30amp 240v 3 wire weld plug
I just acquired a Lincoln Electric 180 weld pac that has a 240v 3 prong cord. ( dryer style )
Lincoln Electric Weld Pak 180 HD Wire Feed Welder-K2515-1 - The Home Depot
My question is too all you welder guys, How are you getting your 240v power source?
I did some research but if any of you can chime in please do, My breaker is about 50ft away from the welding station. Can i just run a 3 wire inclosed female plug setup to a 30amp breaker? RED & BLACK " HOT " & WHITE " GROUND "
Re: 30amp 240v 3 wire weld plug
I just added an outdoor electrical box just below my breaker ran 6/3 cable to it. Then I use a 50ft 8/3 outdoor extension cord to get power to my garage when I need to weld.
50' 220 Volt 50 Amp Heavy Duty 8 3 Welder Extension Cord MIG TIG Plasma | eBay
Check the amperage output of your welder, my AHP Alpha Tig is rated for 40 amps so the typical 30 amp dryer outlet should not be used. If I remember correctly I used a 50amp breaker and 50 amp plug in the outdoor box.
