Rate My Bead/Weld *Aluminum
  143. Miller 135 MIG welder?
  144. what size pipe for primary runners? Intake manifold w/ goodies
  145. Back Purging- What How Why
  146. engine bay shaving/wire tuck
  147. Welding my tranny??? Will the heat damage anything inside? Please Help!
  148. Cold Solder
  149. first mani welded with the smiley tools tig/plamsa and in my hmt fab gargage
  150. tube bending??????
  151. Who here can make me custom fiberglass, or carbon parts?
  152. hmt fabrication section. pics
  153. Where to Find: 1/8" Wall Aluminum Tubing...Straight & 90* bends
  154. can anyone on here make me a top mount turbo mani?
  155. How did you learn how to weld?
  156. Injector seat design help needed
  157. Found a picture of this intake manifold........??
  158. custom aluminum radiator
  159. V-band + 4 bolt/ 3 inch pipe
  160. Who makes THE BEST allan keys..?
  161. Looking for some friendly help around Socal
  162. Supercharged motor header design
  163. Any auto body painters out there???
  164. FS miller 180SD 1500$ W/ 150cuft bottle bay area
  165. urethane, shore hardness, tensile/shear strength and my motor mounts
  166. How to weld to properly weld cast iron
  167. What are you using to cut sheet metal ?
  168. Custom Intake Manifold (not a honda)
  169. 0.125 aluminum sheet metal for intake manfold?
  170. Transmission Bells.
  171. know how to wiring up a b18?
  172. Piping for an A'pexi WS Turbo Exhaust??
  173. 10pt. Cage in a Hatch Through the Dash QUESTION!
  174. Good filler rod information
  175. My first manifold d-series
  176. Anyone making carbon hoods? mounting question
  177. my homemade turbo kit progress.
  178. How many amps does it typically take you guys to weld sch 40 stainless?
  179. Work boots.
  180. New Miller Syncrowave 200?
  181. anyone else tired of the "rate my welds" threads?
  182. Greddy BOV Flange- Rate the welds
  183. RollCage Civic 92-95 Hatch - CAD or Construction Sheets?
  184. welding safety
  185. msd pro billet distributor install? wiring issue .. searched
  186. ls vtec new oiling system
  187. Rate the welds..first timer
  188. JB Welding (it's welding, right? :P) a cracked radiator, any success?
  189. NEW JERSEY aluminum welders: I need something welded
  190. thought people in here would appreciate this better than other forums jd2 bender
  191. collector jig
  192. Custom video camer mount.
  193. Welding & Fab work on an intake in Nor-Cal
  194. b-series trany adaptors for RWD trany.
  195. aluminum filler rod
  196. Need stainless flanges cut
  197. first crack at stainless charge pipes.
  198. New to TIG, so... rate my welds!
  199. Dallas Muffler shops
  200. Custom H22A crx 4-2-1 hybrid NA header how to...
  201. Thicker Gauge Aluminized Steel vs. SS for turbo headers?
  202. looking for someone experience with fiberglass or carbon fiber in so. cali
  203. woot woot... i'm a welder at TOMCAR... yay(+q about welding with short sleevs)
  204. Polyurethane Painting.
  205. Chop saw
  206. MIG welding a Turbo Manifold
  207. New Toy- Thank you craigslist~
  208. headflange became smaller while welding? same experiences?
  209. Learn, Work and make some $
  210. How important is having an adjustable frequency when welding alum?
  211. New toy
  212. OIL Pan Baffles,
  213. My 2nd attempt at a down pipe
  214. I NEED A JOB!! anybody need a good MIG and TIG welder?
  215. delsol body flex. opinions on fabing some braces
  216. Spot welding
  217. What kinda welding helmet do you guys have?
  218. B series dirt racing style shifter
  219. Gap at flange to pipe connection?
  220. looking for user.....
  221. Aluminum 4" 90degree source needed.
  222. Reversing the direction on the Harbor freight band saw?...
  223. "cheap" plasma cutters
  224. Which welder to buy?
  225. Anyone ever welded a rim?
  226. custom seat rail design?
  227. Cast stainless merge collectors...
  228. Whats your local shop charging for boring?
  229. Almost complete Engineering project....nothin special
  230. how to convert 220v to 460v single phase? transformer?
  231. CUSTOM HEADER
  232. MILLER ECONOTIG (460v Model 1-Phase) - could i use this @ home?
  233. Need somebody that can CNC aluminum peices for me...
  234. core support welding question about conversions
  235. Which helmet would you pick
  236. Relocated power steering pump
  237. Aftermarket radiator
  238. Turbine housing welding
  239. Plenum design for the audi
  240. Mig welding tubing...
  241. 180sd users step in
  242. ANYBODY USING THIS TYPE OF WELDER? (HEND HELD)
  243. First Turbo Collector (for me)
  244. custom fabrication
  245. diy filled b series block, with writeup, comments welcome
  246. Machine shop directory
  247. engine driven question????
  248. 94 bubble front conversion...
  249. EG6 JDM interior...HELP!
  250. Silencing an air compressor
