View Full Version : Welding / Fabrication
- Looked at a trade and found bent radiator support, unsure of how bad it is?
- The Fab School announced the availability of Federal Financial Aid
- New plasma cutter
- welding a lever inside the tranny?
- Machine Shop? Mazda Pressure Plate on Mitsubishi Flywheel
- D3 Performance Engineering is looking for another Fabricator!!
- Custom cam cover B series
- Mandrel Bending for Exhaust near Silver Spring, MD
- Billet Merg Collector
- What gloves do you use?
- Where to find flared connectors/flange?
- Rounded or tapered top/bottoms for catch cans?
- torch heat, how long till you give it a break?
- What piece is this?
- what do you use for polish ss?
- Rear Deck Removal
- snapon welding helmet?
- Aluminium or stainless intercooler piping?
- OR FAB - FABRICATION THREAD V2
- Need input for 3s-gte turbo manifold im making
- MIG gas bottle question
- Carbon Fiber Expert in So. Cal?
- what are you building, parts for cars,not cars
- Custom Intake Manifold Velocity Stack Questions
- How to remove '1' cylinder Head bolt head by drilling?
- Argon gas analyzer!
- looking for a 321 4-1 collector
- T4 flange with round hole.
- Looking for precut sch40 4-1 ss t4 collector... BMC is a no go.
- CRX2000 hits the dyno
- Flexhone to port manifolds?
- alumiweld aluminum brazing, when you cant afford a tig
- Rsx seats in ep3
- intake manifold 1.8t
- Side Branch Resonator
- what cup# you use for aluminium tig welding?
- J32 v6 LONG tube header build
- Turbo mani is spiking. Trying to understand why... Help
- Crack at Oil Pressure Sensor B18C1 What's the Prep Work for Welding?
- Where to buy misc exhaust parts?
- E-FAB Fabrication pic and projects
- who wants $100 worth of free flanges?
- My Evo Engined Fiesta Project
- My welding log
- Metal Storage-What do you do?
- A little welding progress
- AceStainless.com — Free Shipping this weekend!
- Bent frame/subframe support pillar
- where to buy inexpensive K series exhaust flange
- Solidworks - CNC for your honda
- 90 Amp Flux Wire Welder???
- How would YOU weld this downpipe?
- Cutting lca bolts with rotary tool.
- Best place to souce 4" up-pipe
- What motivates you to weld/fab/machine?
- where to make custom parts?
- How do you tig muffler/resonator collar to exhuast tube w/ gap?
- Transmission question..
- Sheet metal intake questions
- Body repair questions
- Back purging and weld cosmetics
- Tig Welding: Walking the Cup
- HELP Is the air duster myth true
- bandsaw recommendation
- looking for some VW vr6 exhaust flanges,
- Where to source small velocity stacks
- turbo lamp
- Question on exhausts for 2 cars
- Cheap tig, how far can you go?
- Cracks in manifold
- Anyone know where to have logo tags made?
- Schwannman's Fab Thread
- HellaFab Fabrication Pics
- Were to buy coolant nipple
- B Series Full-Race TopMount Question
- welding in a bung
- FAL window kit installation question
- 80mm DBW Honda Civic Si throttle body
- Looking for advice . Anyone using a mill lathe combo?
- What cad software to use for laser pipe cuts?
- Post your tunsgten, filler, cup preferences
- Wastegate pipe out of turbo collector HELP!
- Miller Diversion 180
- Walk in shop prices?
- Some advice about weld colour?
- Divided manifold collector
- additional transmission support mount/bracket
- anybody have make a twin scroll mani for this turbo?
- Chicago Pipefitters Local Union 597..anybody work for them?
- Gonna custom fab my....
- Solar Flux B, first impressions
- How to hook up this hard nitrade carbide bit
- trading for a car thats had a accident?
- Custom Fabrication Item - How Much $$ To Replicate?
- What fitting is this?
- looking to buy a band saw
- 91 dc dash in a 91 civic hb
- Welding Fume extractors?!?!
- Removing my resonators...Percs and Cons?
- Toxicfab.com "On My Own" Fabrication Video
- weld els
- Ventilation in your shops.
- integra side moldings removal?
- BMW RollCage Build!
- b16 intake flange
- b16 intake flange
- Divided top mount with single 60mm gate
- Custom 3" exhaust over LCA Pictures
- Finally accepted into Welding School
- Argon Consumption-manifolds
- Discount on Welders/plasma cutters
- Ek hatch roll cage measurements
- 1500hp rear mount turbo Z06 build
- good tutorial for resin transfer composite layout
- CNC Plasma cutting intrest
- radiator support
- mount to fire wall and mount to rad support measurement
- Cold Air Intake Box for a turbo
- Helicoils In Engine Block?
- sugaring
- 10 point cage floor bar ??
- rad support replacement
- Band Saws. Opinions wanted from those in the business/hard-core part-timers.
- Intermediate pipe between tial MV-R and manifold?
- Basic question
- swaping the h22a out with b18a1 in 98 prelude
- Anyone ever used the Eastwood MIG 135 or the Real Gear MIG 140?
- mid engine RWD crx 2
- does big cup affect width of the arc in AC?
- household welder
- Removing/Cleaning Rust????
- VW 20vt 1.8t manifold flange dxf dwg needed,
- people making custom parts/molds. how you do it?
- Collector help
- I'm planning on becoming a Welder/Fabricator
- Econotig Circuit board
- imported welding equipment, is it good enough yet?
- Radiator modification
- ef2 jdm radiator support to a usdm frame
- how do you will make this?
- Finally got a chance to get my welder out, a couple questions
- AL fuel hardlines, experiences?
- Filler Rods
- Torque Mount Frame Replacement
- Lincoln 2185 handy mig welder up to the task?
- post flow?
- Roll-cage welding
- weld test for a new job thurs. advice needed for flux core welding!
- Newest bike build...
- what generator to use for 220v welder
- HF bead roller - review with pics
- Compressed air hose ends
- CRX: Carbon Console Panel, Plug Design, Mold Construction, and vacuum bagging.
- Need a Fab tec HELP!
- beginner tig welder
- Can't See Puddle Tig Welding
- Looking to buy this belt sander and bandsaw..
- filling voids in valve cover
- Custom Radiator
- Stainless for down pipe?
- Where to buy longer top hat studs?
- need help please read.
- JDM Front gaps
- some work from the last few months.
- Mini Tig Torch?
- Some fabrication
- Looking for someone in SoCal to fab a turbo manifold
- Intrgra armrest cupholder repair
- B series exhaust manifold flange
- Tips and Tricks
- Helium argon setups?
- Gauges dimetion
- RHD Conversion Shops in San Diego???
- need info
- Best metal to weld?
- cad file b series
- looking for this garret cad flange
- where can i buy a tial gt35 inlet flange?
- What sizes are these V-bands?
- downpipe flanges
- ek tube frontend??
- Looking to have something CNC Machined..any suggestions?
- My Simple B16 Build.. What Turbo Would You Use?
- intake manifold build where can i find flanges...
- Looking to buy a 165 ? Any recommendations ?
- what tungsten do you use? SS/Al
- welding intercooler cores
- looking for 2.5" to 3" exhaust taper
- which mig welder?
- Stress Analysis: FEA
- t4 flange 3/4" thick
- B18 exhaust and intake flanges cad file
- Welding head flanges-mounting heatsink
- fiat seicento / all motor f20b
- EG/DC Prototype Triptronic Trans Mount Bracket**
- 1/4 or 1/2 steel for diy seat brackets?
- bike frame, leather, etc.
- driver wheel housing
- Can anyone cut some parts for me?
- Stainless welding question..
- Custom radiator supports / headlight buckets
- Thermal Arc 211i
- Over Control arm/axle bend for my exhaust
- Looking for a specific 90deg aluminum thick wall bend
- First Manifold: Critique and Questions
- problem with valve cover
- Custom cone making question. (Truncated Cone)
- My welding progress
- radioactive tungsten
- Looking for 3" & 4" Center Line Radius 3" mandrel mild steel elbows
- motor mount bolt broke my head
- sunroof rail ends
- Organizing material
- Everlast 185 Micro Q's
- Supplier of tubing
- First outing with SS... Advice Welcome
- Advise me somewhere online to puchase mild steel mandrel bends
- Modular Aluminum Rear Diffuser
- New welder, old problems are back
- got AC Tig!
- 1.5" Titanium tubing
- bolted a hole in the block (help please)
- is this mess even worth fixing?(header)*PICS
- Blew my first welding test ? :/ what now ?
- CF Velocity stacks
- CNC mandrel bending shop recommendations
- Lookin b16 turbo manifold forward facing
- Miller Multimatic 200 Good first machine?
- ''Best design'' for a manifold.
- Machined vac block to weld onto IM?
- My first attempt at a turbo manifold.
- Any one ever film themselves?...................LOL!
- h22a and 1997 dc2 pipe diameter
- so lost...HELP
- Machine main journal or buy a new crankshaft?
- Tig Welding Jobs
- Public Announcement: James @ BMC
- How should I fix this roll cage tear-thru?
- Broken Tial 38mm??
- H22a7 header/manifold
- Intercooler piping help needed
- Bisimoto v2 h22 header replica
- Some Dummy's Welding Photos
- Looking to buy my first TIG...need advice
- CK gas saver cups?
- vibrant fuse wire?..
- Need help with ideas on Dump tube
- collector
- Custom radiator building tip?
- which hand do you use???
