PDA
View Full Version : Welding / Fabrication
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47
  1. Well its no Honda but my project is finally over
  2. vss welding?
  3. subaru rally car
  4. Precision Intercooler
  5. my first fab.
  6. welding rod question ?
  7. Critique this manifold worht 250shipped?
  8. Some questions about welding and what is a good machine to purchase.
  9. yay 300 topic is mine
  10. Anyone intrested in a NEW Esab plasma cutter
  11. welding galvanized steel... suggestions?
  12. Body panels
  13. welding a falange?
  14. I need a Custom Manifold..
  15. anyone here make custom flanges?
  16. Seat Brackets in NY?
  17. Major HoOd Clearance Problems!!!
  18. turbo manifold.
  19. an fd i did a few months ago!
  20. WHo makes carbon fiber intake manifolds
  21. RE:HarborFreight's Mig Welder
  22. can this be welded?
  23. A couple manifolds i've been working on...
  24. Where do you guys get your thick gauge piping for turbo exhaust manifolds
  25. Any plans online to help with building gokart with civic engine??
  26. Exhaust Welding ?
  27. VSV Intercooler Piping/Intercooler Brackets.....
  28. Something different for my S13
  29. Milling Machine: Is this a good deal? -Maching shop guys-
  30. Tri-y header for dodge neon... pic
  31. Learning to weld
  32. Swap Question
  33. should i get some thing like this?
  34. any way to make existing welds stonger?
  35. Custom Bolt-in bar?
  36. Roll cage....00 civic hb...
  37. Newb Here, Found A Welder, Any Good?
  38. anyone use this welding helmet?
  39. DIY Harness bar...
  40. Aircraft Paint Stripper
  41. Custom Radiator Hose -AN conversion stuff
  42. 3" exhaust madrel bent
  43. Need Someone to weld a transmission in south florida.
  44. Oxy Acetylene welding..Good for exhaust/charge pipe work? Manifolds??
  45. Custom Exhaust Tip
  46. DIY Shortie Intake
  47. ITR cat back modding
  48. Welding advise, transmission linkage
  49. Need to fine some Intake Manifold end tanks...
  50. diy TIG
  51. out of curiosity, can any of you post your best E6010 welds?
  52. Titanium
  53. spare tire hole
  54. Where can I get this tubing / Check out this oil catch can!
  55. Weld Water Tracks? Good or Bad?
  56. Fabing up a turbo mani, where to get collector like Burns?
  57. What kind of welding is required for this piping??
  58. NEED SOMEONE TO WELD IN NOVA!!
  59. cage pics from my garage
  60. Preview: My shifter kart...
  61. cage tips? gussets & boxed joints?
  62. made a mini rod
  63. How to undo somthing that was molded to the body?
  64. What kind of metal to use?
  65. 6 point cage in a del sol
  66. The Macguyver forum!!!!!!!!!
  67. Mandrel Bend Piping WHere from????
  68. cage pixors....
  69. Where to buy piping
  70. welding radiator support
  71. Need passenger airbag blockoff plate FAB'd in CF
  72. FYI Weld Samples, various materials
  73. Bumper bar requires replacement...need help
  74. Looking for a good fab shop in Seattle area...
  75. K-series turbo manifold for EG/EK
  76. VTEC motor inplace of a inboard marine motor in a boat
  77. Feasibility of making an intake (cai) out of fiberglass?
  78. check out my log style turbo manifold i made and lots more to come
  79. EMachineShop.com! Oh yeah baby!
  80. Critique my welding
  81. My recent fab: Lower radiator bracket for radiator conversion...
  82. MIG welder Gas /wo gas whats the difference? Power level for 304ss MIG, CRX exhaust floor plan?
  83. Quenching after welding
  84. who can weld a wastegate flange on my cast manifold????
  85. **PICS**CUSTOM FAB'd COMPTECH ICEBOX LID***
  86. making cutom header //////////////
  87. Did anyone watch that aussie guy weld aluminum on the discovery channel biker build off?
  88. sequential shifter
  89. Let me see ur Intake Manifolds fab'd or Purchased
  90. pic request arc induction box
  91. Body work
  92. carbon fiber processing 101
  93. 2" Steel Mandrels... 45, and 180 degree WHERE?!?!
  94. muffler
  95. proper gounding
  96. Going to have my first tig welding lesson, any tips before I go?
  97. Buying stainless
  98. i need welding help in the VA beach area!!!
  99. LS Cast Iron Turbo Manifold Cracks Repair
  100. Starting to weld. Which welder?
  101. cost's ???
  102. can someone plz answer these questions for me?
  103. What kind of hood dso u use?
  104. tig welder
  105. who has a maxstar 150?
  106. Welding Inconel
  107. new site!
  108. New intercooler pipes help please, i have a mig welder...
  109. my Ep3 seats in my eg hatch !!!! I sit too talll
  110. d series turbo manifold
  111. Blank/non drilled 3 bolt style flange for stock converter?
  112. what to do?
  113. welding SS??
  114. Carbon Fiber Hood Damage!
  115. Do any of you welder guys make a DP for a
  116. Close-loop weld
  117. 600cc Turbo formula SAE
  118. Who makes a 2.5" to 3.0" Downpipe for a sc-61.....
  119. Scrap Metal....
  120. looking for some input: to put the filter in the CAI spot or make heat sheild for turbo.
  121. Any welding schools in NY for cheap?
  122. What are the steps to welding cast steel? I want to try out limit straps up front.
  123. Cold air box
  124. 2000 honda civic front end on a 94 del sol
  125. anyone sell stainless 5 bolt flanges??
  126. JB WELD?
  127. welds on a JDM 4-1 replica header, pics inside
  128. converting an arc welder to a tig welder...
  129. tig welder for sale, look
  130. OT WTB foot control, agron gas regulator
  131. Socal Welders
  132. aluminum equal length manifold
  133. fabrication contest... battery box
  134. Welding Hatch
  135. Sheetmetal sunroof plug/ O.C. welding shop that can do it?
  136. TIG welders.....good/cheap?
  137. Fab'd up a CAI for my car
  138. my vw 1.8t exhaust manifold (in progress)
  139. Cost of re-welding flange at a shop (socal)
  140. When welding a catalytic converter...
  141. Miller synchrowave 180 SD, any good?
  142. Installing Sparco Seats into an EG hatch.
  143. JB Weld
  144. UV Keratitis aka flash burn.... how many of you?
  145. non equal length manifold?
  146. cleaning around jb weld?
  147. Thinking about a couple small fab project.....bracket to take the trans place and cradle
  148. i need garrett 4 bolt dp flanges.
  149. Learning to weld??
  150. Burns Header Pics, what we have laying around
  151. welding on body to fill in the rain rails on top of a 92 civic hatch and molding around car?
  152. Porsche Turbo update..
  153. welding the chasis...
  154. FAQ
  155. Braced and coated my SS auto chrome Mani now 30 PSI safe :)
  156. TIG how strong
  157. Stainless steel exhaust hangers? Anyone know where to get them?
  158. Welding Titanium?
  159. thinking of trading in my syncrowave 180SD for a new thermal arc185 opinions?
  160. Anybody carry 4" aluminum piping ?
  161. anyone ever get zapped by a tig welder??
  162. looking for a good metal shop or fabricator in san diego
  163. Titanium
  164. Tell me about this tubing...
  165. MIG welding center section of T3
  166. What is best for cutting flanges?
  167. Flange on Manifold
  168. DIY endlinks for EK possible?
  169. Fuel Cell With intank pump
  170. i need a job
  171. fiberglass/carbon fiber trunk.. diy.
  172. jb weld
  173. DIY strut bars.
  174. anyone use a 230v welder on there dryer outlet?
  175. JDM ITR Front end conversion...
  176. Welding School in Socal?
  177. SVT Extension Cord Holder
  178. electric or gas? which is better...
  179. I need some cromo heim jointed upper a-arms....
  180. how to mount metal heat shield on bumper???
  181. TIG welding Mild steel 18 gauge...
  182. Anyone try making seat brakets?
  183. Cast iron turbo manifold. Weld it.
  184. tips for aluminum tig
  185. millermatic MIG 135 with cart and gas
  186. Materials
  187. ATTENTION FABBERS!!!! FABRICATE FOR ME $$$$$$
  188. Roll Cage Designs?
  189. suggestions before fabbing up exhaust
  190. welding galvanized steel or aluminized steel harmful?
  191. NPT - AN Equivlents chart?
  192. Here is a way to find out which header is the best [werx & lux]
  193. dd
  194. The 3 inch exhaust project.
  195. turbo mani help
  196. alumaloy?
  197. Best place to get headers coated in So'Cal?
  198. Who sells billet intake flanges?
  199. Quick Welding Question about header and exaust..
  200. what to get (welder)
  201. Need Input - Multiprocess Welder or Seperate TIG & MIG - Suggestions
  202. Where can i get charge pipes??
  203. C02 tank
  204. Anybody know where to find info on powder coating?
  205. this welder any good?
  206. air compressor question
  207. looking for somewhat to shave molding (using sheetmetal) Northern/central cali or bay
  208. Any suggestions on this? easy fix or no?
  209. Topic #100
  210. What auto darking helmet do you recomend?
  211. bodywork/rust repair how to
  212. need welders help!!
  213. mid-pipe welding cost?
  214. RMF all motor header that clears A/C
  215. $120 Harbor Freight 90 Amp Flux Wire Welder....work with 22 gauge sheetmetal?
  216. check out my modified cx mani!
  217. fabrication shop in socal.
  218. Torn/Stripped Engine Mount Stud
  219. cheap welder wire?
  220. What is a "Cold Weld"?
  221. turbi mani
  222. Made some CF FogLight Covers.......
  223. I need exhaust manifold flanges...
  224. Fixing a cracked exhaust mani
  225. Tips on Mig welding. Why does it pop/spark and not lay a good bead?
  226. Welding stainless steel with a mig?
  227. arch welding a downpipe
  228. Help! Wire Feeder Problem! Any idea?
  229. need to "un tig"
  230. welding turbo stuff.
  231. welding stainless...
  232. All Motor headers --- just wanted to share our design/fab skills
  233. thinking about going to school for welding/fabrication
  234. ITB's
  235. Hobart Handler 135
  236. what do u use to cut sheet metal?
  237. something fabricated in CAD
  238. put my front end on
  239. How do these machines look ?
  240. who can fab this: swaybar mount bearing
  241. ITB-Turbo motor :)
  242. Is tig cleaner(less sparks/slag/smoke?)
  243. Anyone have pics of MIG'd aluminum?
  244. broken block (motor mount)
  245. Where to purchase materials for a roll cage
  246. need mani for a turbo eclipse
  247. Clarke Mig Welder
  248. Carbon Fiber process..
  249. Best TIG machine for the $$$???
  250. Composite material temperature limits?
