PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47
  1. SRT4 head flanges, 20 or so...
  2. Alrighty Modifying seat brackets to fit a different model!!! HELP!!!
  3. greddy header 2'' to 2.5'' collector mod.. help!!
  4. DadFab Top Mount Manifold, 4" Downpipe
  5. Any HYDRAULIC guru's here?
  6. Fuel tank coatings?
  7. carbon fiber intake
  8. tig question
  9. who makes runners for custom itbs
  10. manifold material?
  11. 3.5" 3-bolt exhaust flange
  12. anybody need CAD drawings???
  13. Fiberglass guru's, come here
  14. What filler rod and Size for Welding Unibody Metal?
  15. anyone else hold there breath?
  16. need advice on how to remove rust inside pipes.
  17. Where to buy a Carbon Fiber sheet ?
  18. Info needed for Cast Iron work
  19. Welding Classes
  20. SS Collector
  21. skyline manifold
  22. check out my brazing! (pics)
  23. Any difference between rosette weld and spot weld?
  24. Complete rewire. Anyone use anything other than a Painless wiring harness?
  25. mild or stainless tubing for ic piping?
  26. Drilling Spot Welds on USDM & JDM Firewalls...
  27. Best (cheapest) place for Adel Wiggins clamps?
  28. b16 intake flange
  29. My new Full 3" exhaust...
  30. SPOON SW388 question
  31. Porting Tools...Choice of Professionals
  32. Hondata style intake manifold heat shield/gasket.
  33. Flipping house fuses welding at home.
  34. help with welding aluminum.
  35. show me the argon feed to your welder..................mine looks weird, not sure its right
  36. Is the OBX Turbo Manifold any good?
  37. where can i find the best price for 3.5in ss exhaust pipe?
  38. Which of these courses should I take to learn how to weld?
  39. welding a header
  40. want opinions
  41. question about flange
  42. Band saw advice
  43. Should I return my chop saw?
  44. tig and mig question
  45. Aluminum MIG'n. What Voltage, wire speed, gas psi for best results?
  46. need help...first time tig welding
  47. clamp on exhaust pipe
  48. Tube bender for doing roll cages????
  49. welding cast iron
  50. painting
  51. Brown soot .
  52. turbo mani
  53. welding piping with a t3 flange???
  54. Mig welding stainless steel ?
  55. is this welder any good?
  56. 8pt Roll cage .
  57. Head flange for D17 civic (01+)
  58. Questions On Welding Sch 10 Pipe
  59. Chromoly or Mild Steel
  60. gauge metal and adjusting settings......how do yo uknow
  61. frame was pushed back in an accident. need your opinions
  62. building a muffler?
  63. *** Help!: Place That Sells 5" Mandrel U-Bends ***
  64. Preflow vs postflow?
  65. What size Tungsten is good to start out with to learn how to tig weld?
  66. Who will build me a custom turbo exhaust manifold?
  67. Fab shop owners.
  68. I just recieved my cnc'd head flange........... thanks anthonycn
  69. when welding roll cages, how to weld the top of support bar?
  70. Measuring Runners ITB's
  71. Re-anodizing a Part
  72. What size wire??
  73. Does anyone know anything about HTP America Inc. products? 110V TIG welder
  74. cheapest mandrel bender
  75. Where to buy 3.5" exhaust flanges?
  76. Need help.. Problem with block.. welding needed
  77. whats lighter stainless or mildsteel
  78. Is there a proper way to roll fenders?????
  79. Exploited racing
  80. diy equal length manifold questions....
  81. Spary gun question
  82. bended pipe pictures wanted !
  83. anyone know where to get offset honda prelude exhaust flange?
  84. started brazing today...
  85. ANYONE KNOW OF ANY COMPANY OR PLACE TO GET A 6 POINT ROLL CAGE IN RED
  86. Input on my welds...
  87. question regarding MIG welding w/ 100% argon
  88. Fiberglass in a high heat app?
  89. robotic welder or cnc welder?
  90. Question about rust..don't know if this is the right forum but hell ill try!
  91. good info on stainless steel
  92. fillet weld help when tig welding aluminum
  93. O2 Sensor Bungs & Plugs - where to get online?
  94. input on a strut bar design and some other chassis braces
  95. WTB - B-Series Exhaust Flange
  96. Question concerning small bandsaws???
  97. SPOON SPORTS!!
  98. Where can I find a 4 inch to 3 inch reducer
  99. post pics....of DIY lexan windows<<<
  100. What do you pay for SS tig wire?
  101. A2 vw ABA turbo project pics
  102. Solid mounts DIY
  103. Tell me if this is a good deal?
  104. Does anyone make auto-2-manual swap mounts for a DA?
  105. my first real project
  106. Which Robot Welder to Get???
  107. welding SS need advice
  108. Help on welding .055 aluminum intercooler tubing
  109. Fabricating a new dashboard
  110. tryed Arch welding for the first time today
  111. Difference between chromoly and mild steel??
  112. Quality CNC'D b series head flange
  113. DP madness :D
  114. My 24-hour work-a-thon....
  115. Using stock 94 Integra seat brackets, rails, and sliders for Bride seats?
  116. where to get small degree bends to make collectors?
  117. Welding alternative...???
  118. h22 mani pics
  119. Price to modify cat?
  120. Gauge steel help
  121. What are you guys using to bend sheet metal ?
  122. How to make the chassis more rigid? Welding?
  123. roll cages/welders
  124. which band saw should I get? Help!
  125. Who does good exhaust work in Jacksonville FL?
  126. adaptor to change turbo flange?
  127. what cnc mill to get for making ss flanges
  128. welding costs?
  129. need help with my welder
  130. Can someon show my how to remove spot welds?
  131. Custom Manifold pics..
  132. DIY sunroof plug?
  133. All wires directly to ECU?
  134. Questions on SS Welding
  135. wtb:econo tig
  136. need some one to weld something for me
  137. DIY manifold
  138. career related question
  139. $2 ITB bellmouths!!!
  140. diy manifold kit??
  141. help me....how do i make a circle in the metal flange?
  142. I used ls springs and retainer to make this
  143. those of you with full-race a/c manifolds, mounting ac condensor
  144. Which MIG Welder?
  145. What to use to make a rollcage
  146. Composite tubing?
  147. yay!, im learning! couple of questions though...
  148. take a look at my cage (legal to run 9s)...questions & concerns (alot of pics)
  149. machine shop cost... DONT LET ME GET SCREWED
  150. i have a queston about welding
  151. in the market for a tool box - suggestions?
  152. Full Penetration Weld pics
  153. tubular control arms?
  154. Hobart or Lincon tig
  155. $80-$120 ebay 90-125amp flux-core MIG welder good for turbo exhaust/downpipe work?
  156. Custom Brake Lines
  157. Stitch welding, worth it?
  158. dual webers anyone? *pics*
  159. Dremel Question for fog light install
  160. 92-95 civic front air damn/spliter
  161. "Dry" Carbon Fiber vs. "Wet" Carbon Fiber
  162. Eg subframe reinforcement plate
  163. Some fab. work
  164. Chromoly Tubing Prices?
  165. urgent question- about tig welder considering purchase please help
  166. fal windows need help
  167. RSX Type-S Custom Exhaust & Tune
  168. Exploited racing
  169. Lambo-Door hinges?
  170. Would this be ok for downpipe?
  171. custom exhaust price
  172. custom ply-wood front splitter
  173. Critique this manifold!
  174. ROLL CAGES
  175. PLASMA CUTTER what are your thought about this unit
  176. Who moon cuts valve covers?
  177. Cool friction welding video
  178. Roll cage pics
  179. 309 Filler
  180. Welders in SE PA - anyone free sunday march 6?
  181. Would you do it? (plan inside.)
  182. Question for one of my boys?
  183. BMW TB with honda bracket
  184. who has a CNC machine?
  185. filled in my side moldings finally!
  186. Integra Brake Line Fittings
  187. Any HT vendors sell (2.25 stainless 304)?
  188. Need opinions before building C-pillar brace
  189. what size wire for general welding
  190. Ready to dive in.... but am I getting the right deal?
  191. my ghettofab dsm bov flange
  192. Any fabbed torque mounts here?
  193. Opinions on Miller Econotig
  194. NEED HELP:Welding RHD Firewall into 94 Hatch Si
  195. Exhaust help
  196. weight of different types of steel
  197. Aluminum Weld bungs
  198. Flexpipe size.
  199. HF manifold heatshielf
  200. Does anyone make custom carbon fiber hoods???? Need to find someone who can work with carbon fiber.
  201. tig welder
  202. post pics of your "work stations"
  203. finished: integra projectors into my miata
  204. collectors: welded or seamless?
  205. If you know anything about FSAE, please come inside
  206. looking for STAINLESS tight radius 90's...mcmaster=nope
  207. making mount adapters and need advise and expertise.
  208. My Lotus project- Operation Bushings!~
  209. what your technique to desolder roms.
  210. how long should a large bottle of argon last?
  211. How long do i HAVE to wait
  212. Problems using stainless wire in MIG setup. What pressure to run 100% argon at?
  213. Aluminum used in Moroso oil pans?
  214. what is 3.7 mm thickness compared to?
  215. diameter of hole size on header flanges??? please help
  216. Adapter Plate Gurus!
  217. (pics) Turbo kit that we're Fabbing
  218. Last minute advice, purchasing intercooler bends
  219. Rollcage Diagram/Plans?
  220. Water to Air Intercooler Tank
  221. any tips on arc welding?
  222. any tips with mig welding stainless steel? do I need dif. wire?
  223. carbon fiber
  224. Tight U-bend
  225. welding honda valvecovers a problem?
  226. Autopower U-Weld Roll Cage...SCCA/NASA Approved??
  227. nothing special, just another diy manifold
  228. around $500 for a welder to do body work, suggestions.
  229. another "what do you think of this welder" topic
  230. EF Traction Bars
  231. Just wondering if anyone has every used these
  232. crackling and popping whenyou start to mig?
  233. Fiberglass: Mat or Cloth?
  234. Made a big hole unscrewing that goes into frame..need help
  235. When doing 2-1 meges how are you making them match up?
  236. doin some real engineering
  237. DIY carbon fiber Panel
  238. exhaust customization will it work
  239. hobart 135 vrs lincoln weldpak-100 reviews plus wire feeding aluminum results
  240. What do you call these things ?
  241. internal wastegate welding
  242. Any advice for cutting nylon 6/6?
  243. tools/tool boxes
  244. ARC questions
  245. another one of those how much piping.... sorry
  246. Muffler Shop ?
  247. i need a nut
  248. ok well heres my 2nd day of mig (about 3hrs of welding under my belt)
  249. Some of my older custom fabrication...
  250. This manifold WILL get you laid...**56k-well worth the wait**
