PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47
  1. Where to buy Nord-Lock washers?
  2. which mig welder is good for light fab work??
  3. Im looking for a welder in NOVA area for a DP
  4. Need help with welding DP
  5. 3.5" downpipe pics
  6. Single side swingarm S.O.S.
  7. Any one nice enough to share about Weld/Machine/Tech??
  8. custom h22a log mani...what you guys think
  9. help please... thanks.
  10. Fastest way to cut grind down welds?
  11. HELP: How do i remove ???
  12. good entry level tig
  13. DIY velocity stack
  14. b21 motor swap
  15. what welding rod to use on APEXi exhaust!?
  16. my downpipe *pics*
  17. anybody weld custom BMX type bikes?
  18. Drilling 316 Stainless Steel
  19. What can i replace in the bay with 1/4 steel braided line?
  20. fixing cast aluminum rims
  21. DASH BOARD REPLACEMENT...VIN NUMBER???
  22. Hope me luck guys....
  23. S2000 Seats
  24. wleding on cast iron
  25. 15G Downpipe Flange...
  26. Experience with Dayton/Grainger tools?
  27. Looking for someone in NoVa to weld mounting tabs on intercooler ( IC pics inside)
  28. grinding welds down............pics please
  29. kirkey seats WHO CAN MAKE ME SEAT BRACKETS!!!
  30. mandrel bends needed!
  31. Critique my Air Compressor Diagram for added capacity, tool life.
  32. welding job on front end conversion
  33. hard to install door poppers?
  34. welding up 2.5" DP and 3" cat, but dont want to use transition pipe
  35. ... spoolinperformance... goes all motor ?
  36. carbon fiber hood repair?
  37. Headers dented can it be repaired?
  38. making a 6 point cage into a 10 point........
  39. RHD conversion
  40. People with 40CF argon/c02 cylinders... How long do they last?
  41. EASY WAY TO CUT WEIGHT...
  42. Making B series 4340 oil pump gears??
  43. 1ST TIME WELDING - FOR A BUDGET MEAL CHARGE PIPE
  44. LS1 + Austin mini = wow
  45. Can someone explain to me why high temp coatings are black?
  46. My first tiem welding.
  47. First tig weld ever
  48. how do i make a mold for CF?
  49. My Dad and I are in the market for a welder
  50. intercooler piping welder?
  51. What bends should I order for closed loop wastegate dumptube?
  52. mmmm, look what I bought today!
  53. new idea for crank pulley removing tool
  54. Welding mild steel exhaust piping with a mig welder got some questions.
  55. h.f. ban saw review?
  56. Quick Release Exhaust
  57. first welding project
  58. fuel pressure regulator
  59. how -to- MIG welding DVD
  60. Radiator support.
  61. Help! Need serious advice on a project choice
  62. GRRRRR! Metal contamination
  63. Welding of rain gutters?
  64. is it easier to burn through mild steel then it is stainless steel?
  65. Should I try...
  66. shaving side moldings, not with tack welding but with fiberglass/bondo, let me know wut u think
  67. Welding Exhaust anybody?
  68. Aluminum Disks
  69. Bisimoto no longer has ties to Rage Performance
  70. so what do you think of this civic?
  71. Now THIS is a topmount
  72. Would my built ls block hold 350hp
  73. Help with adding a tank to compressor
  74. custom fitting a lip onto my car.
  75. Holes in MIG weld
  76. CAD drawings
  77. making ITBS
  78. where to buy T4 divided exhaust flange??
  79. did some welding today without a mask.
  80. Who can cut flanges here anyone ??
  81. Fuel Cell Cage & Custom Battery Enclosure
  82. s2000 engine into a 95 civic ??
  83. BackPurging Problem Please Help
  84. Welding steel sheet with pure argon
  85. welding elbow to turbo compressor outlet
  86. convince me that I wont get electrocuted
  87. Looking for a Fabricator in NJ
  88. Where to buy band saw blades???
  89. my first tig welds
  90. welding experts needed...
  91. welded door hindges....
  92. Exhuast question
  93. Traction bars
  94. CNC machining!!
  95. polyurethane..
  96. Roll Bar Installation Question..
  97. Where do you typically buy flanges?
  98. 4lug to 5lug?
  99. Chassis Fabrication, etc...
  100. Welding a 6 point
  101. My Manifold in the works
  102. Intake Manifold......
  103. help MIG welding aluminum
  104. Anyone in Nova or Richmond area wanna fab and weld me up some IC piping
  105. manifold how to?
  106. hmt catch can for 11 dollars.
  107. Is this possible, if so how hard?
  108. INTERCOOLER FAB
  109. broken mount bolt holes on block... how to fix
  110. Cost to weld this? Or can I do it myself? any info would be helpful
  111. New tools.. And its stolen! Sort of :)
  112. bandsaw blades?!?!?! wont cut.
  113. Angle tools
  114. DTR 05 RSX chassis pics..
  115. Fab Rods
  116. will i be able to...
  117. turbo kit i fabbed.....nothing special
  118. Aluminum After A Few Days with the TIG...
  119. Just went through a circular saw metal cutoff disc way too quickly
  120. Custom Garrett intercooler for $200K sandcar...!
  121. rewelding motor mount bracket to chassis...
  122. Welding Helmets?
  123. My new shop dog.... Sort off.....!!!
  124. Wastegate plan/ Question
  125. experts...help
  126. Detatchable Exhaust.....
  127. Welding up exhaust, do you guys like to start rom the front or the back?
  128. 4130N to Mild steel?
  129. where'd that thread go with all the .dwg's in it?
  130. Where to get 2.75" rubber elbow
  131. Where can i get this repaired
  132. 99 si front end conversion on eg
  133. How do you guys weld your manifodls together?
  134. where to find stainless 3 bolt flange
  135. intake manifoild customizing b/d series
  136. Thinking about the mani for a DIY project
  137. Aluminum radiator fix!
  138. Filling big gaps (TIG, Aluminum)
  139. Mixing jic and -an fittings?....
  140. What Exactally Causes Heat Warpage?
  141. crosspost from drag racing regarding fuel pump.
  142. Welding Aluminum with SP135??
  143. Is it ok to remove front mount and weld the rest solid?
  144. Powder Coating Equipment
  145. Swing out side bars **sliding sleeves**
  146. Riland TIG Inverter?
  147. home brew trailer
  148. RWD conversion... steering?
  149. How many of you taught yourself how to weld?
  150. LOOKING:Switch Panel
  151. Body Work Repair HELP!!! Front End
  152. Long tube header + Turbo bracing
  153. AirGas giving me the runaround? How do I get my used bottles filled?
  154. fwd "traction bars"/antiwheelie bars
  155. Alluminum Exhaust ???
  156. battery tie down methods?
  157. Completely Pointless, or is it...
  158. flexible exhaust pipe for chargepipes ? asaplease
  159. need someone to fab me seat brackets to fit rsx seats in a 5th accord
  160. Recommend me a belt sander!
  161. Making studs to weld stuff to the body
  162. Slide type flange
  163. repairing fiberglass.help
  164. streetable one piece front end drivers?
  165. Header donut question
  166. Two Wire or Three Wire for Thermal Arc 185TSW?
  167. resurfacing flanges
  168. Top cylinder brace ?
  169. "Emergency" water drain valve for spare tire compartment
  170. where to get eye bolts with swivel
  171. How to weld a bung onto a pipe?
  172. Cost of wiring shop for 230V
  173. Custom Radiator mounts?
  174. Crx Hood Please Help!!
  175. Flowers for my girlfriend.........
  176. H22 Crossmembers bent to the left
  177. Cam gear cutout?
  178. h22 dog box
  179. Where to get metric fine thread, fully threaded bolts 12mm+?
  180. plastic injection molding near va/dc/md
  181. Gas Cylinder?
  182. Crx rear fender rust, HELP!
  183. Yet another one of those "first weld" posts...
  184. surface prepping SS and mild steel, special wire brush needed?
  185. Stainless or mild?
  186. Filling side marker holes in bumper?
  187. If you want to learn how to MIG weld ive got a dvd for you
  188. Need a hand control TIG torch
  189. fabing interior pieces for crx
  190. Aluminum piping for intercooler wher to buy?
  191. Welding Aluiminized steel
  192. Cutting moons into piping. HOW TO?
  193. any one ever convert a d series shift linkage to bseries?
  194. RHD conversion
  195. Strait Line Specialties...
  196. Shipping from mcmastercarr ?
  197. how do you expand thin wall "exhaust" tubing easly?
  198. RSX Seat brackets for EK are COMPLETE!!! *56K death awaits you*
  199. Missing something?
  200. tigging v band flange right to exh housing??
  201. Welding exhaust downpipe on my first try, use "slip-fit" sleeves as a backup?
  202. How do I take a 12mm stripped bolt out?
  203. Heatshield configuration.
  204. mig tig welder?
  205. Aftermarket Caliper mounting brackets
  206. 4 bolt t3 downpipe flange source????
  207. Dont know if this belongs but...
  208. So I made this exhaust system...
  209. Will this hold up?
  210. Need to change compressor outlet direction...
  211. Need a 3 bolt flange and gasket for stock crx piping, 1 7/8" I think
  212. Custom fabbed oil catch can... show yours!
  213. RMF new location
  214. my DIY ITB and vacuum log progress
  215. got my itb flange/runners
  216. Repairing Header
  217. Fuel Rail Fab
  218. does anyone make aluminum intake flanges
  219. Power plug for TA 185TSW?
  220. Mig welding experts need some help
  221. can anyone fab up some forks and lcas?
  222. 2.5 inch 2 bolt stainless flanges?
  223. welder
  224. Harbor Freight bandsaw review
  225. my door is bLah...
  226. Log manifold, cutting the fittings
  227. Best place to get stainless steel wire wheels.
  228. About to buy a Hobart Handler 140, which gas tank best fits my needs?
  229. ...need to find a shop in so-cal to install my glasstop ASAP...
  230. Can I use oxyacetalene to...
  231. OT, How many machinists do we have here??
  232. nsx exhaust flange question, and who has misc. flanges in stock?
  233. HYtech exhaust!!!
  234. Front cross member turned into a traction bar?
  235. Buddy Club SideSkirts on 92-95 2dr into 4dr coupe
  236. Mig welding tips/questions
  237. need someone to extend my bike swingarm..
  238. Where do I buy the flange from my downpipe to cat
  239. Need someone to make me a manifold!!!!
  240. Coiling Welding Cable.
  241. Anyone have a 1/2" tube bender?
  242. foaming the chassis
  243. Matco Tools WFW140 Mig Wire Feeder, Anyone dealt with?
  244. Weldcraft Tig Torch Help!!
  245. Proper Spot weld subframe procedure.
  246. Trying to build a manifold...need advice!!
  247. Any recommendations on what blade to use with a hacksaw cutting steel?
  248. Making an art project for school.. lol
  249. why do I not hear of people making headers out of Ti or iconel?
  250. welding fitting in oil pan. any advice?
