View Full Version : Welding / Fabrication
- Something you guys might find interesting.
- Dump tube material
- can someone reccomend a meadia blaster for undercarraige blasting?
- home depot welders
- Cone Shaped Spacer for End Link DIY
- Who makes a 2-1/4" AL V-band flange....
- Legend Hood Dampers -> ej8?
- More Intake Manifold stuff
- Custom Exhaust *Non-Honda*
- Custom IM H22
- Stainless Welding Prices?
- some pics manifold 2jzgte and bserie topmount
- Best technique for welding 16-14 Ga. aluminum?
- O2 Sensor Bungs
- Need help identifying this part for fabrication
- ESAB Caddy TIG 2200i first impressions
- welding halmet, $200 budget? miller? lincoln? 3m?
- non-honda tranny adapter
- Pics of my new shop, towing business is booming.
- A couple of intercoolers...
- begginer welding help
- looking to lose weight
- good weld?
- Identifying the technical term for a part
- New cage for the ITS Zcar
- Just got my new welder in...
- comment about hobart of 140amp mig..
- desk I built
- Building Custom Exhaust for my NSX: Need Suggestions for Parts/Supplies
- Is it possible to repair a exhaust mani?
- Radiator Cores?
- custom intake manifold
- Could use some help with fabricating processes
- help identify flange material
- Welding Table Top
- the most difficult to weld in accordance with BS EN 287
- Looking for a 2-1 Turbo Merge Collector
- need to trim license plate
- TIG welding polished AL pipes???
- Oil Pressure Tap Cracked
- Sheet Metal Tags / Punch?
- lincoln 175hd welder
- 1977 XS650 turbocharged fuel injected project
- best size round pipe to fit t4 flange?
- need ideas on making a big oven
- More vw bug stuff.....K series!!!!
- whats the best header design for mpg?
- latest welds
- -10 an fitting tap size???
- some non-honda headers
- materials for DP? Dump tubes? manifold?
- rust hole in trunk!?what to do
- Opinions on this design?
- welding mild steel with 308 ss wire
- Small Diameter Stainless Tubing
- do you need your ac bracket?
- Pre polished weld "L"s....
- How to port my Intake Manifold
- v10 bmw e30(not my build)
- electrode grinder
- Some non Honda Machine work
- throttle actuated scoop
- Some fab work I did recently.
- Circle/360 degree bent tubing
- A Quick Design
- tig welder suggestions
- Wheel adapters and galvanism? how to prevent galvanism?
- Anyone had problems with their 'high End Tri-Y headers by LogicMotorsports.com'
- tapping the oil pan + wg placement?
- miller diversion 165
- Aluminum spark plug covers
- First Production
- Just another manifold fabrication
- Hogan Turbo Manifold Polish.....
- CNC Guys....
- Fabricators : Ceramic coating manifolds vs. warranty
- 110-120v strong enough?
- Some I/C piping I made today
- Intake Manifold Material?
- Another small cnc project
- Anybody's got a 4" VBand drawing?
- stuff u thought of or saw before
- custom rear strut bar?
- Just got a invertec 155, need to rewire the power socket
- custom vertical flow FMIC pics
- Anyone heard of Linde TIG welders??
- airbrushed welding helmets
- First tig welder?
- Band saw blade
- Anyone try stick-welding aluminum here?
- Just bought my first MIG
- ccimports
- egt probe install
- Big 4" Aluminum Downpipe
- Transmission Hand Cuff cnc design
- post your backpurging setups!
- Anyone know a good muffler shop in SoCal-Los Angeles
- looking for ideas on fabing brackets to mount engine to palet
- 12 ton press for wheel bearings?
- A few Wire Tucking Questions (to tuck or not to tuck)
- econotig vs. diversion 165 for new tig welder
- LS in a civic eg hatch question?
- my first turbo kit setup.
- magnetic welds
- Anybody know a place in south jersey that welds aluminum?
- Exotic metals bend tests
- which material better for manifolds
- Any horrer story's of Mild steel turbo manis?
- porting my intake, welding alumiun ?
- Anyone have good /clean solutions for 60mm gauges and a rollcage
- Intro and pics from the newbie
- Thermal Arc vs. HTP
- 998+whp BMW Intercooler
- Precision Fabrication 24 x 12 x 4.5 IC
- EG hatch fenders on sedans...
- Neon SRT-4 Top Mount T3 w/44 TiAL
- Can I bend aluminum with my JD2 bender?
- whats causing "gritty" AL weld bead
- How much work and cash.....
- rust help on 88 crx dx
- yet another welding advice thread
- Aluminum Welding Woes
- Making a collector... (Sticky?)
- A small CNC Project
- Welding chromoly... problems..
- just a note to all you welders out there.
- urethane mounts gone wrong. help please!
- inverter vs transformer machines
- Looking for a 220v TIG or MIG (on a budget)
- holes in my body?
- Exhaust flange
- welding aluminum wheel crack?
- Coolmate V3 & New Sync 200
- My mid engine RWD turbo CRX
- Stabilizing AC arc
- getting a little bit more practice in, some collector pics
- What Cad program do you prefer ?
- welding mounts
- CAD/CNC Machining Projects
- Average annual income..
- the start of an sr20 with an evo9 turbo
- high frequency woes (again)
- fan switch
- Fabbing my own muffler. People who have fabbed some look in
- any Idea how to build a drilling rig??
- Hard line Clips
- Reducer....
- Broken eg6 rear subframe
- 5" to 4" stainless reducer?
- [how to] rear disc on CR-V
- cheapest place to buy sched10 fittings?
- Core support welding question! PLEASE LOOK
- Audi A3 downpipe
- tube nuts and pressure?
- Sheetmetal bender? 1/2" material
- Mufflers / In-out on same end?
- Intake Manifold Flanges?
- To cat or not to cat
- My D16A6 powered sandrail (build thread/pics)
- pics of alum. or ss with your syncrowave 200
- -3AN Hose and Fitting Questions
- Lots of pics of lots of parts.
- 304 AND 316 on mani?
- My auto tranny swap is done!
- thermal paste
- Recent exhaust work
- Perforated Exhaust tubbing. Anyone know where to get ?
- Looking for a welder in Miami fl
- How much is professional TIG welder per hour?
- Has anyone welded in a moonroof, roof panel? Moonroof Retrofit.
- CRMB Fab Thread
- New S2000 manifold
- Machining/Welding by BMCRace
- Ford RS 500 COSWORTH Exhaust
- Sight glass in coolant tank?
- Suggestions for AWESOME sounding fabbed exhaust
- can some one tell wher i can find this
- ATV quad exhaust work. Need some opinions.
- Non-Honda Fab
- 3003-o 0.035" 5/8 (10an) aluminum Oil Cooler Hard lines
- Some pictures of my new cage (non honda)
- aluminum used for a roll bar/cage??
- Ebay Header - Connecting to Exhaust Question
- new turbo setup...
- Longshot, looking to borrow a tool
- Relocated my battery on the S
- Check out my new toy...Post yours if you'd like..
- How do I clean up aluminum welds?
- block damage
- Evo 9 Recaros
- Dealing/Compensating with runners shrinking
- Some KA-t log style manifolds im building
- parts to make mani?
- Mitsubishi EVO manifold
- exhaust fabricators, have question
- non honda, work synapse motorsport is doing for me
- bastard vc giving me trouble
- What kind of glue to use?
- who can do a cfd test for me, or knows where i can have one done?
- Longer ubber exhaust hanger
- Fab Request
- Buy or rent gas cylinders?
- Newbie, looking for critique on welds and collector
- Newbie, critique my welds and collector.
- How many PSI in your full argon bottle?
- BrewSpeed fabrication/parts thread
- Heat shield
- Possible to fab up a decent canister type muffler? for a scooter?
- what you think about this welder
- 300ZX Z32 TT project
- miller thunderbolt stick conversion
- Converting miller maxstar 175 to the 152
- Serial Tags?
- SynapseTurbo.com is Hiring
- Has anyone here welded front spindles?? susp. mod
- Deck Closing?
- need help on tig welder decision!!
- how to remove spot welds?
- Aluminum Radiator Repair
- Solidworks users
- made a catch can
- Manifold fabbers check in
- looking for a website... -an taps, blank fuel rails
- Square tube headers
- Need an aluminum welder in Florida. Will pay you!
- test run on my new tig welder
- welding an ls intake manifold onto a gsr flange.
- plexiglas roof w/scion tc sunroof?
- Looking for...
- center/bottom mount srt intake manifold.....
- Aluminum and steel billets
- Grinding Wheel for tungsten???
- -3an to m10x1.0 adaptor??
- Water cooler for torches
- add this one to my fab thread...
- Aluminum Tig Help
- WHAT KIND OF WELDING SHOULD I BUY FOR ALUMINUM???
- Where can i find stainless steel???I wana customize my own charge pipe???
- Joining Aluminum Tubing
- durafix alloy welding
- having trouble welding stainless steel. help?
- Looking for a shop in Los Angeles Area.
- Bandsaw advice
- Bench grinder: which size? 6" 8" etc.
- Miller Dynasty 200SD - HF Start Quit working tonight
- Help me spend my money wisely...
- Basic Exhaust Manifold Fabrication Needed in Newport News, VA
- Finished some intake manifold today
- Yet another new welder th the forum
- vibrant race muffler
