engine shutting down when getting to 2rpm
Old Sep 29, 2021 | 11:03 PM
femarse's Avatar
Default engine shutting down when getting to 2rpm
good morn peeps,
i have an honda accord 1999 vtec engine auto transmission 4 plug
lately the car shut off when rev past 2rpm, rough idle and the idle wont even get to 1rpm, almost shutting down unless i pressed the throttle to increased the rpm and hold it at that specific little after 1rpm , gear delay and jerk when shifting from 1 to 2, other gears select well, the car wont also rev past 3rpm on normal drive, this started after changing the engine pulley because the old one cut the alternator belt all the time due to having a little side of the pulley cut off, car wont also kickdown ,vtec solenoid was changed but problem persist, i also noticed oil leaking from the ignition , any help will be appreciated
obd2 scanner reveal the below code p1607, p1361, p1381, p1298, p0325, p0141 , p 0302 as logged fault and pending fault p1399 , p1486
Old Nov 5, 2021 | 08:45 PM
feels's Avatar
Default Re: engine shutting down when getting to 2rpm
Removes and clean the intake system. Eliminates carbon build up for old car, as this could be a reason
Old Dec 27, 2021 | 11:36 AM
greengoblin121's Avatar
sounds like a coil problem to me. you need to change the o-ring on your dizzy remove the 3 bolts and the dizzy will detach from the motor easy o-ring to replace. I would suggest you strip and clean your dizzy the oil and moisture will also effect your dizzy function.
badpig521
Jan 8, 2020 01:47 PM
smokem1
May 24, 2008 12:36 PM
terraflata
Dec 17, 2007 03:36 PM
PiYoImuT
Sep 7, 2001 09:08 AM
