View Full Version : Welding / Fabrication
- manifold picts
- critique this weld please
- Welding Schools in SoCal???
- Powder Coating Engine and Tranny
- hand laid (race) fiberglass front end.
- Which is the better cutting tool ?
- Hobart Hanlder 140 VS. Lincoln SP135T
- PSI vs PSIG
- 4" Exsauhst PIPE 304L
- careers in welding???!?!?
- Stupid welder problem question.
- intake and exhaust flanges D series
- Pictures of my work and a 6 pt. cage I just finished.
- New AR Fab H22 manifold!!!
- Collector for a T25 flange(GT28R)
- what epoxy to use for carbon fiber intake runners mating to aluminum head flange??
- Recommend me a welder... I need an upgrade
- Hobart Handler 175 good/bad???
- Welding tubes together (Downpipe)
- how much does it cost to...?
- Pics of FAbmans L.A.I for Team Laskey....
- a great example of using inconel
- What material should i use? (adaptor)
- Mig welder from MAC tools worth it?
- Anyone hiring a welder/fabricator
- 4-2-1 turbo mani design??
- Making a cage
- Intercooler Tuck
- wireing a miller 175 220v
- Need help getting someone that can make a steel sterring neck
- Thinking about a "beginner" welding machine?
- 3" flex pipe
- Pro FWD Cars: Cage Pics
- What do you use to cut the square or hole in logs?
- Starting to make manifold :-)
- Extended top hat studs??? Mounting strut brace directly...
- where can i make my integ right side driven in so-cal
- does anyone sell a k24a4 exhaust flange?!?!
- Lincoln 135?? Good welder to start on?
- Plastic weld
- custom intake maniflod?
- TROUBLE SHOOTING TIG PROBLEM
- Test pipe
- cutting oil?
- MIG technique (on tubing)...
- Stipped Bolt
- Single phase vs. Three phase
- Holy shit! Can this be fixed?
- Manifold Runner Question
- my diy dsm 4g63 turbo manifold
- Machines to cut piping with and other materails
- SOME REAL FABRICATION!
- ::Welded up my New Suspension, HAHA::
- Aluminum dash instalation any tips or pictures?
- Fab'ed Moroso Oil Pan
- Lincoln 185 pr syncrowave 180
- BLOCK LEAKS OIL
- Old chassis pics.
- anyone ever use brazing rods?
- Welding a beer keg
- Turbo Manifold Materials and Size
- Checking a 220volt outlet for welder.
- Hasport's ef b16 swap header.
- Fabricating a frame?
- Looking for hinged 3 bolt exhaust flange
- made my first ramhorn manifold ~~~pics~~~
- Would this be a decent begginer TIG setup?
- what do you guys think?
- welding aluminum
- Arc welders
- Input needed on these welds
- radiator support
- why are these welders the same price?
- Custom reservoir for a/w intercooler
- My custom exhaust (pics)
- Plans for car ramps?
- few new pictures of my turbokit....
- water cutter aka flowjet
- best method to weld turbo manifold
- ABS Plastic - Best Way to Cut
- where is that ITB's w/intake thread?
- Retrofitting a midpipe with a bad flange
- TIG Torch angle for beginners...
- Which T3 Flange type is most prefered?
- Buying bandsaw..need advice
- cheap & easy alternative to exhaust flanges - Bailhatch version
- Props to all you welders
- New welding helmet
- some al tig welds
- collector question
- Intake/ice box
- welding cast iron
- Making custom turbo manifold?
- Robotic Welding
- Auto-darkening helmets
- good welding shops in atlanta??
- Possible to weld on ceramic coated pipe?
- Welding advice????? DONT FLAME ME I SEARCHED
- tranny to block bolt hole stripped
- Notching and Bending tube
- catco high flow cat, with or without O2 sensor?
- how much? is it worth it ?
- ITR Conversion no flamers plz
- Welding Pipe to flange (flat surface, etc) NEED HELP
- mcmaster elbows for manifold
- 3.5 vs. 3 inch exhaust piping......
- using B18 mock up motor for fab parts....really using a B16 motor.....anything to worry about?
- Engine Diapers MANDATORY!!! How to..
- Tap size anyone! HELP!
- New Narrow Style RMF
- External Wastegate Location
- Design programs ?
- intercooler has slight kink need help???
- can you weld aluminum to aluminized piping?
- how to decide what gas cup size to use>?
- Tig Torches for Collector Welding
- How to label switches on dash
- TA Seats In A Civic
- bending tubing
- Shock mounts
- MCmaster
- RS*R exhaust
- thermal arc dragster 85????
- Gauge Pod Fabrication
- first attempt at aluminum.......any sugestions?
- Mig for exhaust manifold?
- downpipe question
- downpipe welding
- Econotig vs. Syncrowave
- best way to clean the inside of a manifold?
- crx convertible
- TIG or MIG for Rookie Welder
- need help finding something???
- good boring bits
- Laser cutters ?
- guys that went or are going to wyotech....
- Carbon Fiber Curing
- which plasma cutter to buy?
- MIG welding wire for aluminized steel tubing
- This was NOT a good idea to try to make THIS as my F I R S T manifold
- What page at mcmaster for mild steel el's?
- where to get oxy/acetylene welder?
- Integra Door - steel or aluminum?
- good epoxy
- Great links
- Carbon Fiber Overlays, How to do them, and what to use?
- Best way to cut ABS sheet???
- first time welding this material...and first time welding a collector....let me know what you think
- Anyone used this battery powered impact?
- my new turbo manifold ( mini me style )
- homemade IC idea! Super low budget!!!
- PRELUDE SHIFTER h22 EK
- best way to purge your welds for headers etc...
- How does this look for a beginner?
- my first fab job
- Apex'i N1 with 2.5" Piping? Will it Work?
- any gopod recomendations for a auto darkening helmet?
- Minor accident, MAJOR PROBLEM
- Sub frame for a CVCC?
- way to FABRICATE seats to sit lower?
- Gauge chart
- looking for a header flange made?
- NPR Intercooler make-over.
- front end conversion question
- question about welding
- Making some Blow off valves.
- Are these made well ??????
- ITR Rim Question
- honda civic hatchback
- FAB?: Harness, Wiring, ETC ETC
- Fabbed a new fuel cell. Its the bomb !!!
- welding 4130 chrome moly...
- V-Bands as Exhaust Clamps
- Building turbo header, what pipe diameter and thickness?
- inverter
- Cold roll, hot roll, whats the difference ?
- Any one seen the new DVI's?
- I WANNA DO AN ITB SETUP FOR MY B20. PLEASE HELP!!
- What do you guys think of the NexGen EQC auto darking welding helmet?
- cutting open an intake manifold at home ?? help @!#Z
- is my convertor welded?
- Impact Absorbing Foam
- I am looking for a decent multi-purpose welder (tig is the most important)
- Can anyone here fabricate a manifold for a 4g63?
- Recommend me a Mig Welder
- Bay Area People 408 (Need Your Help)
- cutting 1/2" thick aluminum midplate
- I need a welder to work for me in the las vegas area.
- what my advanced welding class does when they are wasting time.
- DC Radiator and IC Chiller
- Personal Turbo Header...
- what size band saw
- A new type of welding: RIG Welding
- How many folk have built their own headers?
- need help with exhaust pipe fab, need to get from 4.5 to 4in
- Newbie Welding Questions
- carreres in welding/fabrication?????
- New to fiberglass, but need help with molds
- welding aluminum to steel?
- help busted mount on driver side block
- Atlanta - I/C pipe welding?
- header difference???
- adaptor plates
- what is the diffrence between 6061 and 6063 aluminum????
- My new MIG welding machine.
- TIG + Aluminum + Cleaning Question
- EXHAUST MANIFOLD FAB
- mateo 220 mig
- h22a1 turbo header manifold
- Pics for paul93sir (Please Ignore, 56k warning)
- "Plenum" Turbo Manifold?!
- NJ area exhaust
- tail pipe expander.. any experience?
- Could this be easily welded??? (my N1 muffler)
- Jet washer cleaner
- Carbon Fiber 101
- welding titanium
- 230 AC outlet - how much $$ to have done
- Plasma Cutter Not Working
- Critique: I laid a few beads down.. Noobie welder.
- 95 civic seats into a 91 civic
- How do i get the color in my welds?(tig)
- Should I even bother with a MIG or go straight to TIG???
- My 3" exhaust project, 4G civic hatch
- Tig'ing mild steel with different thickness....
- D-series turbo header questions
- New. Just want to Weld Exhaust Basically.
- How big of a bottle ?
- Flux Good to start with??
- DIY ITB ?????
- need help on LS seats installation
- Stainless Steal or Mild Steal for an o2 housing?
- Injector boss dimentions
- piping bend
- mig welding cast iron
- Hybrid Tig welder - Using AC/DC stick welder - Advise plz.
- how too determine the shade of the glass?
- welder question: i hate to ask
- Trouble TIG welding
- how do i get a regular account on honda-tech help please
- Homemade ATP Turbo VES-Assembly
- thread note for shift knob
- Local fab guy helps "one of them"
- Help me out!
- Flanges...
- Why did you lock my other topic
- Flux-core to MIG conversion question
- For all you fabs out there.
- Flanges....
