View Full Version : Welding / Fabrication
- Fighting warpage...
- How to install a dynojet inground.
- Drag/Track Car Cage
- MILLER SYNCHROWAVE 200?
- is this a good tig welder to learn on?
- 18 gauge 4" tubing??
- Questions
- Titanium Exhaust Repair (Pics)
- Silcone connector 3.5 to 3.25"
- Where to get a "turbo box" for a log manifold
- Hood Light Pod project to start... upon figuring out the details
- Questions about purchasing a machine
- 321ss
- How to take out top hat studs?
- where to get flanges?
- weld in seats
- stupid question...Pace setter products...
- Chicago Electric welder --> Where can I get service parts?
- welding neck back onto motorcycle frame?
- V8 all motor headers
- MIG question: wire size .030 or .035?
- Throttle body placement
- B-series custom header kits????
- where to buy welders helmet?
- good flex pipe
- B series mani
- FIXABLE?
- first made manifold
- boosting your 115v mig
- Block repair
- Front end crashed, need fix, estimated cost?
- Trying to make a fiberglass intake arm - what type of fiber/resin?
- WhAt tYpe?
- Sheet Metal
- ITB fabrication labor
- something new I hope. Ideas for fabricators on 92 hatch
- Some work we did this past weekend
- 2JZ Intake Manifold Fabrication
- Any Shop Looking for a Welder?
- wireing 04 rsx-s headlight and wiper switches in 97 EK any pointers?!?!?!?
- How do you cut a T3 flange hole for a log manifold?
- I know this is a dumba#% question
- internal connection for HF box
- Custom intake mani... {not honda}
- Has anyone built a gokart/dune buggy using a singlecam?
- CTR or ITR Pistons in a 86mm?
- 14b turbo inlet flange dimension
- Block Sleeve Question
- TIGing tubing. Need pointers
- Evo 8 bike rack
- Metal Shavings Clogging up the Oil System
- Stock Honda donut exhaust flange?
- 16ga 1.75 90 bends
- my first log manifold
- This place has been suckin big time!! Noone's been makin nothin worth posting??
- FIRST TIG project
- Chop Top 92 civic Hb
- firepower welders good?
- Where to buy 12mm X 1.25 X 110 bolt?
- Little interesting information
- RMC-V30 4 Axis CNC???
- aluminum merge collector
- Cutting U bends?
- Some custom things made for the CRX
- 99 cent automatic cold saw on ebay in kanas, Try to help a fellow fabbers out
- recent fab work @ kordenbrock mtrspts (not a honda but interesting)....
- miller dialarc hf question
- Schedule 10 ro 40 for turbo headers
- Is anyone in GA?
- a/c firewall hole shaved! want to remove
- Header, turbo manifold piping supply???
- pic of my welds
- fs:b16 tranny
- pipe expender off ebay.... anybody use it?
- Need input on turbo manifold build up?
- Is there another name for DOM tubing?
- hood hydrolics..anyone know how?
- Which size for the tubing of a headers on my D16
- Who sells 3" 3 bolt exhaust flanges cheap
- exhaust pulse tuned manifolds
- Pulsed pass with no filler?
- Look what i bought. Now I need to buy some skill.
- 2" aluminum for intake manifold
- People who have built a roll cage... I want your input
- Just some fab work completed this week
- Tig welding questions
- low ballers show us your HF/CHICAGO ELECTRIC/SMILY TOOLS tig welds :)
- DIY header
- Can you weld to stainless?
- can someon tell me how to wire up a 97 ls engine with 96 civic harness
- Core Support Welding... 92 Integra
- Random welds yesterday! What do you think?
- New Fab Toys I Purchase @ Auction
- going from hard line to AN questions
- Sheet metal
- Correct forum? Need some info regarding tools.
- MangaFlow Muffler as a Resonator?
- Half-Homemade 4" muffler
- Help me find a bandsaw! plz
- weld cast iron?
- Do I have 3 - phase power? (Pic inside!)
- need a custom band? call these guys...
- Where to buy SS line seperators?
- Weld Request: Mussel Gaff
- 1.5" Sch40 Weld in 1 pass?
- Fit Turbo Manifold help
- How are sway bars made?
- Custom CNC work
- Need help finding an intercooler of this size or the core.... please help me out.
- Benifits of an inverter!!
- Caterham kit car. Yamaha R1
- how can i put my pictures up?
- where do you buy this
- i am making my first h22 header. 1 5/8" or 1 3/4" ?
- my first merge colector
- Debate on a Tig Welder Which do u recomanded
- DIY E-Cutout Motor/Servo?
- Composites and other Plastics Job openings in So. Calif. area....
- SHIFTER FABRICATION QUESTION
- What filler rod for galvanized?
- manifold out of 18g?
- Saturday... need Tig torch parts in so-cal... anyone?
- Working with fibreglass
- how to make ek custom seat rails
- B18C in a MR Chassis
- CF GURUS.... is that fixable?
- welding brackets on bumper support
- Brazing a cast turbo manifold?
- Anybody got a good price on mild steel "T's" right now?
- where to get Acacia and Fluent 5.2?
- Anyone use a finger tip control ?
- A-Z on Materials. material information
- recent fabs i'd like to share
- Machine shops in the tri-state???
- Looking to purchase around 100 ~3"x8" pieces of Aluminum.
- 3-1 collectors
- Cutting off Comptech Exhaust Tip
- machining an exhaust housing for a larger wheel??
- Mustang TB adapter plate
- Valve cover vents.. Can brass fittings be welded to valve cover?
- how do you make a throttlebody plate?
- Soo...I picked up the new Hot Rod magazine...
- cracked rim
- bay area Rhd crx-looking for help!!!!
- Please Critique My Welds(4th day Welding)
- Back purge vs standard
- Fiberglass + Bondo... process?? Chip Resistance? Please help this fabb'ing n00b
- good places to find quality pipe benders?
- JDM ITR front end welding help!!
- Need basic welder for body work, help
- Some R32GTR fab pics and So forth
- Who carries 3.25" alum tubing and bends?
- what bends to build a 3" exhaust??
- 309L filler for all stainless welding, versus stocking 308 and 309
- getting new flanges made
- My new shifter
- Need help finding exhuast J hooks
- Fresh Air Sytem DIY -- Need Help
- Tungsten keeps screwin up?
- intake mani design.
- Thinking about buying this arc welder.. $50 good deal?
- k20a manifold
- Carbon Fiber Hood Repair.
- Pic Request: Welds using just arch(wire only) vs. MIG(with gas)...
- Okay to MIG Tack Weld on Chrome-Moly?
- oem muffler on custom mandrel bent exhaust
- Stepping up from my 180 syncrowave, would like some input from owners of larger machines.
- where to find bolts
- i want a tig welder but i'm broke....
- i need a collector made for a T4 flange
- I need someone for TIG welding service in NOVA
- Custom Underguard/splash guard
- where to find 5" stainless bends/mufflers
- Found this on an auction website
- eMachineShop.com
- Your First Welding Job
- How do you guys hold your turbo flange in place while mocking up your manifolds?
- JDM front end radiator support weld??
- What do you guys think?
- prepping my car for paint, need some help
- New project coming in, twin turbo slp
- SOHC DELSOL with a twist must check it out
- Hasport Performance is hiring....
- DA rear subframe brace
- Intake Manifold Material?
- Who sells aluminum tubning reducers?
- something for you to laugh at
- restoring shaved door handles to stock help
- Cheapest known online supplier of stainless 18 gage tubing (straight and mandrel bent)?
- Welding mild steel to chrome moly?
- Cleaning sloppy turbo manifold up?
- Profitable to produce and sell collectors???
- EVO Manifolds
- anyone know a place i can buy a cheap mig in van nuys area ?
- People who have fixed cracks in the cast manifolds chim in
- Differences between mandrel bent and regular bent?
- Got bored after work.... EF strut bar PICS
- Where to get Silicone Hose Cutters?
- Help me out on the collector...
- D series exhaust flange in solidworks?
- Looking to buy a REAL bandsaw, what do you think?
- Where to put this stinkin, tiny Odyssey battery...
- preparing suspension metal for powdercoat/paint.
- Looking for someone to weld up two manifolds
- cage surface rust
- High Frequency Interference From Tig Welder
- austin healy project
- 02 sensor source?
- Looking for WELDER in SOCAL to swap radiator/core support + questions about rad support welding
- New manifold feedback wanted.
- need help mounting fuel cell
- Welded some aluminum charge piping...
- Some CNC goodness from work
- Place Racing + 86-89 accords + b series motrs = need mount designs
- what kind of wire do i need
- Valve Spring Compressor
- Cracked Tranny question
- Custom Manifold Spec Advice
- Mig Wire Questions.
- What tool countersinks holes in steel plate (connects roll cage to b pillar)
- what welder do i use to weld holes on firewall for wire tuck ?????
- SPOT WELD CUTTER! NEED INFO>
- Tig welding steel and stainless
- Want to buy a water jet machine. Need some help!
- welding sun burn.
- Intake Manifold Parts
- Major Disappointment
- Welding Titanium... noob Q sorry
- how much should i expect to pay to weld aluminum
- look at this question real quick
- gas and oxygen bottles or electric welding?
- Home made tubing notcher
- welding question
- Anyone fab their own front lower tie bar or h brace? POST PIC!
- Merging 2 pipes into a bigger pipe??
- Can 15 amp breaker handle 110v Mig Welder?
- Proud of my rapidly improving skills... samples
- how come exploited racing is still on after being banned????
- header formula
- 1st MK4 Gti 1.8T with 4" exhaust
- head flanges
- any fab shop looking for a cad drafter / designer?
- home made CAI extension
- fiber glass or eplox(sp?) patch on cf hood?
- TIG Help
- anyone know where to buy aluminum nuts??
- Header fabicators. Need some advice
- attn carbon fiberists (fiberists? carbonists? lol okay sorry.. dumb title)
- rust on quarter panel
- getting panels off at the junkyard.. ? how
