S300 fuel issue
Old Jun 23, 2021 | 03:58 PM
1320vickers's Avatar
Default S300 fuel issue
I’m running my fpr at 45 psi and I know the injectors are spraying but it’s almost impossible to start unless I spray starting fluid my overall trim is at 25 and I have my cranking trim at 100 I’ve tried every combination from 0-100 to try and get a consistent start I have 1200cc that I can’t find the pulse time for anywhere but I don’t think it would keep it from running
Old Jun 23, 2021 | 09:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: S300 fuel issue
If you cannot find dead times for your injectors, you should replace them with a brand that provides this information. Otherwise, you need to be on a Dyno to assess the personality of the injectors you have.
Old Jun 24, 2021 | 07:36 AM
I’ve been trying to adjust enough to get it running a weird issue I seen is sometimes when I’m data logging the ms will jump to 10 sometimes on the injectors
spore691
Nov 3, 2012 08:44 AM
gonmaro
Feb 17, 2009 07:09 PM
HondaKid936
Nov 25, 2008 02:09 AM
Benbuilt4u
12
Dec 25, 2005 09:11 PM
Kwuaymaikrup
Feb 18, 2004 10:14 AM
