PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
  1. 321ss thin wall or 304 sch 10 turbo manifold?
  2. bluing 304 stainless???
  3. Anyone welded DC2 radiator support (JDM conversion)?
  4. Where to buy a 3" flex pipe ? (not ebay please)
  5. Pic Request: Autopower 4 Point Roll bar with proper 4 point harness setup in DA Integra
  6. custom intake box
  7. built another neon manifold
  8. Some crappy pics of my favorite manifold design to date...
  9. Double-Slip Turbo Merge Collectors question.
  10. ROLL CAGE ?
  11. B-series Intake Flanges Available!
  12. Bead Roller ?? For intercooler piping anyone ideas
  13. Looking for more info on these flex joints!
  14. Some recent fabrication!
  15. Still looking for my hood??
  16. 95 Hatch Cx strut swap?
  17. TIG Welding questions
  18. welding cast alluminum
  19. EVO Fab work
  20. Anyone use USC All Metal?
  21. Greddy TiC Exhaust
  22. Custom dp for gt turbo
  23. 95 Hatch CX Brake conversion
  24. Proto Parts, Turbo/Intake Manifold
  25. Cheapo plasma cutters
  26. Welding courses question?
  27. tig - electrode and filler size 16 gauge mild steel
  28. turbo sandrail
  29. Source for three inch collector/donut flange?
  30. 3/8 npt aluminum bung - where to buy?
  31. Got my new intercooler mounted and got the radiator back up to the front. Fab pics inside
  32. need someone to make 4 inch aluminium exhaust system in or near philly
  33. RMS does the D SERIES!
  34. Square plenum..how thick aluminum?
  35. fully welding structual pannals
  36. tubing size for a b16 manifold.
  37. remember the gas operated solder iron?
  38. Rate this MANIFOLD.
  39. Thermal arc users - smaller torch?
  40. Kens Kustom Cage in a 00 GSR
  41. welding delsol roof
  42. Help critique aluminum welds
  43. Post up your 16ga Stainless butt welds (no flange pics!)
  44. Price on making an axle back?
  45. Stainless bends for manis
  46. Who sells alumized small bends like 1.75"
  47. Exotic car performance shop hiring (Philly)
  48. redoing brake lines? first timer, pointers please!
  49. Looking for specific mandrel bent piping.
  50. Anyone got a CAD file of a Dodge V10 head flange?
  51. stepped 4-1 header
  52. some 3d modeling software
  53. Who makes T4 divided flanged collector
  54. trying to put a Invidia EF9 Catback on my crx
  55. insight on intake manifold designs
  56. In the market for new Welder, Lincoln Precision 225 or 275?
  57. my first twin scroll manifold (not honda)
  58. Just some eye candy....
  59. Looking for fab shop in cleveland
  60. Proper way of rerouting dumptube?
  61. who can CNC two 38mm tial wastegate flanges SS 1/2"+ thick
  62. Welding does it matter?
  63. Smoothing out welds?
  64. threw something together this morning (paint gun holder)
  65. I/C fab ?
  66. Welding inside & outside of collector
  67. Are velocity stacks worth the $$
  68. Who sell some good quality mufflers and resonators??
  69. where to buy exhaust hangers?
  70. 2 inch diameter pipe with a 15 degree bend
  71. Recent CNC Work
  72. RD Fabs
  73. v band question...help please!!
  74. What kind of sanding bench do you use for flanges?
  75. Anyone here have experience credit card AVS codes and avoiding internation fraud orders?
  76. Job Opening: Drafter Position Available at My Company [Phoenix, Arizona]
  77. Filler Necks
  78. My First intake, First time welding alumnium
  79. Lets see some shops ! Fab set ups / layouts and ideas...
  80. Can someone give me an opinion on Autocad 2008
  81. V Band Flange material for a Turbine Housing
  82. (noob) just trying to get my facts straight before i do anything
  83. ATTN: Real Honda Dealership techs, new techer on the move
  84. Tony1 42r backdoor intercooler
  85. i want to have my fuel rail bored. what size?
  86. Cant find slotted 3 bolt exhaust flanges
  87. Dumb question. Okay to use JB weld on intercooler?
  88. Should I. . .
  89. Combo unit?
  90. Bending 1/2" sched 40 aluminium
  91. Let's see your bandsaw do this!
  92. Anyone know where Dustin - Carbonall from CompositesFab is?
  93. Welding Web. . .
  94. Anyone using this brake?
  95. Recommend welder
  96. In need of some software for 3d modeling and design of various components...the catch= Free or cheap
  97. Tube bending software.... free! Check it out.
  98. Converting metric to standard via tap?
  99. Choosing a stainless filler wire...
  100. Welding a motor mount bracket on frame rail any advice?
  101. CATCH CAN?
  102. Suggestions on a bigger compressor ?
  103. Wtb: 1.5 inch j u bend stainless
  104. Made my own D Series Crank Pulley Holder
  105. hey what do you guys think of this harness bar for eks should i make more?
  106. Build a roll cage at home
  107. Looking for some bushing stock, m10 inner, any length
  108. question on welding pipe
  109. welding evalutation?
  110. Anyone use an oscilloscope?
  111. Rear bars on cage?
  112. rear axle set ups
  113. missing cam bearing cap!
  114. exhaust temp
  115. Need a source for some small spacers for traction bar setup
  116. Anyone make their own sleeves?
  117. Just got my itb
  118. welding holes in trunk
  119. Looking for someone that sells or can fabricate 3" downpipe 5 bolt
  120. welding aluminum, help?
  121. Need help on a mig for body work HTP/miller
  122. SOHC Sheet Metal Intake Manifold!
  123. Built my fuel sump today..
  124. anyone making sheetmetal gaskets with a hydro press?
  125. Manifold runner length question...
  126. Custom Kart
  127. stich weld or full seam weld chasis?
  128. Core Support
  129. Homemade skid plate for my new ITR header! lots of pics!
  130. need velocity stacks!!
  131. EG cage project
  132. 93 civic roll cage question
  133. Mild steel good enough for turbo manifold?
  134. First production: My RMS GT42R CRX topmount w/ 4" dp
  135. How much argon do you go threw \tig welding ?
  136. HF heat gun? any good
  137. help on welding runners
  138. what do you short people do with race seats?
  139. Check out my nifty collector cutting jig!
  140. Your AN fuel system setups
  141. Roll cage fab guys...how to prep for paint?
  142. Blank exhaust tips?
  143. solid engine / torque dampers ...
  144. making my first intake-parts help and suggestions
  145. this there any way 2 move the alternator down on a h22 motor?
  146. Anyone looking for shop space in Buford GA area?
  147. dumptubes: re-routing vs. open
  148. carbon fiber overlay. Need help and advice
  149. 1.5" SCH. 40 304SS, expansion?
  150. t3/t4 combo flange- anyone got one in stock?
  151. 304 SUS vs. 409 SUS? Pros and cons?
  152. RHD Conversion w/o RHD Firewall
  153. Mig and stainless?
  154. problems running TIG at home?
  155. my 3g civic hatch trailor
  156. tig welder
  157. synchrowave or dynasty
  158. place to buy aluminum trasitions?
  159. ABS piping?
  160. Civic Hatch Crazy 20ga. Sheet metal Fabrication
  161. how hard is to make a down pipe
  162. How is a spoon n1 tip made, or where do i buy the tube already made?
  163. Need tips on this.
  164. really stupid question
  165. Something I've been working on this week.....
  166. First time back-purge help
  167. 2jzgte intake & exhaust flanges? Where to buy?
  168. Fabricating Carbon Fiber Intake/Airbox
  169. Snapped off block bolts
  170. so ive been welding for about 45 min, what do you think? questions also
  171. running wires through fuel tank lid?
  172. coupes with roll cages?? how
  173. my first manifold....56k go smoke a joint!!!
  174. what material dimple die gussets for cages?
  175. 1st DAY MIG
  176. Unibody info/convertible info.. Help? pics.
  177. Need 4.5 ft of 1.5" OD .095 wall Chrom-moly tubing, also need to know which filler
  178. 3" downpipe questions...
  179. Wastegate dump tube?
  180. help with wiring jdm
  181. question for those of you with the weld craft mt 125 mini torch
  182. weld subframe?
  183. Tube beader I made
  184. Rooky welder with a question.
  185. Looky at my header tube
  186. where can i buy porting polishing kits\equipment ???
  187. TimeSert repair: what's the depth of the intake mani stud holes on a d16z6 block?
  188. what radiator on an ef civic hatch?
  189. Tips for installing roll cage while keeping interior?
  190. Help! I have a gremlin in my wiring!
  191. a little something we are working on.
  192. can you powdercoat over chrome??
  193. Paint gun for compressor size
  194. Mild steel vs stainless steel flanges, and 3/8" vs 1/2"
  195. jb weld top hat
  196. welded differential
  197. 1 pic of my project cheapass straight axle
  198. where can i get a set of pliers?
  199. Bar & Plate radiator cores? Available anywhere?
  200. RMS gsr from hell finally done!
  201. [awful] fmic?
  202. Flow in manifold?!
  203. Throttle plate material???
  204. intake manifold (16v dohc VW)
  205. Chassis Fab Guys..........
  206. Fabbing up a rear brace, after input!
  207. Help Me Buy a TIG Welder!
  208. d-series WELDED DIFF>> ???tions
  209. where to find T and 90deg part for log manifold
  210. problem with standalone. i think this is the wrong section, but its a general question and you guys
  211. Lowering entire engine and transmission assembly
  212. Brazing Questions
  213. What to make a simple, efficient dashboard out of?
  214. Twin Turbo B16 setup *pics inside*
  215. Putting together a list of roll cage & chassic fabricators by area. Need some help!
  216. Any tips on building a tube front end?
  217. Best 110v Tig and Mig welder for under $500?
  218. ...And why I love honda-tech
  219. supercharged+turbo
  220. buying a new welder
  221. can this dent be pulled out from this muffler?
  222. BAT ring I fabricated for a customer
  223. comprex?(pressure wave supercharger)
  224. Problems w/ Sync 200??
  225. Custom Exhaust
  226. is this manifold any good
  227. bends and sizes
  228. Cutting 180 bend for axle clearance.
  229. Weld/Fab gods: stripped JRSC mani bolt: repair in place options?
  230. Inside Diameter of 2.5" Exhaust Piping
  231. Vented Valve Cover Post up some pics!
  232. how to do a ek front end on eg hatch
  233. Anyone want to sell me some pre-cut collectors?
  234. Shaving Bay Question (About Welder)
  235. what grade bolt??
  236. lil' f22 intake manifold myself and brother made.. (cnc crap inside)
  237. exhaust building 304 stainless, which is better sch10 or sch40
  238. Looking into a tap and die set
  239. home depo rocks!
  240. im having troubles with thin sheet metal and body panels
  241. To anyone who runs their own shop
  242. Stainless DP
  243. What do you guys think about this vertical bandsaw ?
  244. Found some neato purge caps...
  245. Custom Wiring - Where do you guys get your supplies?
  246. Can you mig Chromoly?
  247. Fabricated (sort of) heatshield/cold air setup (warining turbo diesel ahead)
  248. Can this weld Aluminum?
  249. Suspension Flanges Where?
  250. Who's made their own header with a MIG?
