How many catch cans
Hey you-all, I’m building a b16 for my mini pickup. I finished the motor and this is my first turbocharged motor. I have the catch can lines from the rear of the block. Do I need to run lines from the valve cover?
Any help would be a great.
charlie
charlie
This really depends on how much boost and ultimately how much blow-by will occur. Ring gaps and piston to wall clearance will also contribute to this. Check out the catch can sticky in the forced induction section it can be a lengthy but explains the different types of catch can setups.
This is my first turbocharged build. I hope I gapped the rings correctly. I went by the CP instructions. Seems a little tight to me but I guess I will see.
Thanks for the reply and the information.
Charlie
Charlie
kielcivic
Jun 11, 2009 02:57 PM
