View Full Version : Welding / Fabrication
- Mandrel bend shops in Chicago?
- pic request: modified b16\b16 stock intake manifolds
- A few shots of my tacked H22 topmount GT30R
- need help"wire tuck" & "roll cage" on ef9
- Backpurge stainless downpipes?
- home fab shop. what do you NEED?
- any one using ARC welder sticks as tungsten?
- My First Downpipe (Pie Cuts)
- Audi A4 carbon fiber overlay (How To) over 65 pics!
- First MIG Welds
- Just starting(learning) to tig. What are the critical settings? Whats important to watch?
- Lookin for auto darken helmet with large viewing area
- welding stainless steel with a mig welder?
- tig torch replacement
- ODD QUESTION
- Brand new maganflow with incomplete weld on flange...
- My New Welding Table
- Rate my welds?
- Could use some help on another thread about manifolds.
- Welder Mig / Which is the best bang for your buck for at home running off 110v
- rusted frames
- Hex bolt thread size.
- manifold adapter
- More useful - horizontal or vertical band saw
- FS: Harbor freight tig/arc WITH PEDAL - nearly ready to weld just add gas $200 obo 4yr wrnty
- welder / fabricator wanted in pa
- HF start broken ??
- my neighbors already hate me so....
- EXHAUST PROBLEM !!
- beed roller
- Blasting media for cast aluminum block
- what you think of this engine stand i want to build?
- Has anybody every tried using a different speedo on your honda
- Just for fun, rate my Flux weld:
- A little Domestic Work
- Manifold Material Choice.
- t body's other than used bike ones for itb setup
- B-pillar 4/5pt harness mount (96-00 Civic)
- new project ek hatch lsvtec turbo (Charge pipes, downpipe fab)
- Probable repost: Opinions on $600 all-in-one eBay welders?
- quality of following flex bellows?
- How i spent my Thanksgiving....Euro style!
- Lincoln HD3200 opinions?
- Exhaust transition 6">1.75"?? Where to find?
- Anyone using the ellis bandsaw, if so post some feedback, also other bandsaw question.
- Tuner toys log diy mani question
- Tig question about welding mild steel
- warped cylinder head after welding, what now?
- General Flux Core questions from a n00b(no pics)
- fake walbro feul pump thread?
- Heavy-Duty exhaust hanger rubber
- ITB Manifold cost
- k-series
- Need to know where to get material
- Aluminum v-band
- comments on my stainless welds
- Few thing I've been working on
- Push bar on the 97 Civic DX
- what does ______ mean?
- AN line how to the earls end is there a how to or can someone answer this
- Need a catch can with 3/4" (19mm) hose barbs. Anyone help me?
- How to make a mold?? Please help
- piping question
- my exhaust
- Fuel Pump braket for the Bosch 044 I fabbed up
- Replacing cut out floor
- Why dont people build tubular mani's like this
- If building a tubular mani is it ok to mig weld then tig
- need help deciding what resin to use for my carbon fiber lip over lay
- intake manifold filler rod quest?
- fabricating seat brackets for aftermarket seats? (help)
- flare angle on power steering hardline? 45deg or 37deg?
- Backpurging with co2/argon mix?
- MIG welding Mild Steel to Stainless ... what wire should I use?
- Pics of more carbon fiber overlays for an Audi this time...
- AceStainless.com Now Shipping To Canada!!
- Shop Equipment for sale !!!!!!!! CNC Machine, Tig welder, Mig welder, Bandsaws
- New use for a D-series block
- LIL VAC BOX I MADE.....
- V-Band for exhaust?
- Need this -4 to -10 fitting anyone know were i can get it
- cant find large radius bends
- Fiberglass intake manifold?
- Fabbin a CRX Catback
- Where to get aluminum pipe with bends and long lengths?
- DIY - Make Your Own Tools. Wheel Bearing Remove/Install *DESIGNED*
- structural integrity for brake rotors question
- Syncrowave 200 settings
- Wierd Chrysler Exhaust Flange Fabrication, Question?
- aluminum plenum caps?
- a few pics from the daily grind...
- Designing a header for a rotory motor (rx8 to be exact)..
- Gas/Air masks for welding
- kevlar material?
- Anybody wanna make a del sol glovebox insert for me?
- Pic Requests: holset turbo's on ramhorns ot topmounts
- Need input on puttling a baffle in my catch can. Pics.
- Job
- type of metal
- any pointers on my aluminum welds?
- welding/cutting question
- well i picked my tig welder back today for the 3rd time in like 5 months
- Aluminum welding
- welding helmet?
- Have some questions, want to start tig welding.
- fiberglass molding
- JEGS 8-point weld in roll bar
- tranny has a hole
- Welded extended top hats, how safe are these?
- who used to make the cf sunroof plugs? and are they still in business?
- quick question. broken stud
- jb weld on exhaust?
- Noob: Tig welding T Joint *pix* and questions
- ssuspension design
- anyone know where i can get this carbon fiber piece at?
- Welding on a car! remove gas? or is that just for welding near the tank?
- Bandsaw Blades?
- Older welders better than the new ones?
- Straight Line Specialties is now hiring!
- neon dohc intake manifold i finished today
- harbor freight tig welder and sch 40 304 ss???
- 6-1 collectors?
- what kind of welder for cast iron??
- HF coupon?
- Tig welding question My welds blow
- Garage build thread request.
- wastegate elbow
- Anyone have any Casting Resources for Iron Casting?
- Treating Stainless Manifolds
- Need Help with Fiberglass Wing Fabrication!!please
- Whats bigger for diameter -12 an or -10 an
- i bought a lil clarke 95e 130amp arc
- GT FABRICATIONS GARAGE SALE **TODAY ONLY**
- 75/25 argon/co2 not good to tig ss????
- ef z10bar fabed to DA
- Anyone have pics of the BMC Race T3 Log Inlet installed?
- no more broken pedal assembly (civic/crx)
- whats your favorite stainless filler rod?
- how do you expand collectors like this?
- something a little different...
- Something for the 2jzge fans.
- Best way to remove surface rust from my hood?
- Welder
- frame ?
- AceStainless's Website is down as well as e-mail.. Any Clue whats up?
- Ring I made
- WTB: Collector
- where can i buy a battery relocation kit or a 97 civic coupe?
- Need help with the a/c lines (fittings)
- fabbing a 3" exhaust for EG
- a couple of questions before welding motor mounts
- collectors
- rsx cluster swap
- German fabrication company; race components
- Preparing to start my first manifold 86-89 accord a20a ramhorn t3/t4 with syncrwave 200
- post up pics of your turndown exhaust tips
- Vibrant Performance Fabrication Components
- My RHD EK9 conversion project (before and after pics!)
- Tulsa welding school Jax,FL??? pro's/con's
- Need machined spacers for disk brake conversion
- ARc welding or Mig welding which one is better?
- syncrowave 200 and aluminum
- All Motor Header Questions
- !!!!!!!!!!!!!!!!!!!!looking For Fabricator to Build!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- What material for making a plug (mold making, carbon fiber,etc.)?
- Using acetone to clean carbon steel?
- My manifold finally installed.
- Where to get dimple dies kit?
- Looking for a little information
- anyone in socal willin to fab rear 4point bar?
- Intercooler charge pipes..
- -AN Lines for Radiator Hose... How do you connect to water neck?
- Fender Bender.
- 2" 2 pipe T3 Collector
- Attempting to fab an intercooler
- Anyone know anyone selling a d series intake flange ?
- NRG tech HELP WANTED!
- Welder Purchase - Start My Fun, Start My Career - Need some help
- painting shop floors?
- Looking for a specific tool.
- I finally built my own traction bars-- how did I do??? (also a rear strut bar and airbox too)
- Where to get new pins for a K20 engine harness?
- What is the best method to remove surface rust from metal?
- RIDGELINE: anyone want to fab a REAL cold air intake for a ridgeline?
- Miller Econotig - Good/Bad?
- My New Bandsaw, I think its big enough!!
- Brazing help!!!
- anyone here make ITBs?
- Whats this tool? (oem honda)
- How to "edit" a muffler?
- piping in bulk?
- Front diagonals issues on Cage in an EK with Recaros
- 2.25 resonator?
- miller rhc-3
- should I get a tig or mig
- k20a3 exhaust flange
- divided 1&4,2&3 t4 collector.
- Need some help finding some stainless rectangular tubing...
- Downpipe I made today for vw turbo diesel
- Anyone ever use a "dry cut" miter saw for metal like this one......
- need more penetration
- Weight Reduction Stage 3
- forming lexan
- Deciding on a welder, need some input
- Pictures of 4cyl turbo headers for split turbines?
- Why do people make their t3 collectors round?
- What about these welds?
- Good for a laugh
- Looking For A Welding Job
- Friend's E30 turbo manifold, what do you think?
- how can i setup my tig for back purging
- Battery relocation kit?
- Turbo 5.0 Mustang sneak peak
- Cheapest vband supplier
- Full Race crossmember
- K20A Powered McLaren Replicar
- Aluminized steel, can it be flux welded?
- crx center console
- i need help tig welding
- Getting started
- Will this rad support be ok to weld into my car?
- How difficult to fix... strut tower rusted through?
- cleaning aluminum tubings
- manifolds
- Teeth of Hole gone.. screw wont screw [help]
- Fiberglass Fabrication
- Any aluminum welders in baltimore area for side work??
- Radiator Support
- welding thinner material on 60amp mig
- ....BMC's Collector...Not to happy...With this order...take a look......
- my first mig welder, but wtf?
- Dump Tube piping.
- Where can I buy Piping?Dump Tube. All I need is
- New to site, but no intro place
- Noob ? . difference between 2 welders?
- What gauge Aluminum for 4" exhaust?
- Sick 20V manifold build up (56k go to the bathroom)
- need evo8 16g turbo flange
- 93 Civic Hatch Roll Bar Questions
- My first manifold.....be nice
- Mild steel intercooler pipes, what to do about rust?
- Can anyone reccomend me any header theory/design books?
- 4 point belt install question
- It's fabbing time! Rollbar in an EF Hatch, need pics!
- Modded my strut bar.made a big difference!
- Stupid bondo
- raising top hats
- Just picked up a Lincoln Electric Pak Welder from HDepot...Noobie in the mix !
- Who welds aluminum?
