PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
  1. some more progress on intake
  2. Awesome Header Fab Tool ->
  3. where can i get engine turned alum or ss sheets...
  4. WHEN ! BOTTLE ISN"T ENOUGH (Nos)
  5. shaved door handles?
  6. is it possible???
  7. Diffuser (Expansion)?
  8. Cheap tiggs for $300 us to weld Steel pipes up
  9. Arc/Stick Welding Uses
  10. Where to find Wastegate Flex Pipe/Bellows?
  11. finished my breather tank
  12. 02 placement, in DP.
  13. Newb question. Please help.
  14. need help on making a small, simple, metal workbench
  15. Latest and greatest, DP i made last week :)
  16. looking for a welder in southern california
  17. Leading a body...
  18. Collectors Who makes them 3 into 1
  19. Fabbed me up a DP
  20. Restart the bussines in new shop, Eastern Europe, Latvia, Riga
  21. Dump Tube
  22. where can i find blueprints for turbo manifolds
  23. i am needing some custom fabed breather tank
  24. I need your opinions of this VQ35DE intake manifold design
  25. Where can I buy this size pipe ?
  26. New plenum finished off drag set-up
  27. air/water set-up coming together fabbed tank and PWR intercooler
  28. Gasless wire welding for exhausts?
  29. 1/2 Size Radiator Install in Integra
  30. syncrowave 180sd 4 sale , northeast
  31. Opinions, info, help, comments on new welder....
  32. intake designe
  33. question about rear hubs/spindles/knuckle
  34. Pay someone to TIG an intercooler or just buy one?
  35. I guess ill join in on the fun...pics of my welds!
  36. I need a 3-1 slip collector...
  37. Anyone know of a strong glue that drys clear ?
  38. CHANGE YOUR CRAPPY 4 LUG SETUP TO 5 LUG WITHOUT ITR PARTS
  39. Tig welding soda can.
  40. my recent project in the making...
  41. 4 point strut bars
  42. need advice!! which TIG to buy and from where??
  43. EF ZC Turbo kit i fabricated this weekend
  44. Home made 4-1 header question
  45. Thinking about opening a small turbo rebuild shop in israel..... need your ideas
  46. I think my retarded ass ruined my chassis.
  47. My Custom 321ss Turbo Manifold Im making, and some other crap.
  48. my new stainless mani, STAIND!!!
  49. interest in a radius marking tool
  50. Hydraulic pipe expander?
  51. h series engine to b series transmission adaptor plate!!!!!!!!!!!!!!
  52. H22A alternator/tensioner kit to run either H or D series alternator in 2 different spots!
  53. H22A NA header design advice suggestions wanted...
  54. Weld over already welded pipe?
  55. anyone have sketches/blueprints of go karts?
  56. what thickness of bends to use for turbo mani
  57. amps for roll cage
  58. Is this radiator fixable?
  59. b18a1 intake flange
  60. nOOb question about welding!
  61. can anyone make this flange
  62. ShifterKart project
  63. dumptube piping?
  64. building up material with TIG on aluminum: tips?
  65. welding setup contents
  66. Some fab work over the week
  67. Fiberglass Tech Help
  68. Question about JDM 4-1 Header Heatshield??
  69. Tanks and Regulators???
  70. 228 cu foot oxygen cylinders in north va
  71. Turbo Header Fab.
  72. Fabrication? Carbon Fiber
  73. Need good explanation on this V stack placement.
  74. Some teaser pics of my new EF topmount...
  75. welding order learning to weld
  76. Bends on a manifold
  77. help!!!!
  78. this is one of my setup
  79. Radiator Support
  80. my first CARBON GRAPHITE fuel pump cover
  81. Our new BANDSAW...
  82. My First Ramhorn
  83. Is this bandsaw junk?
  84. My first Pie-Cut elbow.....
  85. Any Electricans in here?
  86. Suggestions for H series moroso oil pan modification for road race use
  87. where to get weld on exhaust hangers?
  88. Where's that block guard write up
  89. fabbing a strut bar...want some input before i start
  90. ? for manifold builders
  91. belt sander for angling pipes what they called?
  92. My first shot at IC piping.
  93. stuff we have been working on
  94. Welding School directory
  95. Can someone with a TIG near DC help me out?
  96. So cali Need custom faber that can make me aluminum IC piping
  97. What am i doing wrong?? (welding)
  98. tig ,mig or arc whats best
  99. Looking to purchase a Tig.
  100. **A Noobtron's first turbo**
  101. Gas/No Gas Welder
  102. LCA/Ball Joint hole too big
  103. Is this hard to fix?
  104. Stargon
  105. miging mild tubing to ss flange??
  106. Roll Cage Tubing Size
  107. Solidworks, anyone have the sch10 pipe file saved ?
  108. where can i find a 3in to 4in flare adapter
  109. back purge?
  110. Welding Aluminized Steel
  111. Need feedback on an idea I had
  112. Rate my Welds: Newb
  113. Mig welding 304 stainless...
  114. Quick Syncrowave 200 question
  115. solid rear mount
  116. What A Pickle - Downpipe/Dump, 02/Wideband Bungs, 3" Exhaust Cutout *Need Placement Help*
  117. any welding shops in/near sf
  118. bikes im working on
  119. need quality welder who knows what there doin!!!haha
  120. Anyone make me a couple of collectors in mild steel?
  121. What kinda tool box do you guys have Im in the market?
  122. What type of fittin and weld is need
  123. bodywork question
  124. Steel Mix, anyone tried?
  125. sumping stock fuel tank
  126. What's a good TIG welder to start out with?
  127. block repair. how does it look?
  128. Pics of the Thermal Arc Pro Wave 185
  129. Inline 6 cylinder turbo header pictures
  130. Fiberglass cracks, anyway to stop them from spreading ?
  131. my Tig cart for ThermalArc 185tsw : first Tig project.
  132. What does a Mechanical Engineer do exactly?
  133. quick question about stainless steel manifold
  134. grind or re-cut piping to weld again.
  135. need working link /w pics for DIY JDM DC2 front install
  136. Would someone with custom exhaust exp PM me
  137. turbo flange question?
  138. How do you cut piping, and DIY bead roller?
  139. DC tig welding aluminum...
  140. cleaning buttwelds
  141. My new MIG
  142. How much should I expect to pay?
  143. learning to weld TIG
  144. hf manifold
  145. What do you think of these welds?
  146. Knife edge the "bridge" in a split port turbine housing?
  147. blueprints for funny car style cage
  148. looking for a uni spotter kit??
  149. what are these clamps called?
  150. what needs to be welded on 2000 front end
  151. Structural Support for Roofless Civic
  152. Rate this dp fabrication..........
  153. Dent on edge of combustion chamber... what are my options?
  154. Where do you guys get your 3.5" stainless tubing?
  155. Tubing Question
  156. Strut Bars
  157. where to buy cheap exhaust mani flanges?
  158. Portable CMM?
  159. A shift meter in my steering wheel
  160. Rolled fenders??
  161. Warped Flange... crush gasket?
  162. how many amps for 3/8 inch steel?
  163. question about aluminum bodied cars and cages ie:honda insight and nsx's?
  164. OT: Best deal on piping bends I've seen!
  165. WTB: 1/2" thick K series stainless head flange
  166. Used Speedglas 9002x
  167. mistake?
  168. Someone in jersey I need exhuast
  169. Anyone looking for a tubing bender?
  170. ram manifold for kickss
  171. Turbo Manifold I made for NativeSon (Len Ayala)
  172. stock motor mounts-how/what do i fill it to make a solid ones??
  173. split piping my exhaust
  174. Should I use sealing tape to mount my regulator and gas line for a MIG?
  175. Looking for a Plasma cutter
  176. Great craftsmanship.
  177. weldin help
  178. scion TC buildup
  179. my turn. rate my welds.
  180. Please, rate my welds :)
  181. So I wanna put a cage in my 94 hatch...
  182. Better Tig Torch Source?
  183. Exhaust system tubing guage>?
  184. Locking engine bolts (requires a key) Idea stupid?
  185. Connecting regulator and gas line
  186. So Cal school fr fab help "the Fab School"
  187. Rollcage bars
  188. surface of mild steele flanges after a while
  189. turbo manifold piping
  190. Miller
  191. Schooling vs. Self Taught
  192. Some of my pulse mig welding
  193. has anyone used a CO2 tank from a keg kit for welding?
  194. Down Pipe
  195. NEED ITR FENDERS FIT FOR EG
  196. Rate PhoenixTurboJesse's WELD
  197. inline 6 head flange......welding suggestions....
  198. Tig welders torch: Air or water cooled?
  199. Harbor Freight Mig Welder
  200. Projector questions
  201. EF8 ROLL CAGE ....... HELP PLS
  202. Technical article on computer-aided design and fabrication of turbo manifolds
  203. Pics of my new ITB manifold -- built by me
  204. Welding tutorial?
  205. Exhaust Bumper Plate Ideas?
  206. Any of you skilled welders in the VA area that can weld aluminum?
  207. What thickness do you recommend for an aluminum intake manifold?
  208. Where do i buy Bars for Roll Bars
  209. How to make runner oval?
  210. making a ITR/GSR intake manifold adapter plate
  211. Suggestion!?!?!
  212. S2000 TOPMOUNT
  213. new to welding.. need advise
  214. Tube Chasis?
  215. New Helmet
  216. get laid on valentines day
  217. THE FINEL DESISION: 220v mig, budget $500
  218. Does this seem like a decent Welder for DIY jobs?
  219. Latest Project
  220. What Am I doing wrong?
  221. integra type R muffler...welders...anybody
  222. Please help me set up my Syncrowave 200
  223. How to clean burned oily finger prints off SS header?
  224. Shaving The Tailgate Questions
  225. Mockup for someone else to weld - how much $$?
  226. Mazworx Custom Tubular Manifold...
  227. problem with my top mount manifold
  228. Welding a cast iron manifold. Need some questions answered.
  229. What's a good epoxy for filling mounts, 80-90a? area
  230. welding Q from a non-welder- turbine housing related
  231. front suspension question
  232. can you mig chromoly?
  233. need some input on modding my dc 4-1 header
  234. rebuild questionn..need helpp!!
  235. 4130 Failing - Link
  236. Sch. pipe welding
  237. question about a tile wastegate flange
  238. anyone played with the Lincoln 3200HD mig/flux welder
  239. CUSTOM CRANK PULLEY.
  240. pipe els?
  241. FS: Miller Econotig brand new, never used. Must go!
  242. HARBOR FREIGHT 10%-20% Off Coupon THREAD******please help update****** -=)
  243. Im new, Heres My Garage
  244. covering up holes in chassis/shell
  245. FOR SALE SYNCROWAVE 180 AND MILLERMATIC 185!!!!
  246. How to repair high pressure power steering hose?
  247. DIY ramhorns...?
  248. Who sells 3inch Flex for the best price
  249. b series topmount manifold with a/c and powersteering?
  250. pics of my in-progress EF turbo setup...built SOHC
