PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47
  1. What's the best way to fix Motorcycle plastics?
  2. Insulation question
  3. cheap painting on a primed panel
  4. Can I change the flange on this manifold?
  5. Buying and Airco 250 AC/DC TIG welder with waterbox!!!
  6. Quarter panel cuting questions
  7. Roof Rack
  8. Welding a partition in the spare tire compartment for an amplifier
  9. arc to tig conversion
  10. Working with fiberglass/carbonfiber
  11. Let's talk TIG welders
  12. Good welding bench plans
  13. Quick drain fittings?
  14. How to shave emblems off a DC2 bumper?
  15. Metals Technology. class that i am taking
  16. welding valvecovers please help
  17. Where to buy materials?
  18. Millermatic 175, good welder? advice
  19. First time fiberglass
  20. So I finally got my thermal arc wired up and got some gas
  21. 95 hatch auto to man
  22. Good welder to start with?
  23. Grade my welds Please (56k I dont know)
  24. HPC coated slip joints
  25. Easiest and most trouble-free wire for exhaust pipes?
  26. For the DIY mani people...
  27. Header Size as a Function of Exhaust Valve Diameter
  28. Need help
  29. WTB Stainless Steel b18 flanges!!!
  30. need help wiring up my syncro 180
  31. Where to find a reliable hole saw that will last for O2 bung holes in stainless pipe
  32. Who makes/does THE BEST thermal barrier coating for turbo manifolds?
  33. anyone have some CAD files of flanges?
  34. What TIG are U using?
  35. Miata: flip up headlights going to lowprofile integra projectors
  36. arc welding a manifold
  37. Hardest way to put an engine in...
  38. manifold material??
  39. Wiring up an outlet for a welder..
  40. got miller syncrowave 180..need tips
  41. bandsaw blades
  42. mild steel 90 bends and tees
  43. cutting/drilling .375" acrylic??
  44. Which welder to use for sheet metal?
  45. need: t4 flange with hole cut to use 3" tube?
  46. any place or person that can make me a custom turbo inlet flange? need ASAP
  47. pics of log manifold i started today
  48. Anybody make intake manifolds?
  49. Quick question about Stainless Steel and Mild Steel....
  50. A link for those who think Oxy-Fuel welding is dead.
  51. question and opinions on this lincoln through ebay....thanks
  52. Cutting torch ?
  53. I need 15 degree bends!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
  54. Cleaning charge pipes? keywords: clean intercooler piping oil
  55. Technical Schools??
  56. In-car camera setup & scanner antenna mount....
  57. max temp safe for jb weld?
  58. Where did all of you learn to weld
  59. do you have size problems?!
  60. New tool
  61. Is it safe to chop, and weld a driveshaft?
  62. Tig Help please
  63. a poor man's carbing 3pt strut bar
  64. Flux vs. Mig
  65. Body Shops In WI?
  66. 4x100 hubs
  67. welding galvanized steel onto mild steel
  68. need s2000 head flange
  69. carbon fiber process
  70. How good is this welder
  71. Help: Head Flanges warping after tig welding...
  72. dents on the bottom of headers
  73. good welder???
  74. Has anyone used the harbour freight tubing bender?
  75. guy screwing friend around need help..
  76. cage plate pics...will these pass tech???
  77. Critique this Rollcage
  78. Thinking about a the lincoln invertec 205. opinions?
  79. Should I replace rear quarter panels?
  80. 88 CRX Sunroof weld
  81. Redbull and TIG welding :p
  82. SSAC Man
  83. bought a new welder and im seccond guessing it
  84. Pics of my port and polish work
  85. Tig torch cups, what size do I need
  86. eletric die grinders.. can't use air.. anything good out there ?
  87. weld turbo to turbo mani question..
  88. Miller 250dx or Lincoln PT275?????
  89. Bench Grinder Pedestal on sale $14
  90. SNAP ON TOOL QUESTION WHAT TO BUY ??? I HAVE A NASTY DISCOUNT.....
  91. how does this manifold look?
  92. Where to Cryo Treat parts in Southern California?
  93. Collector Jig Geometry
  94. Opinions needed on my first manifold
  95. Update on the V8 RWD civic.
  96. h22a coup back to b-series
  97. GhettoFAB ram horn manifolds... I'm the BEST!
  98. Please help me decide!!
  99. How many people sell full race style manifolds now?
  100. Spoon N1 muffler metal?
  101. cx manifold turbo adapter
  102. whoever said making collectors was easy, was......
  103. Collector (stainless)
  104. Aluminum seat brackets
  105. smallest cheapest mig
  106. Fuel cell in a HB???????
  107. Wyotech, technical schools?
  108. Can i install SUbaru Impreza Seats on an EG6?
  109. Adapter
  110. pics of my ramshorn style manifold for B series
  111. Exploited racing
  112. sick of my POS MIG, buying a TIG. how is this model?
  113. What tig rod to buy
  114. header: crap or not
  115. ANy welders in the Los Angeles AREA ?
  116. Spool Guns; Which to buy??
  117. HID retrofit into halogen headlights housings, help
  118. carbon fiber hood???
  119. Whats the metalworking eqivilent of a protractor?
  120. A couple more backpurge pics(8 guage).
  121. Welding a harness bar into a AutoPower roll bar
  122. TIG Techniques
  123. crack on bottom of tranny.
  124. What type of MIG Wire...
  125. Radiator repair
  126. Learning to weld...place to start ?
  127. flex head torch
  128. titanium rollbar?
  129. I need stainless flanges for b18c1
  130. before I made another mistake.
  131. Grounding large pieces ?
  132. what CFM do you guys have your tig welder set at ????
  133. metal gaskets?
  134. pics of 90 degree pipe weld together
  135. mig welding aluminum
  136. how can i get my hands on some......dont wory its fab related
  137. Hey, MIG can get it done sometimes =P
  138. the cost of a manifold
  139. any welders in palm springs area
  140. is this fixable?
  141. HTS-2000 for aluminum fabrication and repairs?
  142. where to buy supplies for making a down pipe and not exhaust pipes from checkers
  143. Inverter technology....
  144. Twin blade cutter
  145. I need a better cutting instrument
  146. Just a little bit of something non-Honda (Large Pics Zone)
  147. Flux Core Welding
  148. does anyone on here make carbon fiber pieces for sale?
  149. Fuel Sump Fabrication
  150. Having a hard time finding welding class's in the Northern Metro Detroit area.
  151. SMAW welding rod sizes
  152. tig from home uses.
  153. Mandrel piping question
  154. mild steel manifold
  155. What advice would you give a first time welder along with what welder to get.
  156. welding hood cable for anti-theft reason
  157. anyone have pics of their custom intake?
  158. True opinions of Miller 330
  159. My first night MIG welding, some questions
  160. Header and tube pics
  161. Updates on the H22 manifold for those that requested........
  162. whats your method of preping your material before welding
  163. Beginer
  164. finished top mount pictures
  165. which belt sander?
  166. RI area welders?
  167. another DIY manifold
  168. anyone on here makes roll cages?
  169. EG radiator into ED mount fabrication
  170. help on my harness bar design
  171. Wanna make an ARC style air box and need some help....
  172. 1.5" V band clamps and flanges?
  173. Shop GLoves What you use ?
  174. Wire feed gas mig turned into a tig welder?
  175. hellp with som fab questions
  176. which Tungsten Electrodes?
  177. donuts
  178. need help with ITB's
  179. Need Help Need New AC System ~FABRICATIONED~
  180. Mig Welder Question
  181. Using a nylon/teflon liner for aluminum AND steel in a MIG gun?
  182. Aluminized piping and heat
  183. Tubing Benders
  184. Anybody make a camber kit for their civic?
  185. About the Lincoln BS pulser feature...and why I don't like it.
  186. Question about welding FMIC pipeing
  187. Got my mani, do these welds look okay?
  188. HELP QUICK! Bumper welding...
  189. my not so diy arc box
  190. *Official Bandsaw thread*
  191. Solid Motor Mounts.
  192. Lincoln Power MIG 215 welder.
  193. check out this degree/angle tool
  194. Any opinions on my new welder- Clarke 180 Amp MIg
  195. Not a Honda
  196. i'm burning through my 16 and 18 gauge steel pipes
  197. Lincoln invertec 205V
  198. Have some questions about boosting D16A9-ZC
  199. fixing my ancient Linde arc/tig
  200. Who wants to do a little fab for me?
  201. DIY crank tool
  202. i need a roll cage!!!
  203. how do these welds look?
  204. titanium pipping for exhausts?
  205. What schedule piping should I use for Turbo manifold?
  206. RHD Conversion*****
  207. just finished my friends turbo mani. critiques please... 56k maybe....
  208. What's the secret? (Fiberglass and bare hands)
  209. Could you use a compound miter saw for steel ?
  210. Tools for civics...
  211. what BANDSAW do you guys perfer for fabrication???
  212. Exhaust/Muffler Shop in SOCAL
  213. Any special considerations when working with inconel?
  214. MIG'ing aluminum with 75/25 argon/co2?
  215. 5-bolt flange for t3
  216. Anyone know where to find custom 3" exhaust flanges?
  217. Headflange Question
  218. Is this weldable?
  219. What's needed to fabricate a 2.5" to 3" flared DP?
  220. How many people have welded an external wastegate flange onto an hf mani?
  221. Considering welding career...
  222. tri y header help!!!!!!!!!
  223. Where NOT to order flanges from...
  224. Weld Advice/Determination - TIG
  225. Got to use the new welder today!!
  226. Walking the cup for the first time. Does this look rite ?
  227. Exhaust piping question?
  228. grinding a straight edge on thick sheet metal
  229. help with dp.
  230. Pics of my cage
  231. My first Welder ... Help
  232. Trying to Weld my JDM Conversion
  233. "Rocking the pedal", pulse generators, rod size, and TIG techniques. 56k go away
  234. Any shops use cad in their products?
  235. Opinions on best way to learn to weld
  236. backpurge pics, downpipe
  237. Tube chassis project
  238. Need something CNC'ed maybe a few of them!
  239. header flange
  240. New receptacles for the garage - Welders - how many amps?
  241. Building my car and fabricating parts...need some input.
  242. stainless steel vs aluminum (searched)
  243. AR Fab at it again!!.................
  244. Just finished my 2nd mani
  245. Learn: how to?
  246. Twin side mounts
  247. Welding Gas for Stainless Steel: Argon or C-10?
  248. Where to buy HF arc starter
  249. Band Saw Blades
  250. manifold picts
