View Full Version : Welding / Fabrication
- question for people with 3 inch downpipes
- Audi Intake Manifold Project
- undercar aerodynamics out of sheetmetal
- Question for the Harbor Freight Tig Welder owners....
- Need help buying a welder
- which exhaust clamps for aluminum tubing?
- Looking for a shop that does Mandrel Bent Piping in SOCAL
- I'm looking for local machining in orlando, alibre user here.
- Buy new doors or get body work done ?
- Underbody Skid Plate: Would you rock it?
- WELDED NUT OFF THE REAR LCA-HUB
- Good tig welder?
- buying a collector jig
- Major body work
- Dry sump oil tank?
- anyone ever warped a v-band flange?
- just got a new torch..
- Fuel Tank Sump?
- Yesterday's project
- variable exhaust
- Some recent fab...Topmount pics.
- ? Should i buy this welder ?
- Looked at 3 welders today which one
- Flange Needed ASAP!!! who has/can get one????
- pics of the trailer in progress, aka: the "truck"
- Best way to cut TONS of metal??
- crimps and crimp tool oem uses?
- Hydraulic to Cable Gearbox Conversion
- Tig Welder in Portland/Vancouver area???
- Quick look , oil catch can fabrication
- tacking methods?
- Non-Honda Fabrication
- Let me see your downpipe!!!
- Did i get ripped off.. Piece of stainless..?
- stainless flex pipe?
- problem with welding
- Help with welding Radiator Support
- Header cracked all the way through. Quick fix?
- Turbo Elements D Series Topmount and 4"Downpipe
- devcon hookup
- sr20 turbo manifold
- How can i get rid of all the small dents on my car????????
- Custom Widebody?
- lincoln weld pak 3200hd
- Welder Repair Parts?
- aluminum mufflers. where to buy?
- recent fab work on a customers integra gsr....
- how to change a civic radiator support
- CUSTOM INTERCOOLER
- Happy Mothers Day
- DOM stainless
- How to build something straight?
- any pics of the front lower radiator support swaped for a tubed one????????
- sound deadener materials?
- How can you tell the difference between SS and Mild Steel?
- mig: stainless "gasless" wire
- i want to build a intake manifold on stock flange\runners.... got some q's
- what rod for cast aluminum honda parts?
- starter welder
- quick question
- Rate my welds
- Fender lip roller
- Exhaust: Is mandrel bending necessary for a 45 degree bend.
- Best place for schedule 40 bends?
- what would you do with this header?
- Where to buy rounds aluminum rings for velocity stacks?
- what welder to get...
- Bodywork question.. is this fixable easily or no?
- what kinda tig torch do you have? searching for a smaller torch.
- welding roll bar plates
- This is the stupidest question I've ever had to ask: Which way does one move when TIG welding?
- Welding Inconel, need some help =)
- Does anyone make a 4" 3 bolt exhaust flange?
- VR6 Tubular manifold in progress...
- Machining a block and crank from scratch
- anyone using the burns stainless ultralite muffler?
- homemadet intake manfold v.2
- Finaly Got my Harbour Frieght welder Month later
- Collector how to....
- Turbomanifold Studs, threaded rod...Will they work?
- Need a welder in Denver/Colorado to fix my muffler
- some of my welds, comments/suggestions?
- Buy or pass? Air compressor
- do all weld pak 100's upgrade to mig?
- turbo brace?
- Heat Shrink Tubing
- I would like your guys input on this project.
- Making an Intercooler... got some Qs
- rear quarter panel kill!!!
- Are there any good schools to learn how to weld/fabricate?
- Would you critique my weld?
- Misc aluminum pieces - 80/20
- seeking help, bolt is tight, won't thread in, i don't want to snap the bolt.
- some recent stuff i've welded.
- newbie q... reading argon flowmeter
- NRG Tech's RHD EVO 5; AMS Evo Killa
- Fabwork done this week at RCautoworks
- I screwed up my car real real bad...
- anybody try this bandsaw yet?
- DIY intake manifold
- Is it possible to take off a megaphone??
- Rapid prototyping ABS plastic..
- For all you welding guru's (need help)
- fabbed an odyssey battery hold down
- where can i get a tube polyurethane?80d-120d which one 4 mounts?
- D16 Exhaust Flange dimensions
- suggestion for quad throttles on my b18c
- Few things i made for a friend
- install jdm front end
- anyone heliarc?
- What the heck happend?
- roll cage size
- For Sale Miller Syncrowave 300
- i have a welder and supplies but i need some info before i start
- What do i, do i plug the holes now that i took the factory wing off my EM-II HELP LOL
- What's the best way to cut 1/4" steel?
- Did some oxy/fuel welding on my bike *pics*
- I have a welding question, please awnser promptly...
- Is this collector ok?
- Need helpf fabbing a eg hath roll cage
- Recent fabwork here at phoenixturbo
- company to cut sheets of stainless?
- How to: get rid of Brake Dust?
- Collector Help!!
- So I bought a block guard.
- JD2 model 3 question
- Spray Dye Vs. Spray Paint
- Spray Painted Interior..HELP
- Can anyone help me?!?!?
- 3" Aluminum Intake Tubing?
- DIY Painting Help
- Looking to get my Aluminum charge piping welded up...
- TW metals?
- What do you need CNC'd?
- intercooler couplers Home Depot?
- Vacuum infusion molding (VIP) Carbon Fiber - How to with pics and videos
- What kind of welding wire/rod do you use to not splatter?
- Idea for 3" floating exhaust flange - Good or bad?
- Sealing slip on exhaust connections.
- Removable roll cage elements
- DIY DRO
- How are gusset dimples made?
- Where to find 2.75" Aluminum V-bands???
- Chicago Electric = Clarke?
- hacking a foot pedal on to a tig without one...
- Welding up a turn down tip, suggestions??
- Welding on doors
- Sound Proof thing where do i get that??
- Back Purging valve
- post your ti welding.
- ITB air box
- looking for aluminum cylinders that are cut in two!
- Rust Holes
- buying/making perf. tubing for mufflers
- Flux Core vs. MIG
- Shaved/Molded Hatch Complete
- Pictures of a simple yet effective setup we just completed....
- does anyone have experience/reviews for the miller econo tig
- WTB collector
- can most types of steel be welded together?
- First few tig welds on a 4-1 Collector and 2 soda cans.
- What are these called???
- Oxy/Ace Welding... Weld on a muffler?
- anybody interested in pre-bent aluminum pieces for cells brackets plenums etc.
- Built a set of carbon fiber pipes for motorcycle
- ever fab up a sand rail chassis?
- WTB: MIG WELDER 220v
- Thinking about a Miller Spectrum 625 plasma - will it do what i need?
- Rate my welds....building my exhaust (2.5" mild steel 14ga)
- "Rotating machine" for better welds?
- Build your own English Wheel
- mig techniques?
- Solidworks intel celeron d?
- 4130 chromoly?
- carbon fiber bikes
- SMAW
- Custom Auto Body & Fabrication Services...available in the Philadelphia Area!!!
- All Lincoln welders are NOT created equal
- First time TIG Welding Rate my weld.
- Smashed SMSP, fixable?
- Anyone have this?
- What is Cosmo? Solidworks?
- Bent wheel stud
- Trumpet tubing to go from 60 mm to 2.5 inch??
- TIG services needed in NOVA to weld cage in car...
- Sex comes in gold ;)
- Chinese 200 amp AC/DC welder with Foot Pedal
- Just got my TA185 Quick Wiring Question
- Double sided carbon fiber overlay and Dzus details
- mig on 304 s.s ok?
- Need a little advice on alum. welding - surface tension on the material
- Road Racing Cage for E46 BMW Recently Completed...
- NHRA 6 point roll bar approved?
- ARC WELDING HELP
- Exhaust fab shops in/near Rockville, MD
- good place for merge collectors (2-1)
- Prep Work?
- In need on tig welder in san jose (gun related)
- RX7 3'' DP and dumptube.
- Solidworks Flange files
- TIG weld Aluminum with My MIG???
- home CNC software
- B16A dyno on pump
- Post A pic of your welding cart/ worktable/ or even workbench.
- anyone know where i can get a head flange for nissan RB25
- New project and ? about surface rust removal
- any one done any leading?
- Pipe Bending..
- Radiator end tank design question
- Welding aluminum..........
- Fabbing IC end tanks, how thick?
- intake flang
- Is a propane tank safe for compressed air?
- 2.5 mugen bpipe to 2.25 comptech axle back...
- First time welding 304 to cast.. check it out
- FS: BN* WP1712 WeldCraft FLEX Air Cool Torch - 12ft Braided Hose + #8Cup/Gas Lense
- Brazer meets Tig welding... Whoa (PICS)
- My rusted Coated AN-R header
- solar welding mask
- dude wtf...damn welder doesnt work
- intercooler pipings
- ONEFAB manifold problems
- Where can I get a Ceramic coating?
- DIY 3-axis CNC Mill (or lathe)! Must see!
- Crossmembers
- Thanks......
- Got my suncro 200 going, have a question on welding SS and getting good color
- New equipment - bender/notcher/blah blah... blah
- Where to get tight-radius MILD Mandrel bends?
- Post Pics of your recent fab work Manifolds, Cages, Exhausts, etc.
- need help putting my fuel lines together
- proper gap spacing for butt welding pipe?
- DIY Short shifter... experiments.
- MIG welding Mild Steel to SS Steel?
- ***New Bender*** pics and stand build!
- quick question
- I need an intake flange cut
- IM runner question
- Bodywork question...
- I need an intake manifold flange
- Need a b-series 1/2in mild steel header flange
- Hot Rod chassis
- electric impact wranch.
- SS head flanges?
- looking for someone in upstate ny to do some tig welding for me
- bender question
- CAREER DECISION
- DIY: Coating a header.
- Chop saw users
- First time tig welding please help
