- How to open 2013 CRV ECM
- B18 S300 initial startup way too rich
- ELD missing
- P06 ECU Data log
- T1 style cam only trigger vs cam + crank trigger setup
- Trigger settings for Fueltech ECU using T1 trigger kit
- The great throttle body gasket of the d14a4 put on the d14a3 and the cheapest way to
- Ostrich 1.0 not holding tune
- help 2002 honda 2.3 Engine Management and Tuning help
- What ecu should I use for my 97 b20b vtech turbo
- Low idle after Hondata basemap
- S300, CEL no fuel prime.
- 98 civic runing hella rich.
- Idle hunting after car is warm
- 92 civic failed for high nox
- Distributor Experience with Hondata Coil on Plug Conversion - CPR Retrofit
- AEM Infinity
- Aem wide band Honda tuning suite logging issue
- Aem Infinity
- Need help identifying wiring harness
- Scan Gauge 3? Good for diagnosis?
- 2015 Accord I4M6 data logging?
- white smoke coming from below engine (intake manifold area)
- Basr map with DSM blue tops
- Etuning from Boostednw.com
- Neptune RTP choppy RPM in datalogs.
- Need help identifying this chip in my ECU
- COP Trigger Setup
- help tuning
- D16y7 skunk2 manifold
- FuelTech and IACV
- What would be yhe best O2 sensor arrangement...
- Inovate LC2 wideband with HTS issue
- D series rebuild?
- Beginner Request for tuning data!
- Break in Tune
- Identifying apexi power fc
- H23A VTEC Ignition Timing
- Car will run but will die soon after
- HELP! H23A problem driving me nuts!
- Can someone tell me if these look like stock b series fuel injectors?
- Vegas Invasion Tuning Files
- Bee R rev limiter installation on an EP2
- Newbie looking for help on neptune rtp
- Check Engine light - 2008 Honda Ridgeline
- Hondata S300 Tuners in Texas
- D series valve adjustment
- Windsor Ontario hondata tuning
- Tuning an 1990 Honda
- Need some super knowledge on identification wire harness
- P1166 and P1167 - "Hard Code"?, Possible ECU issue??
- Gsr swap onto b18a1
- F22 V-Tec tuning help
- TPS Issues, NOT READING IN HONDATA
- Need B20v 12.5.1 e85 tune asap
- Obd1 to obd2 adapter
- Cannot get analog inputs working with s300
- correct way to wire ecu fan control (a12) for cars that dont have a ecu fan control
- Tuner Directory - Illinois Tuners
- Attemped to socket/chip PR4 ECU myself…F***’D up ECU?? (OBD1)(PICS)
- Chipped P05 ECU Problem
- Afr not reading on Hondata S300
- TD05H 14b Turbo on D15B2 engine. 94 civic
- ECU options for my Civic Hatch
- Ecu still usable?
- K24a2 Aem series 2 stock basemap?
- Hondata s300 Not showing sensor data.
- 1993 Civic "electric like" noise when under load.
- D16Y7 with P06 ECU
- need help choosing motor
- Starting fresh with wiring. Need some ideas
- 95 Del Sol S D15B7 ECU
- 16a1 to b18c
- B18c type R tuning need help
- b18c1 gsr obd2 to obd1 tuning ?s
- B series obd1 wiring harness and d series vtec obd2 wiring harness
- non VTEC Hondata ecu questions
- P28 issues
- K swap harnesses?
- Limp mode pls help
- Recommended stand alone system for simple build
- Upcoming B16a2 rebuild and upgrade plans
- Boosted b18 cuts out at 10 psi
- Cammed D16 map help
- Chrome Question
- Blown Q34 Transistor on a P72, Can this ECU be saved?
- Is my P75 ecu vtec converted?
- 93 Civic ECM - Waterproofing???
- f23a basemap needed
- Obd0 converted to obd1 but want vise versa
- D15B 3stage Vtec Tuning (Locach)
- Not hitting full boost
- No more Ostrich, need alternate RTP
- 2000 CRV - No signal to ICM
- 1993 Civic Cranks, but does not start /Dashboard does not light on.
- 2012 Civic O2 wire harness color issue
- Fuel injector help 750 to 350 possible?
- S300 Wideband analog connectivity issue
- Which ECU to use for F23a/F22a hybrid?
- Availability of cables for crome tuning
- USED HONDATA S300 V3
- Please can you help identify ecu
- Phearable P28 Chipped ECU or JDM ITR ECU?
- how serious are tight exhaust valves and how much should I pay to have them adjusted?
- PCV
- Need help closeloop wont stay on in hts
- 2004 Honda civic
- 2.4L Jumped Time? #1 Cylinder Binding
- Mustang 70mm throttle body on h22a
- FuelTech remote tuners?
- Tuner directory help
- EK3 high negative fuel trims
- New to tuning
- Tuning a 2000 GSR
- 99 Si cranks no start
- Moates Burn2 not detecting!!
- why did my ECU burn here
- Lost and don’t know if this is the right place to ask this question
- New to me race car issues, I’ve been reading.
- Demon V2 B20 V Base Map
- Stock oxygen sensor with S300
- Removing hondata for emissions
- How to burn a chip with TOP 3100 burner??
- I can't remember what the red button does
- Getting a cel code 6 but the sensor is functional in Tunerview
- Not sure if this is the right place to ask
- 1990 Prelude Losing Power - PLEASE HELP!!!
- I want to tune my d16z6 on a budget
- Will I get any power by buying and tuning a chipped P28 ECU for my Accord CG8 (F18B2)
- D16Z6 1993 Delsol SI ECU
- Hondata S300 Vs. Honda Tuning Suite
- What ecu do I use for a b18a1 into my 97 civic dx
- Is branching vacuum hoses bad?
- ECU Bench Testing
- B16A ECU Wiring is messed up
- Identifying the software a BIN file was made
- Distributor delete?
- Crome Tuning
- 1993 Honda del sol b16 boosted crank no start
- a lil help please engine swap
- Hondata s300 v2 po5
- Connect 4.2 lsu wideband on the stock o2 sensor socket
- OBD2 to OBD1
- ECU, inspection
- Running a B-series Distributor on just an Ardunio digikey. Is it possible?
- Electric wastegate problemm
- FuelTech plug and play conversion for street car?
- B18B1 Timing
- tps calibration issue
- 95 civic ex coupe auto no power to ignition checked fuses all good ???HELP PLEAsE
- Neptune and AEM wideband not working
- Trigger offset for 0BD2 B series distributor for Fueltech ECU
- OBD2 to OBD1 conversion cel diagnostics
- Running Neptune obd1 p06
- CA Legal Turbo Kit?
- ITB B16A2
- ECU for H swap
- Link G4 ECU
- Searching for Reputable Tuner in Pennsylvania
- P28 S300 ECU injectors not pulsing
- high voltage P1298
- Help required to match ECU to P2J Head
- Rolling anti lag wiring question
- 2010 Honda CRV R20A
- Fuel Trim on a Tuned and Boosted car?
- 96spec DC2 P0130 code
- neptune tip-in fuel trim enrichment setting questions
- AEM Infinity 506 questions
- Hondata S300 Fuel Ignition Tables-Is Tuned for Boost?
- How do I tune my CRV?
- FANC A12 WIRING
- P0171 Bank 1 Lean after b20b swap
- 96 ek civic b20 vtec hondata s300 ecu keeps dying
- 650hp Turbo J32A2 - AEM Infinity 708 - Redline Questions
- FuelTech wiring - single signal injectors?
- Automatic ECU must Convert to Manual ECU?
- B18lsv turbo. Same built head new css block
- obd2a vs obd2b
- How many catch cans
- L15B7 internals on an L15A7
- Why are there so many threads on can't advance enough
- What ObdII Ecu can i run in a H22a
- Datalog cable cant connect no matter what
- Immo off d15z8 P9L ecu
- Need a stock JDM P72 map and B20B for Crome Gold
- Base map help
- 98 integra tach and speedo signals
- AEM X-SERIES UEGO problem wtih AFR display mode
- DC/ MD/ VA Auto Shop Recommendations
- 2013 TL CELs
- VTEC
- 13 TL TYPE SHAWD KTUNER Q's
- I WANT TO TUNE MY CAR
- Is this basemap ok? D16Z6
- Ethanol Content (Flex Fuel) Sensor Dropouts. Out of Ideas.
- Cold Idle options without FITV - OBD1 ecu
- Honda CODE READER
- H22 Emulator help please
- timing weird issue
- 2001 honda accord 4cy VTEC 4000 rpm cuts out
- F20B Basemap Required
- Zdyne software
- Aftermarket Distributors and Sensors
- Immobilizer chip swap between 2 obd2b p72's
- Oil Pressure Sending Unit / Switch.
- Canadian car has no ELD or EGRL, can't datalog
- better fuel economy with only 1 o2 sensor working?
- engine shutting down when getting to 2rpm
- HTS can you data log an already tuned car?
- Need help with red light on Kpro V4
- Unable to build boost
- Tach jumping, power cutting out. OBD1 conversion crx
- D16z6 into a 2000 Civic EX
- VTEC Solenoid High Voltage CEL S300 -No boost past 6psi. Thoughts?
- Remove Pop Tune
- B20 swapped 91 integra ecu
- Hondata S300 vs. A'PEXi Power FC?
- Need an Electrical Wizard!
- RSX with Hondata Mapping module. How do I remove to sell it?
- D17A1 to d17a2 swap
- Troubleshooting: 2013 Acura TL Ktuner Flash V2 Getting codes
- Troubleshooting: How to get Proper Ignition timing without lower timing cover
- D12 engine
- Chipped P72 In Limp Mode
- Anyone have any issues dealing with chippingsolutions?
- D16Z6 swap
- Chipping/Reflashing a P28 D16Y8 ECU
- K series turbo guys: A question regarding VTC & Power.
- Code 14 not going away. Bad ECU?
- 99 CR-V B20Z2 AWD AUTO
- Assistance needed: How to route OEM vacuum lines without a Helms manual.
- Closed loop inputs
- California Residents... how will your next BAR appointment go ???
- Ostrich won't connect
- OBD1 P72 internal diagram needed
- Safe basemap to use until I get my car dynoed?
- Tuning a stock 2013 CRV?
- Fueltech ECU into EF Civic
- S300 fuel issue
- Suggestions Needed: 2015 Accord 2.4L - P0088 high fuel pressure Code issues.
- '97 Accord OBD2A Dizzy Works With OBD1 ECU?
- J37A1 swap into a 2007 Ridgeline. Can I use J35 harness?
- Does this ECU look normal ?
- J35A3 3.5L harness and ECU compatibility.
- Erratic afr/lean missfire
- Couple questions on Honda sensor and plug types
- TPS signal noise?
- Mixing E85 and Regular 87 Pump gas?
- AEM wideband ECU install
