View Full Version : Welding / Fabrication
- Help me find this flange!
- replaceable head tig torch
- some updated shop pics and some industrial projects
- I need to know what the correct name for this is.. An eyelet of some sort.. Pic inside
- fabricate a piece to raise suspension a bit?
- Intake Manifold Design question never asked
- Welding 304 with NiRod44
- Looking for TIGHT 2.5 Ubends
- Anyone ever use this bender?
- general question about welding...pics
- installing takata harness into an ej8?
- need frame straightened!!
- To: All those in here who help and aid in assistance...
- DIY muffler theory. Does this sound like BS to you?
- Post up your 4" Exhaust/DP
- Calling all weekend welders, in SE Pa, South Jersey, or Delaware
- Super 6-Point Cage in EG Hatch
- titanium grading
- Contamination issue, few questions.
- 321ss manifold questions
- Do you know what this tool is?
- how do i calculate tubing weight by specific weight and wall thickness.
- Attn: Good Al. Welders :) .....
- Need a dump tube!
- Cheap stainless bends, polished or non polished
- Cheap Aluminum bends 1.5"-4"
- Best method for cutting endtanks off of an Intercooler?
- oval silicone coupler?
- RMS ramhorn t3..check it out mang
- my wleder stand
- 1.8t manifold
- critique my welds!!! newbie to tig
- Spintech mufflers?
- Cage is all done...
- Painting rollcage question
- Tips for welding cast alum ?? Anyone shed some tips
- Radiator cor support
- Anyone use a Chicago Electric EASYMIG 100
- skining a door
- RWD CIVIC??
- exhaust gasket material??
- Looking for the affordable spot for v-bands
- side exhaust...
- Cutting out old quarter panel?
- Anyone use Pyrex cups?
- What happened to tigdepot.com? Need small tig torch...
- Recent fab work 4" DP - Not Honda!
- non-aluminized carbon steel.
- tapp size for 02 sensor bung??
- Intake manifold design question.
- Looking for a 3 bolt exhaust flange
- what aluminum to use for a catch can?
- quick structure question
- liability issues anybody??? waiver?
- turbo manifold material questions
- ATTENTION Madison, Wisconsin AREA WELDERS!!!
- Lincoln welding school?
- Is it possible to control expansion and distortion of runners welded seperate from the manifold?
- What happens when you put a 179whp B20 in a 34 year old civic
- Header fixture ideas?
- Where to source out, metric barb fittings ?
- Thermal Arc TA185: What are your settings for aluminum and steel?
- Mig Aluminum Spool Gun?
- Rewiring Engine harness ground.
- Stamped or etched metal tags (for branding manifolds)
- Entry level MIG
- Full Race Cage Kit Installed Photos
- So who sells d series intake flanges ?
- How can I fix this (tapped holes)
- what is a good assortment of cup sizes.
- head studs?
- Cp2 titanium to SS?
- Pics of swing out bars?
- I/C piping question.
- Critique my first manifold..
- Catalytic / Header Aftermarket Flange?
- What hydraulic tubing benders are people using?
- Welding stainless
- Critique my welds please! Tig(GTAW)
- roll cage tubing
- air compressor Q
- Exhaust Fab ?
- -10 an drill bit size?
- Engine bay shaving tips and techniques. Anyone have any?
- INTAKE PLENUM FOR TWM ITBS.... iacv?
- Weld progress pics...
- Adding A/C to a 99/00 SI with a turbonetics blower
- SR20 Intake manifold
- diy topmount - first manifold
- Need a welder ! Southern California***
- Lincoln Invertec 205
- Making a custom airbox.
- V.2.0 of my welding after some advice by members here...
- distributor cap
- Cheap Bender, What do you guys think?
- Nissan 240SX RSR ExMag Exhaust on a prelude
- Looking for a Tig Welder AC/DC
- my first N/A header... something a bit different.
- Oxy/Fuel cutting goggels.
- Rate my welds V.1 from myself...
- Sump Check it out
- Turbo mani
- tig with brass rod
- DIY HOME DEPOT LIP
- Want to box/silence my compressor cheap, any ideas?
- where to get a m12X1.25 die?
- New exhaust I made for my M-2
- 3.5" Cannister Exhaust
- just some weekend fab pics not much
- anyone got a printable draw\sketch of a standard 38 mm wg?
- Building my first tubular manifold, a few Qs
- VHT interior paint??
- I need flanges made!
- 6 point rollbar
- Some bent tubing welded together.......
- welding
- What kind of welding is this?
- affordable bead rollers?
- Finally!! RMS divided t4 top mount
- Custom Prelude Exhaust?
- Welding engine bay
- Scary stuff
- Any custom air box's?
- Keep Burning It Up
- Custom catch can need some input.
- Stitch welding chassis...tips, how to's, etc?
- Need welding help
- I think my Syncrowave crapped out....
- Which welding helmet
- another 4" alum exhaust...
- Mig welding stainless
- Recent fabwork (Top-mount GT30R kit) pics!
- Frame repair project: 1992 Civic VX
- my welds suck please help
- D15b2 header???
- Aluminum exhaust question
- Anyone still ARC/stick welding???
- I need some piping
- How can I get big old fatty welds on sch40 pipe?
- where can I get a block of aluminum?
- Looking to start welding, is this mig worth anything?
- good place in va to get a cage done
- 3 phase power?
- who makes intake flanges for the K?
- miller syncrowave 200
- entry level Clark welder from Menards $199 (no good at all? )
- Building turbo manns....
- change the auto seatbelts
- diy fuelrail sugestions wanted.
- Saw this in the prelude forum: what do you guys think of something like this?
- 3D Scanning
- Source for NSX flanges?
- How do you weld runners to parallel collectors?
- CRP Turbo HulkHB
- Where to get 6061 or 6063 in 0 temper or 1 tubing.
- Looking for and Aluminum Tig welder in the South NJ area
- Bondo on inside ot rear quarter panels?
- Cutting a car up (I own it)
- I <3 my honda cut out
- where to get a single SS exhaust port flange made?
- any professional welders here?
- Got a Flexpipe question...
- Fabrication Torrents
- Topmount Fabricators Chime in
- welding exhaust and ic piping with wire welder? (mild)
- 3.5" bends
- Cut and weld stock seat brackets?...
- MIG aluminum and no gas?
- Waterjet service?
- Welding the Diff to mae it Perma-Locked
- crx clip conv.
- Gold heat tape?
- Tig Newbe...Tips...Do's... Don'ts...
- What is this called?
- aluminum exhaust
- Size miter saw for cutting?
- ghetto M5 twin turbo kit
- radiator/core support
- aluminum welding ?
- ATTN Exhaust Gurus. X-Pipes?
- Machine work SS VS AL
- Something different: P/S rack to manual steering rack bushing
- Mig Troubles - Welds are inconsistent
- old honda pics
- What kind of polyurethane is hasport mounts?
- 2006 Si exhaust
- Roll cage/bar install, any liability worries?
- Installed resonator w/o welding?
- How to back purge when tig welding ss
- Roll Cage builders
- Fiberglass and plastic...?
- Resonators?
- Removing sound insulation
- Roll cage builders question... CRX main hoop location?
- roll cage sites???
- Stripped bolt thread on crankshaft! What to do?
- old nissan pics
- New Fab table!
- N1 exhasut will not fit!!!!!????!?!?!??!
- Who would have thought a lift kit was 6 bucks?
- Setup/Build Traction Bar Control Arms - How Do You Set Them?
- purge and mig welding
- External Wastegate Adapter Design Help
- Just a few pics of what's happening around the shop.
- welding truck ;p
- Looking for a good band saw.. any suggestions??
- kens kustom chassis roll cages
- having a hard time finding thread chasers
- Some tig welding questions.
- Hi Guys, please give me your opinion on this
- CK rotary amp controller
- tial turbo housings?
- Anyone stock greddy wastegate flanges?
- Couple pics of my jmfabrications.com 3.5" aluminium exhaust
- nedd body and paint great quality and cheapest around
- looking for a welding supply store in toronto canada
- Gas tank welding/repair
- Recent pita fab job
- Where can i buy a d16 intake manifold flange ??
- New little....little....toy
- anyone know how to weld radiator support?
- building a cage out of pcv
- A Not So Simple 4-Point Roll Bar
- tube chassis and wheelie bar help
- Twhere to buy GARRETT intercoolers for less $$$$?
- need paint and body anyone cheap proffessional
- 180° sch40 fitting
- roll bar
- Composites Fab, Where's my hood?
- looking for 6 into 1 merge collector, 4"-5" tall
- Anyone know a website that sells totaled cars?
- materials for turbo manifold
- Intercooler end tank supplier?
- where to buy new oem harness plugs and pins
- need a collector built 3 into 1 2.5"
- Received my Manifold, have ? Possible big pic warning..
- Headers Galore! :)
- So my Miller Maxstar crapped out on me today...
- front strut bar round tubing material/size ??
- Quick Question About mounting intercooler sprayer..
- Does anyone here make equal length manifolds at a good price?
- Not honda but some serious fabrication. 800hp trackday taxi
- you know your traction bar is stronger than your frame when...
- painting hood
- weld/lathe pics
- Stainless Intake Manifold... cons??
- A simple 5pt cage
- My new toy....
- Beginner welder seeking advice
- My new Intercooler Piping
